Is there any theory, why and when doubling sequences of the decimal part of the fraction numbers occur? Take for example these small numbers:
1/7 = 0.[142857]
1/19 = 0.[052631578947368421]
1/49 = 0.[020408163265306122448979591836734693877551]
where sequence inside [] is the repeating/cycling part.
For 1/7 we can see that doubling is started with 14, following with 28, 56, 112, 224,... when numbers bigger than 2 digits additively carry front part of the digit to the previous number. On the other hand calculation can be done:
$(2^1 7)/10^2+(2^2 7)/10^4+(2^3 7)/10^6+(2^4 7)/10^8+...$
Or complete with summation function:
$$\sum_{n=1}^{\infty} \frac{2^n\cdot 7}{10^{2n}}=1/7$$
For 1/49 we find repeating part $[020408163265306122448979591836734693877551]$ again being a doubling series: $02, 04, 08, 16, 32, 64, 124, 256, \ldots$ whose summation function ends up being somewhat simpler:
$$\sum_{n=1}^{\infty} \frac{2^n}{10^{2n}}=1/49$$
For 1/19 doubling can be seen in reverse order starting from the end of the sequence: $1, 2, 4, 8, 16, 32, 64, 128, \ldots$
I can't find summation function for this however. Calculation of the digits clearly comes from the summation of this sequence:
$$2^0/10^{18} + 2^1/10^{17} + 2^2/10^{16} + 2^3/10^{15} + 2^4/10^{14} + 2^5/10^{13} + 2^6/10^{12} + 2^7/10^{11} + 2^8/10^{10} + 2^9/10^9 + 2^{10}/10^8 + 2^{11}/10^7 + 2^{12}/10^6 + 2^{13}/10^5 + 2^{14}/10^4 + 2^{15}/10^3 + 2^{16}/10^2 + 2^{17}/10^1 + 2^{18}/10^0 + ...$$
which results: 275941.052631578947368421. If we go further adding fractions of 10^-1, 10^-2,... and so on, repeating pattern will be visible on whole number part of the number. My secondary wonder is, if there is a summation function for 1/19?
Primary question is why and when does this kind of forward or reverse doubling sequence occur on recurring decimal expansion?
I have read these materials but doubling sequential behavior of the cyclic numbers are not really discussed on them:
http://thestarman.pcministry.com/math/rec/RepeatDec.htm
https://www.quora.com/Why-does-the-number-142857-have-such-interesting-properties
Link
http://en.wikipedia.org/wiki/Cyclic_number
http://en.wikipedia.org/wiki/Recurring_decimal
http://www.researchgate.net/publication/259735461_An_Unanticipated_Decimal_Expansion
Examples table
G   SL  SDS SF              S
7   6   27  14*2            142857
19  18  81  05^n and 2^n reverse (also 12*4 reverse)            052631578947368421
47  46  207 02 * 6          0212765957446808510638297872340425531914893617
49  42  189 02^n            020408163265306122448979591836734693877551
71  35  126 014 * 6         01408450704225352112676056338028169
79  13  54  1*8 reverse     126582278481
83  41  171 012 * 4         01204819277108433734939759036144578313253
89  44  198 fibonacci       01123595505617977528089887640449438202247191
97  96  432 03^n            010309278350515463917525773195876288659793814432989690721649484536082474226804123711340206185567
109 108 486 fibonacci reverse?          009174311926605504587155963302752293577981651376146788990825688073394495412844036697247706422018348623853211
199 99  405 005^n and 02^n reverse          005025125628140703517587939698492462311557788944723618090452261306532663316582914572864321608040201
G = Generator SL = Sequence length SDS = Sequence digit sum SF = Summation function S = Sequence
Glorfindel
  • 3,955
MarkokraM
  • 671
    I think I found the rule for increments of the summation, that fits to all cases at OT: SUM[((10^x)-n)^(n-1)/(10^x)^n, {n, 1, Infinity}] = 1/((10^x)*n), n=49, x=2 => 1/49 = 0.[020408163265306122448979591836734693877551] – MarkokraM Jul 20 '15 at 14:19
  • The "forward" doubling for $1/7$ and $1/49$ occurs because $100$ leaves remainder $2$ when divided by $7$ and $49$; i.e., $7$ and $49$ divide $100-2=98$ – J. W. Tanner Apr 28 '19 at 18:34
As your research shows, most discussion of repeating decimals focuses on the simple repeating block of digits in the decimal expansion. There is some interest in "cycling" numbers, but those are really just the same repeating block starting at a different point:
\begin{align} 1/7 &= 0.\overline{142857} \\ &= 0.142857\overline{142857} \\ &= 0.14\overline{285714}. \end{align}
The simple repeating block of $1/7$ is easily seen if you try to compute $1/7$ by long division:
$$\require{enclose} \begin{array}{rll} 0.142857 \\[-3pt] 7 \enclose{longdiv}{1.000000} \\[-3pt] \underline{7}\phantom{00000} \\[-3pt] 30\phantom{0000} \\[-3pt] \underline{28}\phantom{0000} \\[-3pt] 20\phantom{000} \\[-3pt] \underline{14}\phantom{000} \\[-3pt] 60\phantom{00} \\[-3pt] \underline{56}\phantom{00} \\[-3pt] 40\phantom{0} \\[-3pt] \underline{35}\phantom{0} \\[-3pt] 50 \\[-3pt] \underline{49} \\[-3pt] 1 \end{array} $$
Once you find a remainder of $1$ after one of the subtraction steps, you know the pattern will repeat. (In general, for $1/n$, you don't necessarily ever find a remainder of $1$; but as soon as you see any remainder that you have seen before, you have found a repeating pattern. For example, $1/6$ has the repeating remainder $4$.)
