Can a finitely generated module $M$ over a commutative ring have $\operatorname{Ann}(x) \neq 0$ for all $x \in M$ while $\operatorname{Ann}(M) = 0$?
It's not difficult to show that there is no such module if the ring is a integral domain. For general, I guess the answer is yes. But I failed to find a desired example.
Censi LI
  • 5,905
Let $R$ be a UFD which is not a PID, e.g. $R=\mathbb Z[X]$, and $M=\bigoplus_{p\text{ prime}} R/(p)$. Note that every non-invertible element of $R$ is a zero-divisor on $M$. Let $I=(p_1,p_2)$ with $p_1,p_2$ primes such that $I\ne R$. Since $I$ does not contain invertible elements, every element of $I$ is a zero-divisor on $M$. Moreover $(0:_MI)=0$.
Now consider the idealization $A=R(+)M$ of the $R$-module $M$. Let $J=IA$. We have that $J$ is finitely generated ideal and consists of zero-divisors, but no non-zero element of $A$ annihilates $J$.
user26857
  • 52,094
  • A very elegant example. Thank you very much. – Censi LI Mar 15 '15 at 07:35
  • I remember seeing this when you first wrote it, and I forgot to ask a follow up. Is this something you had previously seen, or is it your own idea? I only ask because it seems these examples are fairly rare. If there was more literature on them, I would be interested in looking them up. Thanks – rschwieb Apr 15 '19 at 13:53
  • This example is borrowed from Kaplansky, Commutative Ring Theory, Exercises 6, 7, Section 2-2. – user26857 Apr 15 '19 at 17:20
  • But the idealization is a well known trick for producing (counter)examples, and I used it in few answers on this site. – user26857 Apr 15 '19 at 17:21
Here is a proof that no such examples exist over integral domains:
Let $M$ be finitely generated over an integral domain $R$. Let $x_1,\dots,x_n$ be generators of $M$. Take $0 \neq a_i \in \operatorname{ann}(x_i)$ for every $i=1,\dots,n$. Define $a=a_1 \cdots a_n$. Since $R$ is an integral domain, $a\neq 0$ and $a \in \operatorname{ann}(M)$.
Let me now answer the question negatively in the case where $R$ is Noetherian and $0 \neq M= J$ is an ideal of $R$. So let us assume that all elements of $J$ have zero annihilators. Then all elements of $J$ are zero-divisors of $R$. Let $p_1,\dots,p_s$ be the minimal prime ideals of $R$. We know that the set of all zero-divisors of $R$ is precisely $p_1 \cup \cdots \cup p_s$. Consequently, $ J \subset p_1 \cup \cdots \cup p_s$. Then by prime-avoidance we must have that $J \subset p_1$ without loss of generality. But the minimal prime ideals have the property that $p_i = \operatorname{ann}(x_i)$ for some $0 \neq x_i \in R, \, i=1,\dots,s$. This implies that $J \subset \operatorname{ann}(x_1)$, thus $x_1 \, J=0$ and so $0 \neq x_1 \in \operatorname{ann}(J)$.
user26857
  • 52,094
Manos
  • 25,833
  • Actually my answer provides an example of a finitely generated ideal consisting of zero-divisors and having trivial annihilator. – user26857 Mar 14 '15 at 22:13
  • @user26857 This is old, but I should note that Manos proves no example exists when $R$ is Noetherian whereas your example uses a necessarily non-Noetherian ring. – Anonymous Sep 28 '22 at 03:26
  • Although I believe there is a mistake here. The set of zero-divisors equals the union of the associated prime ideals, not minimal primes. The rest of the proof goes through. – Anonymous Sep 28 '22 at 03:46
What if you take $C=\{i^r | r\in \mathbb Q\}$, where $i\in\mathbb C$. $C$ is closed under multiplication. Let $\mathbb Q$ act on it by $r\cdot z = z^r$. Then it's finitely generated as a $\mathbb Q$ module (generated by $i$). Then $C$ is a $\mathbb Q$ module (I think) and every element has non-zero annihilator (I think), but no non-zero rational can annihilate everything (I think).
Gregory Grant
  • 14,874
    I believe you, but then where's the error in my example? – Gregory Grant Mar 14 '15 at 18:49
  • 1 is the identity element, so it is its own annihilator. Keep in mind this is a multiplicative abelian group. So the annihilator of an element $c\in C$ is an element $r\in\mathbb Q$ s.t. $r\cdot c = c^r=1$. Or am I confused about the definitions here? – Gregory Grant Mar 14 '15 at 22:13
    I was trying to make this rigorous by defining $C={e^{ri\pi} | r\in\mathbb Q}$. And action by $\mathbb Q$ by $s\cdot e^{ri\pi}=e^{sri\pi}$. It took me a while to see the flaw, but it turns out that is not a well-defined $\mathbb Q$ module. – Gregory Grant Mar 14 '15 at 23:05
  • Why is it not well-defined? – Manos Mar 14 '15 at 23:10
    It's easier to see if we translate into additive notation. As an abelian group it is $\mathbb Q/\mathbb Z$ and the action is $r\cdot \overline{a} = \overline{r\cdot a}$. But if we do that then $\overline{\frac12}=\overline{\frac32}$ and we'd have to have $\frac12 \cdot\overline{\frac12} = \frac12 \cdot\overline{\frac32}$. But the LHS is $\overline{\frac14}$ and the RHS is $\overline{\frac34}$ which are not equal in $\mathbb Q/\mathbb Z$. – Gregory Grant Mar 14 '15 at 23:15
  • I see. Interesting. Thanks. – Manos Mar 14 '15 at 23:18
  • Well, it's a interesting example, but I don't think $\mathbb Q/\mathbb Z$ is finitely generated. – Censi LI Mar 15 '15 at 07:47
  • It would have been finitely generated as a $\mathbb Q$ module, if it was well defined. – Gregory Grant Mar 15 '15 at 14:03
  • No, $C={e^{ri\pi}|r\in\mathbb Q}$. So $4z=1$ only for $z=\pm 1\pm i$. – Gregory Grant Mar 17 '15 at 15:44
  • @user26857 If you had read the comments you'd see that I already realized this and posted it above. – Gregory Grant Mar 21 '15 at 11:52
    Because it seemed to be an instructive mistake. I learned something from it and apparently others too who have read through it. – Gregory Grant Mar 21 '15 at 12:18
