We know linear transformation $T$ over two vector spaces $V,W$ and the rank $r$ (dimension of image $T$) of $T$ . We also know matrix representation $M$ of $T$.
Is $r$ the rank of $M$ ?
Srijit
  • 460
user12290
  • 1,305
  • How do you define the rank of M ? Because my definition of the rank of a matrix is just the rank of the linear application which is symbolised by this matrix in caconical base. – Adrien Boulanger Mar 06 '12 at 14:16
  • Rank of a matrix is the order of a largest submatrix with non zero determinant. – user12290 Mar 06 '12 at 14:34
Using your definition of rank as the order of the largest submatrix with non-zero determinant (call this $s$), a proof is as follows. Write $e_i$ for the basis vector of $V$ represented by the column vector with $0$s everywhere except for a $1$ in the $i$-th position, and (abusing notation), also write $e_i$ for this column.
First we show $r\geq s$. If the largest submatrix with non-zero determinant arises from taking rows $r_{i_1},\ldots,r_{i_s}$ (and then some $s$ columns) then in particular the rows $r_{i_1},\ldots,r_{i_s}$ are linearly independent, so the vectors $T(e_{i_j})$ corresponding to $Me_{i_j}=r_{i_j}^T$ (for $j=1,\ldots,s$) are linearly independent, and the dimension of the image is at least $s$.
To show $s\geq r$, note that the rows of $M$ span an $r$-dimensional subspace of $K^n$, where $K$ is your field. This is because:
$$M(v_1,\ldots,v_n)^T=v_1Me_1+\cdots+v_nMe_n=v_1r_1+\cdots+v_nr_n$$
so by varying $v_1,\ldots,v_n$, we find that the span of rows of $M$ is (or rather represents) the image of $T$, which has dimension $r$. So in particular (by sifting) there must be $r$ linearly independent rows of $M$. Any submatrix of $M$ formed from these $r$ rows has non-zero determinant, since its rows are linearly independent, and so the maximal size of such a submatrix is at least $r$.
So $r\geq s$ and $s\geq r$, and hence $s=r$.
mdp
  • 14,671
  • 39
  • 63
T: V-> R(Where R is the subspace of W to which T maps V ).
R has a dimension of r[Given] and Let V has a dimension m.
  1. You know Matrix Representation of T wrt to a Fixed basis Of R(say B) and that of V(say A).
Proof That any Linear Transformation from V-> R requires at it first step that their basis Are fixed.
So, Now M(m*r)B(r*1)=T(A)(m*1) where M,B, and T(A) are represented as Matrices and T(A) means the matrix of the Transformed Basis Elements.
MB=T" where the notations denote the respective Matrices.
Now, B is of rank r, T" is of rank m(As T" is the matrix of a Linear Transformation of the BASIS of V)
Now p(T")<=min(p(M),p(B))=min(p(M),r) and By Sylvester's Inequality, Sylvester rank inequality
p(T")>=p(M) => p(T")=p(M)=m
Also, as r is the dimension of R. if m=r it holds.
NOTE: If I have done Wrong ,I will be glad if You Point out my mistake.
COUNTER Example: Take V= $\ E^2 \ $ and R=$\ E^3 \ $ where E is the Euclidian Space.
So m=2,r=3, Here take T(A)= $ \ (e_1,e_2)\ $, B= $ \ (e_1,e_2,e_3) \ $
and Hence Dimension of M = 2.(CHECK!!)
Hence We can Tell it is Equal to r, iff m>=r
Srijit
  • 460