But long division also reveals shorter patterns that "repeat" in the form of geometric series:
\begin{array}{rll} 0.14 \\[-3pt] 7 \enclose{longdiv}{1.00} \\[-3pt] \underline{7}\phantom{0} \\[-3pt] 30\\[-3pt] \underline{28} \\[-3pt] 2 \\[-3pt] \end{array}
The remainder of $2$ indicates that the rest of the digits of $1/7$ will just be the digits of $2/7$ shifted two places to the right; and the digits that occur there will just be the result of doubling all the digits of $1/7$. In more algebraic notation, what happens is
\begin{align} 1 &= 7 \times 0.14 + 0.02 \\ &= 7 \times 0.14 + 0.02(7 \times 0.14 + 0.02) \\ &= 7 \times 0.14 + 0.02(7 \times 0.14 + 0.02(7 \times 0.14 + 0.02)) \\ &= 7 \times 0.14 + 0.02(7 \times 0.14 + 0.02(7 \times 0.14 + 0.02(7 \times 0.14 + 0.02))). \end{align}
If we rewrite these same equations with all the multiplications fully distributed over the terms in parentheses, the result is
\begin{align} 1 &= 7 \times 0.14 + 0.02 \\ &= 7 \times 0.14 + 7 \times 0.02 \times 0.14 + 0.02^2 \\ &= 7 \times 0.14 + 7 \times 0.02 \times 0.14 + 7 \times 0.02^2 \times 0.14 + 0.02^3 \\ &= 7 \times 0.14 + 7 \times 0.02 \times 0.14 + 7 \times 0.02^2 \times 0.14 + 7 \times 0.02^3 \times 0.14 + 0.02^4. \end{align}
As we continue writing equations in this pattern, we generate the terms of the infinite geometric series
$$ \sum_{k=0}^\infty 7 \times 0.14 \times 0.02^k. $$
The method by which we develop this series suggests intuitively that the limit of the sum as the number of terms goes to infinity is $1$, but we can also use the known formula for the sum of a geometric series, $ \sum_{k=0}^\infty r^k = \frac{1}{1 - r}$, to prove it:
$$ \sum_{k=0}^\infty 7 \times 0.14 \times 0.02^k = 7 \times 0.14 \times \sum_{k=0}^\infty 0.02^k = 0.98 \times \left( \frac{1}{1 - 0.02} \right) = 1. $$
So we have
\begin{align} \frac17 = \frac17 \times 1 &= \frac17 \sum_{k=0}^\infty 7 \times 0.14 \times 0.02^k \\ &= \sum_{k=0}^\infty \frac{14}{100} \times \left( \frac{2}{100} \right)^k \\ &= \sum_{k=0}^\infty \frac{14 \times 2^k}{100^{k+1}} . \end{align}
The factor of $2^k$ in each term of the sum produces the doubling phenomenon:
\begin{align} 1/7 = & \phantom{+0} 0.14 \\ & + 0.0028 \\ & + 0.000056 \\ & + 0.00000112 \\ & + 0.0000000224 \\ & + \cdots . \end{align}
Of course, unlike the simple repeating block $142857$, after a few iterations these doubling blocks of digits start to "overlap", meaning you actually have to add them together rather than simply concatenating them. You already knew that, of course, but I think it's important to emphasize that these sequences and the simple repeating sequences come to the same answer in different ways.
