$1^i$ is defined as $e^{i \ln 1}$
$\ln 1$, though, it's not our real logarithm, but it's the complex one; the point is that is a multi-valued function; to be more precise,
$$\ln z = \ln_\mathbb R |z| + (\arg z + 2k\pi)i$$
Where with $\ln_\mathbb R$ I mean the usual real logarithm.
So $\ln 1 = \ln_\mathbb R 1 + (2k\pi)i = 2k\pi i$
Hence $$1^i = e^{i \ln 1} = e^{-2k\pi}$$
So $1^i$ it's not really a number, it's more like a set of numbers; all the numbers in the form $e^{-2k\pi}$, $k \in \mathbb Z$.
The value $k=0$ is special and it's sometimes called the principal value; choosing this value for $k$ clearly results in $1^i = 1$, but it's important to understand that $1^i$ is not a well-defined number.
Note that, as @Jonathan Y. points out, a similar argument also holds for $1^{3/5}$. And if one thinks about it also for $\sqrt 1$, which is not a number but the set $\pm 1$.
The point is that we can define without ambiguity $\sqrt 1$ (take the positive value) and $1^{3/5}$ (there is only one real root).
One could naively think that the same could be done with $1^i$; just define in some way a special value and work with that. The point is that it can't be done; there is no way to specify a value without ambiguity and carry on all the usual algebra rules. So we're stuck with this multi valued definition if we are in the complex plane; if we are on the real line, instead, it's possible to define $a^{b/c}$ as a single value.
P.S. The principal value I referred to earlier it's sometimes useful but problems arise if you define the complex logarithm as it's principal value. Once you start studying complex analysis and (for example) the residue theorem it should be clear why :-)
