We came across counterexamples in many areas of mathematics: For example
  1. Sum of irrational numbers not necessary being irrational
  2. The "Windmill blade" function (for lack of a better name of one of the most important counterexample in multivariable calculus that continuity $\nRightarrow$differentiability)$$z(x,y)=\left\{\begin{matrix}\frac{xy(x^2-y^2)}{x^2+y^2},(x,y)\neq(0,0)\\0,(x,y)=(0,0)\end{matrix}\right.$$
  3. Linear algebra problems (e.g. Construct $2$ by $2$ matrices such that the eigenvalues of $AB$ are not the products of the eigenvalues of $A$ and $B$, and the eigenvalues of $A+B$ are not the sums of the individual eigenvalues.)
There are books wrote about counterexamples, such as this
Often, I am bad at finding counterexamples when it is the first time I came across some certain mathematical field of study, thus I tend to approach them as if I am proving something and then either find a contradiction, or encounter a step on the "attempted prove" that acts like a constraint.
For example, in answering the 3rd item, I found a subset of counterexamples that must obey the following:
$$A=\begin{pmatrix}0&b\\c&0\end{pmatrix}, B=\begin{pmatrix}0&f\\g&0\end{pmatrix}$$ $$bg+fc\neq\pm2\sqrt{bc}\sqrt{fg}\\ fg\neq \frac{g^2b}{c}\text{ or }bc\neq 0$$
Since I came across so many similar looking cases (at least in linear algebra and in some abstract algebra) it is tempting to have the following "hypothesis"
Claim: All counterexamples for a given mathematical problem obeys a set of constraint relations that is dependent to the problem.
But is that the full story?
Is there any counterexamples to the claim above?
Now for the subset of counterexamples that obey the claim above, then it should be natural the next step is to think about "optimizing" it, similar to generalising the idea of prove shortening
Is it sensible to think of trying to optimise a set of counterexample to a given problem by finding the worst possible counterexample (i.e. the one which is most nontrivial, least symmetric and breaks the most theorems (but not enough to cause it to fall outside the mathematical object in question) underlying the mathematical object that is covered by the problem?
Tldr:
What kind of fundamental property, possibly at the metamathematical level, that all counterexamples share, that makes counterexamples harder to find in a systematic way than constructing proofs?
To elaborate Qiaochu Yuan said in item 3:
Finding counterexamples is something of a dark art; I have seen literally no mathematical writing of any kind which explicitly discusses how one might go about doing it, even though it is quite an important mathematical skill. Here are some thoughts off the top of my head.
So it seems harder than proofs because there is no known systematic way to do it, other than intuition and trial and error
Understand why this is the case will help me to understand why it is difficult to devise a systematic way to find nontrivial counterexamples such as the windmill blade function
Secret
  • 2,390
    I think the opposite...disproving is easier than proving...reason is that for proving something you need to show that all cases under the given condition is going to be true...but for disproving something you need to provide just one example which is not in accordance with the given mathematical statement. – Soham Aug 31 '15 at 13:23
  • I second the comment of @tatan . In my experience, examples are the best thing. No arguing with good examples. Before I start on a proof I want to see examples of the claim holding. Usually that's not enough to settle the general question but it gives something solid to work from. To disprove something, of course, a single counterexample suffices. – lulu Aug 31 '15 at 13:28
  • It is true that all you need is one counterexample to disprove something, but you need to find the counterexample first, and for that, there seemed to be a difference between finding proofs and constructing counterexamples $$$$ For proofs, we have systematic ways to approach them, and even a lead to shorten them as much as possible $$$$ But for counterexamples, the most common technique is trial and error $$$$ I am interested on why the discrepancy – Secret Aug 31 '15 at 13:50
I completely disagree with your statement that it is easier to prove things than it is to find counterexamples. There are statements that are easy to prove
For every real valued function $f$, there exists a function $g$ such that $\forall x\in \mathbb R: f(x)<(g)$
and statements hard to prove.
There are no integer solutions to the equation $$a^n+b^n=c^n$$ for $n>2$
And there are statements with trivial counterexamples
For all real numbers $x$, there exists such a number $y$ that $y^2=x$
and statements with nontrivial counterexamples, like your windmill function.
5xum
  • 123,496
  • 128
  • 204
  • Yes. Agreed. Proving & finding counter-examples are just as hard/easy as each other. It depends on the problem! – Colm Bhandal Aug 31 '15 at 13:35
  • I have clarified what I meant by "hard". I'll update my question title with that – Secret Aug 31 '15 at 13:42
  • We often have some systematic ways in finding proofs (even seeking for the shortest one as shown in the OP) but we don't have this systematic way for the case of counterexamples. I a interested on why this discrepancy, hence the "hard" – Secret Aug 31 '15 at 13:57
    @Secret And I disagree with your view that the discrepancy even exists. Finding proofs for hard statements requires intuition and vision, just like finding hard counterexamples... – 5xum Aug 31 '15 at 13:59
I would argue neither is harder in general, or at least there's no objective way of making such a judgement.
