I am from Hong Kong and have just finished all the public exams. In my high school life, I've learned some topics on mathematics which are fundamental, yet I think are not in-depth enough.
The topics I've studied:
  • Mathematical induction
  • Binomial Theorem
  • Trigonometry-- Basically CPD Angle Formula, Sum-to-angle/Angle-to-Sum Conversions
  • Calculus-- First Principle/ Differentiation (up to 2 variables)/ Integration (1 variables)(by part)(substitution)
  • Matrices and Determinants (up to 3x3)/ Systems of Linear Equations (up to 3 variables)
  • 2-D/3-D Vectors/ Manipulation of Scalar products & Vector Products
That's all.
Question
1) Which of these topics should be studied in broader field? Is there any advanced subtopics that I am strongly recommended to study?
2) I know there're many fields in math that should also be explored, say Set Theory, Topology, Number Theory, etc. Is there any priority in studying these fields?
P.S. I'm quite intrigued by ALGEBRA.
zhw.
  • 105,693
Mythomorphic
  • 6,008
    You might want to give Linear Algebra a try, and if you like it, then try Abstract Algebra. For Linear Algebra, I recommend Hoffman and Kunze. Also, for differentiation and integration, Mathematical Analysis will get you pretty strong in theory. I recommend Rudin's Principles of Mathematical Analysis, or Apostol's Calculus before that if you find it too hard. Good luck. – Hasan Saad May 06 '15 at 18:13
  • @Hasan Saad Thank you for your recommandations. I shall have a look of these books. – Mythomorphic May 06 '15 at 18:30
  • Point-set topology is interesting. (As well as topology in general.) – Akiva Weinberger May 06 '15 at 18:42
  • I already upvoted it, but I’d like to verbally support the recommendation made by Hasan as well: If you know about matrices, determinants, vectors, vector products and such and you are intrigued by algebra, chances are you will find linear algebra extremely enlightening. It’s probably the most natural thing to go to if you want to get introduced to more abstract and structural mathematics. It is also helpful, if not necessary, for studying multivariate calculus and abstract analysis – which would be the next step on the calculus path. – k.stm May 06 '15 at 18:51
The following is just my opinion, so take it with a grain of salt. However, I will warn you not to neglect the fundamental subjects you may not like so much. For example, I strongly prefer algebra to analysis, and consequently didn't internalize much analysis. It turns out, I'm gravitating towards subjects now that require a stronger analysis background than I have, and paying the price for not working as hard as I should have.
  • Linear algebra is a must, and is my recommendation as one of the first things you study. It opens the doors to multivariable calculus, and it can serve as your first introduction into many important topics in algebra/group theory: Invertible matrices form a group, changes of basis transformations are conjugation, etc. That way, when you see abstract groups/rings for the first time, you'll have more objects that you can relate to and say, "Hey, that too was a group/ring, all along!". Further, linear algebra shows up just about everywhere. It's never too early to get started, and it has very elementary underpinnings (linear equations).
  • Number theory has a special relationship with much of (abstract) algebra. A lot of reasoning about finite algebraic structures reduces to number-theoretic considerations, like divisibility. You'll meet things like modular arithmetic ("clock arithmetic"), which are examples of groups. In a sense, basic algebra and basic number theory go hand-in-hand. While basic number theoretic results are used to study groups, you don't need a course in number theory beforehand, and it will help you in basic number theory. Conversely, understanding number theory before learning abstract algebra will make certain parts of algebra much easier to learn.
  • For most studies of mathematics, a rudimentary understanding of set theory is sufficient, and I certainly wouldn't read a whole book devoted to it. My university's "Fundamentals of Advanced Mathematics" was essentially a course in mathematical reasoning (understanding the kinds of proofs, and practice with rigorous proofs), and often the basics of set theory are covered in this setting. You can usually learn more advanced topics on a "need to know basis", and pick them up as necessary.
  • Once you know the basics of set theory, general ("point-set") topology is within your grasp. However, it's generally viewed as a fairly advanced topic of study, despite having basic prerequisites (motivated heavily by analysis). You can look into it now, but I wouldn't worry too much. Topology is an extremely diverse field, with subtopics including differential topology and algebraic topology.
pjs36
  • 17,979
  • Your comment is so detailed so thx a lot. As you've mentioned, group/ring always have their importance. I actually realize it previously, but I just do not know whether I should do it in the highest priority. Now I get it. Btw, about number theory, is there any special thing to study other thanmodular arithmetic? – Mythomorphic May 06 '15 at 19:27
  • @hkmather802 You're very welcome. Hmm, it's been a while since I've taken my number theory class, so I'm a little foggy on the details. A lot of time was devoted to congruence, yes, but it really is deeper than just modular arithmetic. We also covered things that weren't congruence. The course used this book by Rosen, and you can look over the table of contents at that link. – pjs36 May 06 '15 at 23:50
At this point, I would say that there are two goals:
1) Pick up the basic background that any mathematician would be expected to have. Exactly what that background would entail is undefined (and controversial), but you should probably have some familiarity with linear algebra, real analysis, complex analysis, topology, group and ring theory, number theory, combinatorics, and set theory. This is a long-term goal, of course, and I'm probably leaving some areas out.
2) Find what parts of math interest you the most. Math is a huge subject; if you're just finishing up high school, you've probably only scratched the surface. Take a bunch of different classes, read a bunch of different books and papers, and figure out what you're thrilled about, what you like, and what you're not particularly interested in. Any area of math is going to have prerequisites, but learn what you can now and learn the rest when you can.
That having been said, for the immediate future, I'd recommend you take a look at an introductory group theory book. I've never run across a particularly good book along those lines, but Artin's "Algebra" is OK (not great, but OK).
anomaly
  • 25,364
  • 44
  • 85
I will recommend linear Algebra by-G S Strong.
user90533
  • 576
  • You should elaborate on this: why do you recommend this book, e.g. what interesting (or standard) topics are covered really well, what are the strengths of the author's approach, etc. – Marconius Nov 17 '15 at 11:03
