Using the root test doesn't seem the best way: the ratio test requires
\lim_{n\to\infty}\frac{3n+2}{(\sqrt{2})^{n+1}}\frac{(\sqrt{2})^n}{3n-1}
=\frac{1}{\sqrt{2}}<1
For the root test: you need
\lim_{n\to\infty}\frac{(3n-1)^{1/n}}{\sqrt{2}}
So you just need the limit of the numerator and taking the logarithm brings you to
\lim_{n\to\infty}\frac{\log(3n-1)}{n}=0
Hence $\lim_{n\to\infty}(3n-1)^{1/n}=e^0=1$.
Why is that limit zero? Compute instead
\lim_{x\to\infty}\frac{\log(3x-1)}{x}=
\lim_{x\to\infty}\frac{\log(3x-1)}{3x-1}\frac{3x-1}{x}
The second factor has limit $3$. For the first do the change of variables $3x-1=e^t$, so you get
\lim_{t\to\infty}\frac{t}{e^t}
which you should know is zero.
