$$\sum_{k=1}^{10} \binom{10}{k} $$
I know the answer is $2^{10} - 1$ but I don't know how to get to the answer.
Consider the following:
So $\sum_{k=0}^{10} \binom{10}{k}$ is the total number of choices of any number of objects from a set of 10 objects. That's $2^{10}$, because for each object you have a binary decision: pick it or not.
Thus $\sum_{k=0}^{10} \binom{10}{k} = 2^{10}$. Subtracting $\binom{10}{0} = 1$ you get the desired result: $\sum_{k=1}^{10} \binom{10}{k} = 2^{10}-1$.
Hint: The binomial theorem gives you a formula for $(x+y)^{n}$. In your case, you know the answer should be $2^{10}$... so what could you pick $x$ and $y$ to be so that $(x+y)^{10}=2^{10}$?
EDIT: I thought the sum started at $0$... in this case, you'll have to subtract the zero term $(1)$.
