I would like to find a closed form for the following power series: $$f(x;r) = \sum_{n=1}^\infty \frac{x^{nr}}{\Gamma(nr)},$$ where $r$ is a positive integer. Until now, I've tried to let Mathematica compute it and I looked on the net but found nothing similar... Any help will be very appreciated.
Except for the very first terms, it seems to me that there is no closed form.
What I obtained is $$f(x;1)=e^x x$$ $$f(x;2)=x \sinh (x)$$ $$f(x;3)=\frac{1}{3} e^{-x/2} x \left(e^{3 x/2}-2 \sin \left(\frac{1}{6} \left(3 \sqrt{3} x+\pi \right)\right)\right)$$ $$f(x;4)=-\frac{1}{2} x (\sin (x)-\sinh (x))$$ For $r>4$ appear generalized hypergeometric functions but some of them can simplify $$f(x;5)=\frac{1}{5} \left(e^x-\sqrt[5]{-1} e^{-\sqrt[5]{-1} x}+(-1)^{2/5} e^{(-1)^{2/5} x}-(-1)^{3/5} e^{-(-1)^{3/5} x}+(-1)^{4/5} e^{(-1)^{4/5} x}\right) x$$ $$f(x;6)=\frac{1}{3} x \left(\sinh (x)+\cos \left(\frac{\sqrt{3} x}{2}\right) \sinh \left(\frac{x}{2}\right)-\sqrt{3} \sin \left(\frac{\sqrt{3} x}{2}\right) \cosh \left(\frac{x}{2}\right)\right)$$ I give up with nightmares !
- 260,315
Sometimes taking a step back and avoiding computations reveals the hidden depth of a problem. Remeber Galois: "Sauter à pieds joints sur ces calculs" – Alex M. Jun 11 '15 at 10:52
Since $f(x,r) = x \sum \limits _{n=1} ^\infty \frac {x^ {nr-1}} {(nr-1)!}$, for fixed $r \in \Bbb N \setminus \{0\}$ let $g(x) = \sum \limits _{n=1} ^\infty \frac {x^ {nr-1}} {(nr-1)!}$. Convince yourself that after deriving $r$ times you get $g^{(r)} = g$. But this is an easy differential equation, as it has constant coefficients! If $\varepsilon$ is a primitive root of unity of order $r$, the general solution to your differential equation is $\sum \limits _{k=0} ^{r-1} c_k \space \Bbb e ^{\varepsilon ^k x}$. In order to find the coefficients $c_k$ note that for $0 \le k \le r-2$ you have $g^{(k)} (0) = 0$ and $g^{(r-1)} (0) = 1$. This means
$$\begin{eqnarray*} c_0 + c_2 + \dots + c_{r-1} = 0 \\ c_0 + \varepsilon \space c_1 + \varepsilon ^2 \space c_2 + \dots + \varepsilon ^{r-1} \space c_{r-1} = 0 \\ c_0 + (\varepsilon ^2) \space c_1 + (\varepsilon ^2) ^2 \space c_2 + \dots + (\varepsilon ^2) ^{r-1} \space c_{r-1} = 0 \\ \dots \\ c_0 + (\varepsilon ^{r-2}) \space c_1 + (\varepsilon ^{r-2}) ^2 \space c_2 + \dots + (\varepsilon ^{r-2}) ^{r-1} \space c_{r-1} = 0 \\ c_0 + (\varepsilon ^{r-1}) \space c_1 + (\varepsilon ^{r-1}) ^2 \space c_2 + \dots + (\varepsilon ^{r-1}) ^{r-1} \space c_{r-1} = 1 . \end{eqnarray*}$$
The determinant of this system is a particular form of a Vandermonde determinant easily seen to be nonzero, so the system has a unique solution. I do not know whether the minors associated to the unknowns are easily computable (they exhibit a lot of symmetry).
In any case, $f(x,r) = x \sum \limits _{k=0} ^{r-1} c_k \space \Bbb e ^{\varepsilon ^k x}$.
- 35,207
I thank you very much for this clever suggestion. Actually, I would have never thought to do a trick like that. It helped a lot. – Matth Jun 11 '15 at 13:44
Following the idea of Alex.M, and exploiting the symmetry of the system of equations, we get closed expressions for the $c_k$. Indeed, the matrix involved in the system is a particular form of a Vandermonde matrix, which is a Discrete Fourier Transform matrix. This matrix is easily invertible and thus we get the $c_k$.
