Let $E(c)$ be an elementary matrix of the type to add $c$ times a row to another row when applied to another matrix on the left (with $c$ in some off-diagonal position $(i, j)$), and, with the usual notation, let $F_i(c) := \operatorname{diag}(1, \ldots, c, \ldots, 1)$, with the $c$ in position $i$, be another type of elementary matrix. Then, as these two types span the elementary matrix that switches rows, only applying them from the left, they generate $GL_n(\mathbb{R}) := G$. Let $G^+$ be those $A \in G$ with $|A| \gt 0$, and define $G^-$ similarly.
It is well-known that $G^+$ and $G^-$ are the path-components of G. I am stuck with a proof using only the above, and only basic algebra and matrix algebra (no linear algebra (like spectral theorem) results even, and certainly no topology beyond the definition of "path-connected" - using only basic topology makes this fairly trivial).
It is obvious that all $E(c)$ are path-connected to $I$. So they can by and large be ignored, as long as we remember that they could appear in any position relative to the $F_i$.
The $F_i(c)$ are path-connected to either $F_i(1) = I$, or $F_i(-1)$. Note that, obviously, no $F_i(a)$ is path-connected to $F_i(-a)$ ($a \ne 0$), nor, for $i \ne j$, $F_i(c)$ to $F_j(d)$ ($c, d \lt 0$). But only looking at $\operatorname{diag}(-1,-1) = F_1(-1) F_2(-1) \in G^+$, we see that the matrices in $G^+$ also include those whose elementary matrix decomposition includes some which do not path-connect to $I$.
There is an old question in which the answer using this approach simply claims that all matrices $A \in G$ are either path-connected to $I$, or to $F_n(-1)$, which I fail to see (eg, look at the example, or at $F_1(-1)$). It is clear that all $A \in G^+$ have an even number of $F_i(c)$ with $c \lt 0$, and that you get the same determinant if you exchange those pairs with $F_i(-c)$ both, but this would usually result in a different $\bar{A}$.
Assuming a clever way along this last thought could be found, then the $A \in G^-$ could still be connected to any $F_i(-1)$, with $i \in \{1, \ldots, n\}$, and more is needed to show that they are in one path-component.
Stuff I've shown using only similar methods, and that could be used:
1) $SL_n(\mathbb{R})$ is path-connected.
2) $SL_n(\mathbb{R})$ is normal in $G$
I feel that I'm overlooking something easy, and would appreciate feedback.
