In the middle of a proof of the Inverse Function Theorem (namely, the proof of Baby Rudin), we use the fact that if $A$ is invertible and:
$$ ||B-A||~||A^{-1}|| <1$$
then $B$ is invertible. The proof for this, however, relies on the fact that the vector spaces are finite dimensional (because it concludes that $B$ is bijective by using that it is injective). How do we circumvent this, if we want to prove that IFT in banach spaces?
    This is true in general for continuous operator between Banach spaces. You can find a proof in Murphy's C$\hspace{0pt}^$-algebras and Operator Theory*, Theorem 1.2.3. – Luiz Cordeiro May 26 '15 at 19:57
    For $\lVert X\rVert < 1$, the Neumann series $\sum_{n=0}^\infty X^n$ is convergent, and gives you the inverse of $I - X$. Apply to $X = I - BA^{-1}$. – Daniel Fischer May 26 '15 at 20:18
If $X$ is any Banach space, with $A, B \in L(X)$ bounded linear operators and $A$ invertible, we have, in the operator norm, using the hypothesis presented in the text of the question,
$\Vert I - A^{-1}B \Vert = \Vert A^{-1}(A - B)\Vert \le \Vert A^{-1} \Vert \Vert A - B \Vert < 1. \tag{1}$
Since (1) shows that
$\Vert I - A^{-1}B \Vert < 1, \tag{2}$
we have
$A^{-1}B = I - (I - A^{-1}B) \tag{3}$
is invertible; this follows from the well-known result that $\Vert C \Vert <1$, $C \in L(X)$, implies $I - C$ invertible; a detailed proof may be found in my answer to this question. Writing
$A^{-1}B = K, \tag{4}$
with $K$ invertible, also allows us to write
$B = AK; \tag{5}$
$B$, being the product of invertible operators, is itself invertible; indeed, we have
$B^{-1} = K^{-1}A^{-1}. \tag{6}$
Robert Lewis
  • 71,180
