It is clear that a division ring is simple, having only trivial right ideals. It is also clear that if a ring, R, is unital and finite, having only trivial ideals, then the ring is a division ring.
However, is it true that a unital ring with only trivial right ideals is a division ring, with its order being irrelevant?
Anerky
  • 103
Suppose $aR=R$ for all nonzero $a\in R$, and $R$ is unital. Fix $a\in R$; we seek an inverse. By hypothesis we know $1\in aR$ so $1=ab$ for some $b\in R$. And similarly $bR=R$ so $1=bc$ for some element $c\in R$. But then we have $a=abc=c$, so $1=ab$ and $1=ba$ and so arbitrary $a\in R$ have two-sided inverses, and hence $R$ is a division ring.
A symmetrical argument holds if we suppose $R=Ra$ for all nonzero $a\in R$.
A unital ring $R$ may fail to have two-sided ideals besides $0$ and $R$ and still fail to be a division ring due to the presence of zero divisors. The textbook examples are the matrix rings $M_n(k)$ (for any integer $n>1$) over any scalar field $k$ (see this question). Indeed if $k$ is finite then so is $M_n(k)$!
anon
  • 151,657
  • Thank you for your help, Whacka! It is very much appreciated. – Anerky Feb 16 '15 at 23:54
  • What is meant by “A symmetrical arguments holds if...”? Do you mean to say we need not show $ab=ba$ if we suppose $R=Ra$ for all non-zero $a$? – Sun Apr 21 '20 at 04:01
