This post is quite long, since I wanted to include the necessary context. (Maybe I've put there too much.) Maybe you might prefer to look at the questions at the end of this post, first.
$\newcommand{\Filt}[1]{\mathcal{#1}}\newcommand{\Zobr}[3]{{#1}\colon{#2}\to{#3}}\newcommand{\FF}{\Filt F}\newcommand{\Invobr}[2]{{#1}^{-1}[#2]}$ If $\Zobr fXY$ is a map, $\Filt F$ is a filter on $X$ and $Y$ is a topological space, then we can define the notion of a limit (of a cluster point) of the function $f$ along the filter $\Filt F$.
A point $y\in Y$ is a limit of $f$ along $\FF$ if $$\Invobr fU=\{s\in S; f(s)\in U\} \in \FF$$ holds for every neighborhood $U$ of the point $y$.
A point $y\in Y$ is a cluster point of $f$ along $\FF$ if for every neighborhood $U$ of $y$ and for every $F\in\FF$ the intersection $\Invobr fU \cap F$ is non-empty.
Equivalently, the set of all $\FF$-cluster points can be described as $\bigcap_{F\in\FF} \overline{f[F]}$.
We get equivalent definitions if we talk about limit/cluster point of the filter base $f[\FF]=\{f[F]; F\in\FF\}$.
For reference, see e.g. Bourbaki: General Topology p.70, Dixmier: General Topology, Section 2.6 or Schaefer, Wolff: Topological Vector Spaces p.5. Some authors use the name adherence point instead of cluster point.
This type of limit was mentioned in this question.
In this question I am only interested in the special case of the definition of $\FF$-cluster point, when $X$ is a topological space and the filter $\FF$ is the neighborhood filter of some point $x\in X$. (I.e. the filter $\FF$ consists precisely of all neighborhoods of the point $x$.)
I.e. in this case, the set of all $\FF$-cluster points is $$\bigcap_{U\in\mathcal N_x} \overline{f[U]},$$ where $\mathcal N_x$ denotes the system of all neighborhoods of the point $x$ in $X$.
In this case the $\FF$-limit is precisely the limit of $f$ at the point $x$. An it seems very natural to call the $\FF$-cluster point of $f$ a cluster point of the function $f$ at the point $x$. In fact, such definition is used in Bourbaki, p.73.
For example, the cluster points of function $\sin\frac1x$ at $0$ are the points in the interval $[-1,1]$. If we apply the signum function to the preceding function, we get $\{-1,0,1\}$ as cluster points at $0$. (Here I am talking about cluster points of $f$ at a point, where the given function is not defined - but it's not very difficult to modify the above definition to this situation.)
Based on the above observations, this notion seems to be closely related to the continuity at a point. So I would expect that this notion and some results about it could appear in textbooks on real analysis at least for the special case of real functions or functions between metric spaces. (The generality in which I stated the definition above is, as far as I can say, common only in the texts directed more towards general topology.)
I've tried to Google a little and have a look into few books, which I thought might be good references on real analysis (Bruckner, Bruckner, Thomson: Real Analysis; Protter: Basic Elements of Real Analysis; Pugh: Real mathematical analysis). Often I stumbled upon the notion of cluster point of a sequence or cluster point of a set, but the only thing related to the above notion I was able to find was cluster value of a real function here. (The exercise I linked to says that for real functions all cluster values are between $\liminf_{a\to x} f(a)$ and $\limsup_{a\to x} f(a)$ and that these two values are both cluster values. This means that the set of cluster values is a singleton if and only if both limit superior and limit inferior have the same value.)
As I did not find much results about this notion, I wonder whether I was searching for wrong name.
So my questions are:
- Is the notion of cluster point of $f$ at $x$, which I tried to describe above, known under other names?
- Do you know some references for basic results about this notion?
