To summarize,
How was he able to do this?
He lucked out, really. It was a coincidence that it worked and an intuitive guess. As Ragib Zaman said, "Euler most likely relied on his incredible intuition for the guess, then his great calculating ability to check it's validity numerically."
The derivation (though not accurate for most other functions) is:
\begin{align}
\frac{\sin(x)}{x}&=(x-\pm \pi)(x-\pm 2\pi)\cdots\\
&=\left(\frac{x}{\pi}-\pm 1\right)\left(\frac{x}{2\pi}-\pm1\right)\cdots\\
&=\left(\frac{x}{\pi}-+1\right)\left(\frac{x}{\pi}--1\right)\left(\frac{x}{2\pi}-+1\right)\left(\frac{x}{2\pi}--1\right)\cdots\\
&=\left(\frac{x}{\pi}-1\right)\left(\frac{x}{\pi}+1\right)\left(\frac{x}{2\pi}-1\right)\left(\frac{x}{2\pi}+1\right)\cdots\\
&=\prod_{k=1}^{\infty}\left(\frac{x}{k\pi}-1 \right)\left(\frac{x}{k\pi}+1 \right)
\end{align}
Why does this not simply make a polynomial function that has the roots same roots of sinx/x?
Note that it does make a function* with the same roots as $\frac{\sin(x)}{x}$. You can see this by equating the first equation with $0$.
Can this method be used to make other trigonometric functions?
I don't think so. From what I understand, there are six basic trigonometric functions and that's all there is. There is no specific limit on the number of trigonometric functions; rather, these six are the only ones that have caught on due to their specialness, power, and use. (You may find it intriguing that there are hyperbolic analogs of these functions: Hyperbolic functions.)
*I do not think this function could be considered a polynomial function.
This does make a function with the same roots as and yes. (Out of letters)
– 000 Apr 21 '12 at 17:20
