-1 is a square modulo an odd prime if and only if that prime is congruent to 1 mod 4.
Why is this, I cant seem to figure it out.
cf12418
  • 869
This is a consequence of Little Fermat: any integer $x\not\equiv 0\mod p$ satisfies the equation: $$a^{p-1}-1=0$$ As, if $p$ is odd, $a^{p-1}-1=\bigl(a^\tfrac{p-1}{2}-1\bigr)\bigl(a^\tfrac{p-1}{2}+1\bigr)$, each integer satisfies either $a^\tfrac{p-1}{2}-1=0$ or $a^\tfrac{p-1}{2}+1=0$, and each equation has $\dfrac{p-1}2$ solutions modulo $p$.
Now we have two cases:
  • if $a$ is a square: $a\equiv b^2$, then $a^\tfrac{p-1}{2}-1=b^{p-1}-1=0$,
  • if $a$ is not a square, $a^\tfrac{p-1}{2}+1=0$.
Let's set $a=-1$. If $p\equiv 1\mod4$, $\dfrac{p-1}2$ is even, so that we're in the first situation, which proves $-1$ is a square modulo $p$.
If $p\equiv3\mod 4$, $\dfrac{p-1}2$ is odd and we're in the second situation, which proves $-1$ is not a square modulo $p$.
Bernard
  • 175,478
So suppose -1 is square modulo of an odd prime p. i.e for some integer x we have that $$x^{2} \equiv -1 \mod p$$ Evidently $\gcd(x,p)=1$, so applying Fermats Little Theorem gives $$(-1)^{\frac{p-1}{2}}\equiv x^{p-1}\equiv 1 \mod p $$ But this can only hold if $\frac{p-1}{2}$ is even, i.e $p=4k+1$ , some $k\in \mathbb{Z_{+}}$
    This is one of the ways I did it in the question I mentioned in the comments (here). The other way is $x^2\equiv -1,\Rightarrow, x^4\equiv 1\pmod{! p}$ and little Fermat gives $\text{ord}_p x=4\mid p-1$. – user26486 May 19 '15 at 22:52
