Any idea of solving this equation?
$$\sin x + x\cos x=0$$
I have also tried by setting a function $g(x)=\sin x+x\cos x$ and searching for solutions using the derivative but my atempts w
Thomas
  • 43,555
First, we have the trivial solution: $$g(0) = \sin 0 + 0\cdot \cos 0 = 0$$
Consider $x = n\pi$ for large $n\in\mathbb{N}$, $$g(n\pi) = \sin(n\pi) + (n\pi)\cdot \cos(n\pi) = n\pi\cdot (-1)^{n}$$ We have infinitely many points where $g(x)$ is positive, and infinitely many points where $g(x)$ is negative. This coupled with the fact that the function is continuous and oscillating between positive and negative means that there are infinite solutions to your question.
jameselmore
  • 5,207
This kind of equations which mix polynomial and trigonometric functions do not show explicit solution (take into account that this is already the case for $x=\cos(x)$ and numerical methods should be used.
Narasimham explained that, beside the trivial solution $x=0$, the roots are closer and closer to odd multiples of $\frac \pi 2$ and they are closer and closer to this bound (just consider the positive roots since if $x$ is a solution of the equation, $-x$ is another one). This is then a good starting value $x_0$ for Newton method. The first iterates would then be $$x_0=\frac {(2k+1)\pi} 2$$ $$x_1=(2k+1)\frac \pi 2+\frac{2}{\pi (2 k+1)}$$ what you also could obtain using Taylor expansion at first order. You can, for sure, continue iterating to the required accuracy using $$x_{n+1}=x_n-\frac{\sin (x_n)+x_n \cos (x_n)}{2 \cos (x_n)-x_n \sin (x_n)}$$ Just for illustration purposes, the approximation $x_1$ gives for the first roots$$\{2.20742,4.92460,7.98131,11.0865,14.2079,17.3366,20.4693,23.6044\}$$ while the solutions would be $$\{ 2.02876, 4.91318, 7.97867, 11.0855,14.2074, 17.3364, 20.4692, 23.6043\}$$
Edit
Just for your curiosity, we could do better if, instead of using Taylor, we build the simplest Pade approximant of the function (don't worry : you will learn about them). In such a case, the solution would be approximated by $$x=(2k+1)\frac \pi 2+\frac{2 (2 k+1)\pi }{(2 k+1)^2 \pi^2 +6}$$ for which the numerical values are given below $$\{1.96672,4.91117,7.97828,11.0854,14.2074,17.3363,20.4691,23.6043\}$$
A graph of $\frac{\sin x }{x}- \cos x $ shows a root at x = 0. Other roots asymptotically approach odd multiples of $\pi/2, ( x\rightarrow \infty) $. These can be found by numerical methods such as Newton-Raphson.
Narasimham
  • 40,495
