Let $t_n$ be the number of distinct vectors $T$ of length $n$ that can be made using the above process. Here I will just provide an upper bound on $t_n$. That is $t_n \leq 2F_{n + 2}$, where $F_n$ is the $n^{th}$ Fibonnaci number. First, some definitions; then a proof.
Definition (Compressed form): For any vector $U$ whose elements are in $\{0, 1\}$, we can write it it's compressed form $C$ as follows: $u_0[c_1, c_2, \dots, c_m]$. Here $u_0$ is the initial term, and each $c_i$ is a non-zero natural number representing a contiguous run of $0$ or $1$. Note in particular that $m \leq n$ always holds. For example, the sequence $(0, 1, 1, 1, 0, 0, 1)$ would be represented as $0[1, 3, 2, 1]$.
Proof (of upper bound): Well, according to the lemma below, we know that the compressed form $C$ of any vector $T$ can only have $c_i$ terms are all odd, except possibly the first and last terms. Also, no term is $0$. It is also clear that the sum $c_1 + c_2 + \dots + c_m = n$, from the definition of a compressed sequence. From elsewhere, we can show that the number of odd sequences adding up to some number $n$ is $F_{n + 2}$. Now, if we relax this constraint so that the first and/or last term can be even, we get four possibilities for the first/last term: even/even, even/odd, odd/even, odd/odd. Subtracting 1 from a non-zero even number always gives us an odd number, so the above number of combinations above are $F_{n - 2}, F{n - 1}, F{n - 1}, F_{n}$. Summing these up and using the standard Fibonnaci recurrence gives $F_{n + 2}$. Now, the first term of a compressed sequence can be either $1$ or $0$, so we get $2F_{n + 2}$ for an upper bound, as required.
Lemma: The compressed form of any vector $T$, constructed as in the question, contains all odd numbers, except at its first and last terms. To see why this is the case, consider some intermediate term $k$ in the compressed form. This corresponds to a run $T_{i + 1}, T_{i + 2}, \dots, T_{i + k}$, with $T_{i + k + 1} = T_{i} \neq T_{i + 1}$ and $T_{i + j} = T_{i + h}$ for all $1 \leq j, h \leq k$. That is, it corresponds to $k$ a sub-sequence of $k$ equal terms in a row, and two different terms immediately before and after the sequence, which are themselves equal. Now, suppose $k$ is even, towards a contradiction. Well, consider the $S$ vector that created the $T$ vector. Notice that for any $a$, $S_{a + 1} = S{a} \pm2$. Also note that $T_i \neq T_{i + 1}$ by definition. Now define $D_a = \frac{S_{i + a} - Si}{2}$. We show, inductively, that for odd $a$, this value is odd, and for even $a$ it is even. This is clearly true for $a = 0$. For the inductive case $a = n + 1$, we know that $S_{n + 1} = S_{n}\pm2$. So $D_{n + 1} = D_n\pm1$. So the parity of $D_n$ clearly alternates between successive terms. Now, we have assumed an even $k$. Which means $D_k$ must be even, and $D_{k + 1}$ odd. So then $S_{i + k + 1} \neq S_i$. But by the definition of the compressed form, $T_{i + k + 1} = T_i$. The only way this is possible, from the definition of $T$, is if $S_{i + k + 1} = S_{i} - 2$ and $S_i \leq 0$ or $S_{i + k + 1} = S_{i} + 2$ and $S_i > 0$. But both of these cases imply that $T_{i + k} = T_{i + k + 1}$, which is a contradiction, so $k$ cannot be even.
Lemma (*): For $u \in \{0, 1\}$ every vector, which in compressed form is written $u[1, 1, \dots, 1]$, is constructable with the above process. To proves this, consider first the case of $u = 0$. Then we can see that the vector $V = (1, -1, 1, -1, \dots)$ results in a vector $T = (0, 1, 0, 1, \dots)$. This is because the associated vector $S$ will be either $(0, 2, 0, 2, \dots)$ or $(-1, 1, -1, 1, \dots)$, depending on the parity of the length. For the case of $u = 1$, the vector $V = (-1, 1, -1, 1, \dots, -1, -1)$ or $V = (-1, 1, -1, 1, \dots, -1)$ will work. This is because the associated $S$ vector will be either $(2, 0, 2, 0, \dots)$ or $(1, -1, 1, -1, \dots)$, again depending on parity of length.
Lemma (**): All vectors in compressed form $C = u[c_1, c_2, \dots, c_m]$ are constructible with the above process whenever all $c_i$ are odd. We prove this by induction on $n$, the length of the original vector $V$. We start with two base cases $n = 1, 2$, so that we can jump by two in the inductive case. Well, we notice that both case we get that all $c_i$ being odd implies all $c_i = 1$, and so by (*) we are done.
For the inductive case, again if all $c_i = 1$, then we can just apply (*) and we're done. Else there is some $c_i \geq 3$. But then by induction the compressed form $u[c_1, c_2, \dots, c_i - 2, \dots, c_m]$ can be constructed. Now, look at the associated vector $T$ that results in this compressed form. The term $c_i - 2$ in the compressed vector corresponds to either $c_i - 2$ $0$s or that many $1s$ in a row. In either case, we can extend this to $c_i$ $0$s or $1$s by adding $(-1, 1)$ or $(1, -1)$ at the corresponding slot in the corresponding vector $V$. Doing this preserves the other $c_i$, and so we achieve our desired $C$.
Corollary (lower bound): A lower bound for $t_n$ is $2F_n$. That is $2F_n \leq t_n$. This is because the number of vectors of odd numbers adding up to $n$ is $F_n$ (as shown elsewhere), and the start term in the compressed form can be either $0$ or $1$.
Putting it all together, we have: $2F_n \leq t_n \leq 2F_{n + 2}$.
