This is called the decomposition into Euler angles. The problem is that the result depends on which order you're planning to do the x-, y-, and z-rotations in.
Here's the drill, though:
Step 1: Convert your rotation to a $3 \times 3$ orthogonal matrix using Rodrigues' formula. This is well-detailed on Wikipedia and elsewhere, so I won't go into it here.
Step 2: Your matrix $M$ has three columns, $u_1, u_2, u_3$. Let's say you want to write
M = R_x R_y R_z
where the $R$s are rotations (by varying amounts) around the three axes. We could then write
R_y^{-1}R_x^{-1}M = R_z
which, since a rotation about $z$ has interesting entries only in its upper left $2 \times 2$ block, means that we need
R_y^{-1}R_x^{-1}u_3 = e_3
where $e_3$ is the vector $\begin{bmatrix}0\\0\\1\end{bmatrix}$.
Let's make that happen. First, we'll find an $x$-rotation that "kills off" the first entry of $u_3$.
Case 1: Both the first and last entries of $u_3$ are 0. In this case, perform no rotation about the $y$ axis, and if the second entry is 1, pick $R_x$ to rotate about $x$ by $90$ degrees; if the second entry is $-1$, pick $R_x$ to rotate about $x$ by $-90$ degrees. With these choices, $R_x^{-1}u_3$ will be $e_3$.
Case 2: At least one of these entries is nonzero. Let's call them $s$ and $c$. Let $\alpha = \text{atan2}(c, s)$, and let $R_y$ be rotation about $y$ by angle $\alpha$. Then $R_y^{-1} u_3$ will have its first entry zero, and its third entry nonzero. Call the second and third entries of $R_y^{-1} u_3$ by the names $a$ and $b$ respectively. Let $\beta = \text{atan2}(b, a)$, and let $R_x$ be rotation about $x$ by angle $\beta$. Then
R_x^{-1}R_y^{-1} u_3 = e_3.
That means that
R_x^{-1}R_y^{-1} M = \begin{bmatrix}
c' & -s' & 0\\
s' & c' & 0\\
0 & 0 & 1
\end{bmatrix},
and we can write $\gamma = \text{atan2}(c', s')$ and let $R_z$ be rotation about $z$ by angle $\gamma$, and we're done.
It's quite possible that I've made a sign error here somewhere: that one of the angles should be the negative of what I wrote. But if you write a program to implement this, it should be pretty obvious where any error is.
\left[\begin{array}{ccc} 0 & -k_3 & k_2 \ k_3 & 0 & -k_1 \ -k_2 & k_1 & 0 \end{array}\right]$, and the construct $\mathbf{R} = \mathbf{I} + (\sin\theta) \mathbf{K} + (1-\cos\theta)\mathbf{K}^2$, and $\mathbf{R}$ is the rotation matrix you're looking for. – John Hughes Feb 25 '15 at 18:11
