Take for example the following: $${\left( {{1 \over 2}} \right)^n}$$ as n tends to infinity, the denominator tends to infinity, while the numerator stays the same (i.e. one). I thought $$\left( {{1 \over \infty }} \right) = 0$$ Yet Wikipedia says it equals one? Converging Sequence
Asked
Active
Viewed 113 times
3Your expression does tend to zero. It's the sum of all the terms along the way that converges to 1. – turkeyhundt Jan 14 '15 at 22:32
Oh, I see the difference now. But if one divided by infinity equals zero, then infinity multiplied by zero is one??? – Michael Lee Jan 14 '15 at 22:37
That's a little above my pay grade, but you can check this out. http://math.stackexchange.com/questions/28940/why-is-infinity-multiplied-by-zero-not-an-easy-zero-answer – turkeyhundt Jan 14 '15 at 22:39
@MichaelLee notice that multiplying the equation by $a\in\mathbb{R}$ you get that $0\cdot\infty=a$ but $a$ can be any real number hence limit of form $\infty\cdot 0$ can be any value. – kingW3 Jan 14 '15 at 22:44
@kingW3 I see and the numerator can be any other real number and infinity is not a real number. – Michael Lee Jan 15 '15 at 00:42
Regarding the title: the sequence tends to zero, the limit equals zero. – Hans Lundmark Jan 15 '15 at 07:29
The summands $\frac1{2^n}$ tend to zero indeed. But the Wikipedia page you reference is about the series $\sum_{n=1}^\infty \frac1{2^n}$.
Hagen von Eitzen
- 374,180
And of course, an infinite series can't possibly converge if the summand doesn't tend to zero! – Eff Jan 14 '15 at 22:37