Finding a counterexample doesn't necessarily require an ingenious guess though, you can find one in a relatively systematic fashion. When proving a theorem, the main question you are trying to answer is "why do these hypotheses imply the conclusion?" You may try to come up with a series of deductions that eventually leads to the result.
Constructing a counterexample is just the opposite of this. You are asking the question "what assumption in my hypothesis is too weak to imply the conclusion and what would be instead sufficient?" You then construct an example which only just satisfies the weak hypothesis and see if it works.
Granted this is only one way of constructing counterexamples (another consisting of guessing until you find one). For example in analysis, if continuity alone is insufficient to prove a claim, you may try a function that is continuous but not differentiable or one that is unbounded, for example. Here you may have a pre-existing toolkit of counterexamples which satisfy property $X$, but not $Y$, which can be tested against the claim.
Of course, this does not make this process easy, but that's the same with proving something. In general, there are no systematic ways of solving problems and at some point, you will need a logical jump or a piece of insight. Common tricks exist though, including so-called standard counterexamples.
ktoi
  • 7,317
  • This is quite new to me, I don't aware there's a systematic approach exists for finding counterexamples $$$$ You answer "Constructing a counterexample is just the opposite of this. You are asking the question "what assumption in my hypothesis is too weak to imply the conclusio and what woul be instead sufficient?" You then construct an example which only just satisfies the weak hypothesis and see if it works." also illustrate how my logical thinking, as my professor suspect, is "moving backwards" because my (tedious) approach is "Explore the mathematical object and find the relation/expression – Secret Aug 31 '15 at 14:14
  • which breaks the hypothesis", which is (if I have understood correctly), the complementary approach to what you suggested. no wonder I often end up wasting too much unecessary time in finding counterexamples because the set of objects I need to explore with my approach is often way larger than the set of objects need to explore using your approach... $$$$ I should keep your approach in mind in future work in my maths side of my career – Secret Aug 31 '15 at 14:15
I think the opposite...disproving is easier than proving...reason is that for proving something you need to show that all cases under the given condition is going to be true...but for disproving something you need to provide just one example which is not in accordance with the given mathematical statement. Also before proving anything you will have to deal with many examples,find out the common among them and proceed.Disproving is much easier....you don't need to do all these.
Soham
  • 9,990
You are asking an incredibly broad question here. My best answer is to question your question. What exactly do you mean by a counter-example? We usually mean something that goes against our intuition. Formally though, a counterexample is just something that goes against a claim e.g. "All integers are greater than $0$" has the obvious counter example of $-1$. OK, so that's obvious, but it's a good (counter-)example of how not all "formal" counter-examples are really useful or insightful. So then we must ask, what is a useful or insightful counter-example? And from here, the question becomes one of opinion, where we must decide what is intuitive, useful, insightful etc. And so I'll stop here lest I get bogged down in my own tedious opinions.
Colm Bhandal
  • 4,649
  • To narrow down the question (which I have done just a moment ago): We often have some systematic ways in finding proofs (even seeking for the shortest one as shown in the OP) but we don't have this systematic way for the case of counterexamples. I a interested on why this discrepancy, hence the "hard" – Secret Aug 31 '15 at 13:48
  • I think the "definition of counterexample" I have in mind is like this: $$$$ A (set of) counterexample is a set containing elements such that it obeys "goes against a claim" and which such "goes against the claim" is expressible as a relation of one or more elements in the mathematical object in question that the problem is based on $$$$ I am not sure if that covers all possible counterexamples in all possible mathematical objects, though – Secret Aug 31 '15 at 13:55
  • So as a specific example, the set of counterexample for "all integers are greater than 0" are ${n\in \mathbb{Z}: n<0}$ – Secret Aug 31 '15 at 14:05
    "We often have some systematic ways in finding proofs" - yes, sometimes we can use techniques e.g. induction, reductio ad absurdum..., but there is no general "formula" for proofs- it's an art not a science. The same goes for counter examples. There are heuristics e.g. looking at small scopes, but again there is no "algorithm" for generating either proofs or counter-examples. For the small scope hypothesis, see: https://en.wikipedia.org/wiki/Alloy_Analyzer. – Colm Bhandal Aug 31 '15 at 15:43
