Motivation: Brocard’s problem
$n!+1$ being a perfect square
Observations: Given a power Diophantine equation of $k$ variables with a “general solution” (provides infinite integer solutions) to the equation which makes the equation true for any integer.
Following can be said-
1. The “general solution” (provides infinite integer solutions) is a rational(not necessary), algebraic expression(can have multiple variable), .
2. The general solution can be expressed using $1$ variable, so the given equation can be expressed using function of $1$ variable and finally, the derivative of the both side will be equal.
In other words, given an, exponential Diophantine equation in $k$ variables with infinitely many solutions, there is some family of uni-variate,closed-form formulas $R_1(n),\ldots,R_k(n)$ (not all constant) using the formal variable $n$, the field operations (+, -, $\times$, /), the integers, and exponentiation, such that $R_1(n),\ldots,R_k(n)$ is a solution for all integers $n$.
Example:
It is known,$x=a^2-b^2;y=2ab; z=a^2+b^2$ are “general solutions”to a power Diophantine equation $x^2+y^2=z^2$, here $k=2$,for any integer $a,b$ the equation holds true.
,$x=a^2-b^2;y=2ab; z=a^2+b^2$ are rational, algebraic expression with $2$ variables $a,b$.
It can written that,$x=f_1(a,b),y=f_2(a,b),z=f_3(a,b)$ Keeping $b$ constant,$x=g_1(a),y=g_2(a),z=g_3(a)$ , thus, general solution is expressed using $1$ variable, namely, $a$, where $b$ is fixed/ constant. So, the equation becomes,$g_1(a)^2+g_2(a)^2=g_3(a)^2$, and the derivative of the both side is same with respect to $a$.
for each integer $a$, an integer solution of the equation can be found and as $a$ increases $g_1,g_2,g_3$ increases, because when these $g_1,g_2,g_3$ are plotted on 2D, it can be noticed that from one integer point to another bigger integer point,each of these $g_1,g_2,g_3$ moves continuously to another $g_1,g_2,g_3$ as $g_1,g_2,g_3$ are algebraic, rational expression (otherwise not possible to provide integer solution with transcendental function expression).
Question: This is a verification post (as tagged below). Are those Observations right? What are the flaws?
Request: Please do not provide another solution (elliptic curve, divisibility). Answer should be directly regarding the post.
Remarks:
1. In general, $g_1,g_2,g_3$ might have points where these function are not differentiable but those points are finite, so the argument can be carried on after those points. For example, if $g(a)= \frac{5a}{a-1}$ then $g$ is continuous after $a=1$.
2. The equality of derivative is a "necessary" condition, not "necessary and sufficient" condition, so, it will not have any impact on FLT for $n>2$.
3.Dont consider different sort of function like, the trivial equation $x−y=0$. you can find the following general solution: Take $g_1(a)=a $and take $g_2(a)=acos(2πa)$. Then , $g_1(a)−g_2(a)=0$ for each $a∈Za\in \mathbb{Z}$. But the derivatives are not equal.(please help to define this!)
Please let me know if anything is unclear / undefined.