More precisely, we want to compute the following series: $$\sum_{n=1}^\infty \frac{x^{nr}}{\Gamma(nr)} = x \sum_{n=1}^\infty \frac{x^{nr-1}}{(nr-1)!}.$$ Then, let us define: $$g(x;r) = \sum_{n=1}^\infty \frac{x^{nr-1}}{(nr-1)!}, \quad f(x;r) = \sum_{n=1}^\infty \frac{x^{nr}}{\Gamma(nr)} = x g(x;r).$$ We have then: $$g(x;r) = \frac{x^{r-1}}{(r-1)!} + \frac{x^{2r-1}}{(2r-1)!}+ \dots $$ Then, we have: $$ \frac{\partial }{\partial x^k} g(x;r) = \sum_{n=1}^\infty \frac{x^{r-1-k}}{(r-1-k)!},\quad \forall k=1,\dots,r.$$ Then, in particular, we have: $$g^{(r)}(x;r) = g(x;r). $$ The characteristic polynomial of this simple differential equation is then $z^r -1=0$. Let then $z$ be a primary root of $1$, that is, without loss of generality, $z = e^{\frac{ 2\pi i }{r}}.$ Then, the general solution of the this differential equation is given by $\sum_{k=0}^{r-1} c_k e^{z^k}.$ For $k=0,\dots, r-2$, we have $g^{(k)}(0;r) = 0$ and $g^{(r-1)}(0,r) = 1.$ Then, identifying the terms, we have the following $r\times r$ system of equations: $$ \left\{ \begin{array}{l} c_0 + c_1 + c_2 + \dots + c_{r-1} = 0 \\ c_0 + c_1 z + c_2 z^2 + \dots + c_{r-1} z^{r-1} = 0\\ \qquad \vdots \\ c_0 + c_1 z^{r-2} + c_2 (z^2)^{r-2} + \dots + c_{r-1}(z^{r-1})^{r-2} = 0\\ c_0 + c_1 z^{r-1} + c_2 (z^2)^{r-1} + \dots + c_{r-1}(z^{r-1})^{r-1} = 1. \end{array}\right. , $$ or in matrix form, $\mathbf{F} \mathbf{c} = (0,\dots,0,1)$, where $\mathbf{F}$ is the following matrix: $$\mathbf{F} = \begin{pmatrix} 1 & 1 & 1 & \cdots & 1 \\ 1 & z^1 & z^2 & \cdots & z^{r-1} \\ \vdots & \vdots & \vdots & \ddots & \vdots \\ 1 & z^{r-1} & (z^2)^{r-1} & \dots & (z^{r-1})^{r-1} \end{pmatrix}, $$ and $\mathbf{c}=(c_0,c_1,\dots, c_{r-1})^t$. Since $z$ is a unitary root of the unity, this particular matrix is a discrete Fourier transform matrix. We will prove that $\frac{1}{\sqrt{r}}\mathbf{F}$ is unitary, that is: $$ [\mathbf{F}]_k \cdot [\mathbf{F}]^*_l = r \delta_{kl},$$ where $[\mathbf{F}]_k$ denote the $k-$th column of the matrix $\mathbf{F}$. Then, we have: $$[\mathbf{F}]_k \cdot [\mathbf{F}]^*_l = \sum_{m=0}^{r-1} e^{\frac{2\pi i}{r} km } e^{\frac{2\pi i}{r} (-l)m } = r \delta_{kl}. $$ Indeed, if $k=l$, the result is trivial. If $k\neq l$, we have: $$\sum_{m=0}^{r-1} e^{\frac{2\pi i}{r} km } e^{\frac{2\pi i}{r} (-l)m } = \sum_{m=0}^{r-1} (e^{\frac{2\pi i}{r}(k-l)})^m = \frac{(e^{\frac{2\pi i}{r}(k-l)})^r - 1 }{e^{\frac{2\pi i}{r}(k-l)}- 1 } = 0,$$ since $(e^{\frac{2\pi i}{r}(k-l)})^r = 1$. Then, we can write the inverse of $\mathbf{F}$ as: $$\mathbf{F}^{-1} = \frac{1}{r}\mathbf{F}^* =\frac{1}{r} \begin{pmatrix} 1 & 1 & 1 & \cdots & 1 \\ 1 & \overline{z}^1 & \overline{z}^2 & \cdots & \overline{z}^{r-1} \\ \vdots & \vdots & \vdots & \ddots & \vdots \\ 1 & \overline{z}^{r-1} & (\overline{z}^2)^{r-1} & \dots & (\overline{z}^{r-1})^{r-1} \end{pmatrix}. $$ Then, we have: $$[\mathbf{F}^{-1}]_r =\frac{1}{r} \begin{pmatrix} 1 \\ \overline{z}^{r-1}\\ \vdots \\ (\overline{z}^{(r-1)(r-1)} \end{pmatrix}. $$ Then, we get: $$ \begin{pmatrix} c_0\\ \vdots \\ c_{r-1} \end{pmatrix} = \mathbf{F}^{-1} \begin{pmatrix} 0\\ \vdots \\ 0\\ 1 \end{pmatrix} = [\mathbf{F}^{-1}]_r. $$ Then, we can conclude: $$c_k =\frac{1}{r} \overline{z}^{k(r-1)}, k=0,1,\dots, r-1.$$ We can finally conclude that $$f(x;r) = x g(x;r) = \frac{x}{r}\sum_{k=0}^{r-1} \overline{z}^{k(r-1)}e^{z^k x}.$$ Most of this answer is due to the edit of Alex M., thanks a lot.
- 11
Note that $(\bar z)^{r-1} = (\bar z)^{-1} = z$, so the sum becomes $\sum \limits _{k=0} ^{r-1} z^k \Bbb e ^{z^k x}$. – Alex M. Jun 15 '15 at 17:26