Notice also that $0.02^3 = 8 \times 10^{-6}$. This would correspond a remainder of $8$ at the end of a step of long-division, which we do not allow when dividing by $7$. In effect, the long division algorithm uses the fact that $$7 \times 0.02^2 \times 0.14 + 0.02^3 = 7 \times 0.000056 + 0.000008 = 7 \times 0.000057 + 0.000001$$ to stop the "doubling" effect and start from $1$ again.
You can also get a tripling effect in $1/7$ from the first step of the long division,
\begin{array}{rll} 0.1 \\[-3pt] 7 \enclose{longdiv}{1.0} \\[-3pt] \underline{7} \\[-3pt] 3 \end{array}
This corresponds to the equation
$$ 1 = 7 \times 0.1 + 0.3, $$
which can be further expanded to $7 \times 0.1 + 0.3(7 \times 0.1 + 0.3)$, $7 \times 0.1 + 0.3(7 \times 0.1 + 0.3(7 \times 0.1 + 0.3))$, and so forth, which generates the series
$$\sum_{k=0}^\infty \frac{3^k}{10^{k+1}} = 0.1 + 0.03 + 0.009 + 0.0027 + 0.0081 + \cdots.$$
So long division is one way to discover a doubling or tripling pattern applied to some digits (often many fewer digits than the simple repeated block contains), and there can be more than one such pattern that can be discovered this way.
The last example (the tripling pattern of $1/7$) is an example of the infinite sum $\sum_{k=1}^{\infty} \frac{\left(10^x - n\right)^{k-1}}{\left(10^x\right)^k}$ which you mentioned in a comment, with $n=7$ and $x=1$. This works as a representation of the fraction $1/n$ because the sum is a geometric series, and
$$\sum_{k=1}^{\infty} \frac{\left(10^x - n\right)^{k-1}}{\left(10^x\right)^k} = \frac 1n.$$
(This was shown in https://math.stackexchange.com/a/1372077/139123 using a generalization of this formula, with $N$ instead of $10^x$ and $p$ instead of $n$.)
Let's generalize this formula in a slightly different way:
$$\sum_{k=0}^{\infty} \frac{m\left(10^x - mn\right)^k}{\left(10^x\right)^{k+1}}.$$
Notice that this starts $k$ at $0$ instead of $1$ without changing any of the terms of the series. We can evaluate this as follows:
\begin{align} \sum_{k=0}^{\infty} \frac{m\left(10^x - mn\right)^k}{\left(10^x\right)^{k+1}} & = \frac m{10^x} \sum_{k=0}^{\infty} \left(1 - \frac{mn}{10^x}\right)^k \tag{A} \\ & = \frac m{10^x} \left(\frac{1}{1 - \left(1 - \frac{mn}{10^x}\right)}\right) \tag{B} \\ & = \frac m{10^x} \left(\frac{10^x}{mn}\right)\\ & = \frac 1n. \end{align}
Once again, we use the formula for the sum of an infinite geometric series to get from step (A) to step (B).
This gives you a lot of flexibility in setting up geometric series to find doubling, tripling, or other $N$-tupling digit sequences in a repeating decimal fraction. For example, setting $n = 7$, $m=14$, $x=2$,
$$ \frac 17 = \sum_{k=0}^{\infty} \frac{m\left(10^x - mn\right)^k}{\left(10^x\right)^{k+1}} = \sum_{k=0}^{\infty} \frac{14\left(10^2 - 14\times7\right)^k}{\left(10^2\right)^{k+1}} = \sum_{k=0}^{\infty} \frac{14 \times 2^k}{100^{k+1}} $$ just as we found before. Other examples are:
\begin{array}{rrrcl} n & m & x && \qquad\text{decimal expansion} \\ \hline 19 & 5 & 2 && \displaystyle{\frac{1}{19} = \sum_{k=0}^{\infty} \frac{5 \times 5^k}{100^{k+1}}} = 0.05 + 0.0025 + 0.000125 + \cdots \\ 47 & 2 & 2 && \displaystyle{\frac{1}{47} = \sum_{k=0}^{\infty} \frac{2 \times 6^k}{100^{k+1}}} = 0.02 + 0.0012 + 0.000072 + \cdots \\ 49 & 2 & 2 && \displaystyle{\frac{1}{47} = \sum_{k=0}^{\infty} \frac{2 \times 2^k}{100^{k+1}}} = 0.02 + 0.0004 + 0.000008 + \cdots \\ 71 & 14 & 3 && \displaystyle{\frac{1}{49} = \sum_{k=0}^{\infty} \frac{14 \times 6^k}{1000^{k+1}}} = 0.014 + 0.000084 + 0.000000504 + \cdots \\ 83 & 12 & 3 && \displaystyle{\frac{1}{49} = \sum_{k=0}^{\infty} \frac{12 \times 4^k}{1000^{k+1}}} = 0.012 + 0.000048 + 0.000000192 + \cdots \\ 97 & 1 & 2 && \displaystyle{\frac{1}{97} = \sum_{k=0}^{\infty} \frac{1 \times 3^k}{100^{k+1}}} = 0.01 + 0.0003 + 0.000009 + \cdots \\ 199 & 5 & 3 && \displaystyle{\frac{1}{199} = \sum_{k=0}^{\infty} \frac{5 \times 5^k}{1000^{k+1}}} = 0.005 + 0.000025 + 0.000000125 + \cdots \end{array}
There is a doubling pattern when the summation has $2^k$ in the numerator, tripling when the summation has $3^k$ in the numerator, etc.
