Let $R$ be a commutative ring and $M$ a finitely generated $R$-module. Let $s$ be the maximum number of linearly independent elements of $M$, while $t$ is the minimum number of a system of generators of $M$. Show that $s\leq t$.
It is immediate in the case of vector spaces, but my first attempt (explicit computation) didn't work here due to the fact that there are coefficients (elements of $R$) without an inverse. I tried in so much other ways spending a lot of time, and I should be very glad if you cold give me a precise, complete and rigorous proof.
Thank you in advance.
user26857
  • 52,094
    Would it be possible to show that no set of $t + 1$ elements can be linearly independent? Use a generating set of size $t$, express the $t+1$ elements as linear combination of the basis elements and try to figure out a linear dependence between them. That's the approach that I would try first. – Arthur Apr 29 '15 at 19:48
  • Yes, I completely agree! Unfortunately it seems not to work so easily because some coefficients could be not invertible and a linear dependence could be not so evident. –  Apr 29 '15 at 19:59
Let $x_1,\dots,x_s\in M$ be linearly independent over $R$, and $y_1,\dots,y_t\in M$ a system of generators. Now define an injective homomorphism $\sigma:R^s\to M$ by $\sigma(e_i)=x_i$ (here $(e_i)_{i=1,\dots,s}$ is the canonical basis of $R^s$), and a surjective homomorphism $\pi:R^t\to M$ by $\pi(f_j)=y_j$ (here $(f_j)_{j=1,\dots,t}$ is the canonical basis of $R^t$). Now write $x_i=\sum_{j=1}^ta_{ij}y_j$ and define a homomorphism $\phi:R^s\to R^t$ by $\phi(e_i)=\sum_{j=1}^ta_{ij}f_j$. It's easily checked that $\pi\phi=\sigma$, so $\phi$ is injective. Now just use the famous exercise 2.11 from Atiyah and Macdonald.
user26857
  • 52,094
It is not hard to come up with linear dependence using almost the same row reduction techniques from linear algebra. (In a field, you kill $b$ using $a$ by subtracting $(\frac{b}{a}) a$ from $b$. Here, you just multiply $b$ by $a$ and then subtract $ab$ from the result.)
Then all you have to do is show that at least one of your coefficients is nonzero.
user26857
  • 52,094
