Question 1
Let $G$ be a group and $H\unlhd G$ and $K\leq G$ such that $H\cap K = 1$ and $HK=G$
Let $\varphi:K\rightarrow Aut(H)$ be a homomorphism such that $HK\cong H\rtimes_\varphi K$.
Then is $\varphi$ trivial if $K\unlhd G$? And is $K\unlhd G$ if $\varphi$ is trivial?
Question 2
Let $H,K$ be groups and $\varphi_1,\varphi_2:K\rightarrow Aut(H)$ be homomorphisms such that $H\rtimes_{\varphi_1} K\cong H\rtimes_{\varphi_2} K$.
Then, is there a relation between $\varphi_1$ and $\varphi_2$?
Rubertos
  • 12,491
In general, if $\phi=\varphi\pmod{\operatorname{Inn}(H)}$ then $H\rtimes_{\phi}K\cong H\rtimes_{\varphi}K$, where $\operatorname{Inn}(H)$ denotes the inner automorphisms of $H$ (automorphisms of the form $\gamma_g: h\mapsto g^{-1}hg$).
This then answers you first part of the first question. Can you see why? (The answer to the second part is "yes", and the proof is simple - think about direct products, or do it explicitly).
The answer to your second question is more subtle. Under certain circumstances (for example, $H$ does not map onto $\mathbb Z$ and $K$ is infinite cyclic) the above conditions are necessary and sufficient. For a counter-example, look up the classification of groups of order $pq$ ($p, q$ prime. There I no more than two groups of order $pq$, but there are more than two relevant maps (and no non-trivial inner ones!).
user1729
  • 31,015