The procedure for generating these examples was simply: given $n$, choose $x$ and set $m = \left\lfloor \frac{10^x}{n} \right\rfloor$. Whether the result is an "interesting" pattern depends partly on how hard you want to look at the digits of the decimal fraction; for example, with $1/7$ there is a pattern with $x=1$, $m=1$ (powers of $10-7 = 3$), a pattern with $x=3$, $m=142$ (powers of $1000-7\times142= 6)$, and even patterns with $x=4$ and $x=5$, but the easiest pattern to see (in my opinion) is for $x=2$ (powers of $2$). The effect is enhanced when $10^x - mn$ is small. It also seems desirable for $x$ to be a fraction of the period of the repeating decimal, and not very large. You can find $10^x - mn$ for as many values of $x$ as you wish by starting with $x=0$ (in which case $10^x - mn = 1$), and for each successive value of $x$ ($x = 1,2,3,\ldots$), multiply the previous result by $10$ and find the remainder when you divide by $n$.
It does not seem simple to predict which $n$ will have small enough values of $10^x - mn$ for small enough values of $x$ without going through this exercise (even setting aside the fact that "small enough" is a subjective measurement here). But by setting this up in a spreadsheet I found some additional "interesting" patterns for $n < 200$:
$$ \frac{1}{17} = \sum_{k=0}^{\infty} \frac{588 \times 4^k}{10000^{k+1}}, \quad \frac{1}{43} = \sum_{k=0}^{\infty} \frac{232558 \times 6^k}{10000000^{k+1}}, \quad \frac{1}{51} = \sum_{k=0}^{\infty} \frac{196 \times 4^k}{10000^{k+1}}, $$ $$ \frac{1}{119} = \sum_{k=0}^{\infty} \frac{84 \times 4^k}{10000^{k+1}}, \quad \frac{1}{127} = \sum_{k=0}^{\infty} \frac{7874 \times 2^k}{1000000^{k+1}}, \quad \frac{1}{167} = \sum_{k=0}^{\infty} \frac{5988 \times 4^k}{1000000^{k+1}}. $$
And of these, I would not consider $1/17$ or $1/43$ to be "easy" to see even after you know what to look for.
David K
  • 98,388
  • Could we summarize at the end something like doubling is consequence of the n power 2 multifier on the equation? Any simole rule or notation to show when it happen? Just to conclude original question. Btw. 1/98 × 2 = 1/49 and 1/49 × 7 = 1/7. So 2×7 the beginning of the sequence is seen here as well. – MarkokraM Jul 28 '15 at 08:45
    Yes, it's the power of 2 that causes the doubling (and I have added a word about that). I also gave a trial-and-error method for finding patterns like this, and used it to find another doubling pattern, some quadrupling patterns, and a 6-times pattern. – David K Jul 28 '15 at 14:16
    Very throughout answer to the doubling and n-tupling phenomenon. I hope other people interested of the topic will be satisfied with it now. I learned a lot! I also made small corrections to few numbers there which were probably copy and paste typos. – MarkokraM Jul 29 '15 at 17:28
  • @DavidK It was a pleasure to read your answer. I was wondering whether the same method that you described could be used to explain how the decimal expansion of $1/19$ can be written as a sequence of doublings in reverse? The OP had also asked this question as a secondary problem. –  Mar 03 '16 at 18:15
    @BrahadeeshS. The answer shows a series for $1/19$ in powers of $5/100$. The obvious connection to the "backward doubling" is that $5/100 = 1/20$, so if we start somewhere in the middle of the series we can compute all earlier terms by repeatedly multiplying by $20$--that is, move one place to the left ("backward") and multiply by $2$ ("double"). But this is not the whole story, because the "starting point" for generating a series in this way is not as clear as it is when we double or triple from left to right. I'll give some thought to what can be said about that in not too many words. – David K Mar 03 '16 at 19:58
