As stated above. I'm working on a possible proof. It appears that $$(b+1)(b-1)=(c+a)(c-a)$$ That's where I'm stuck. Any help please? A clear, simple proof desired, thanks!
$7^2+11^2=13^2+1$
They all have to be odd, otherwise two are even and not coprime.
Look for values $c^2+1$ for which $(c^2+1)/2$ is composite. There will always be another $a^2+b^2=c^2+1$
Empy2
  • 50,853
  • It's just $(a,b,c)=1$. It is not given they are pairwise coprime (see op comments). – user26486 May 29 '15 at 17:01
  • If $(a,b,c)\neq1$ then there is no solution. – Empy2 May 29 '15 at 17:02
  • I don't understand. If (a,b,c) does not equal one and therefore has no solution, then why did you give 7, 11, and 13? I'm kinda confused. – HyperLuminal May 29 '15 at 17:06
  • $7,11$ and $13$ have no common factor, so $(7,11,13)=1$, and it is a solution. But if $a$, $b$ and $c$ have a common factor $d>1$, then so does $a^2+b^2-c^2$. But $a^2+b^2-c^2=1$. – Empy2 May 29 '15 at 17:09
Every number whose prime divisors are of the form $4k+1$ can be written as the sum of two coprime squares. For sure, if we take $c=2^m$, every prime divisor $p$ of $c^2+1=4^m+1$ is of the form $4k+1$, because $$ 4^m+1\equiv 0\pmod{p}$$ implies: $$ -1\equiv (2^m)^2,\pmod{p}$$ hence $-1$ is a square $\pmod{p}$. Moreover, if $4^m+1$ is not a prime, it can be written as a sum of two coprime squares in at least three different squares. So we have a solution for every $c=8^n$, for instance: $$ 4^2+7^2 = 8^2+1, $$ $$ 31^2+56^2 = 64^2+1, $$ $$ \ldots $$
Jack D'Aurizio
  • 353,855
HINT:
Using Brahmagupta-Fibonacci Identity,
$$(ab+cd)^2+(ad-bc)^2=(ab-cd)^2+(ad+bc)^2$$
Set $ad-bc=\pm1\implies (ad,bc)=1\implies(a,b)=(a,c)=(c,d)=(b,d)=1$
Choose arbitrary $a,b$ such that $(a,b)=1;$ then use the method described in my answer here: Solving a Linear Congruence to determine $c,d$
