Is there a function which is continuous and differentiable, but is not smooth function?
By smooth I mean having continuous derivative. For example, the derivative of $f(x)=x|x|/2$ is $f'(x)=|x|$ which is continuous. So I consider this function smooth.
    Does $x\mapsto |x|$ have an antiderivative? – Git Gud Jan 14 '15 at 19:11
  • I think yes, x|x|/2 – user96634 Jan 14 '15 at 19:14
  • @GitGud Isn't that antiderivative smooth? – user96634 Jan 14 '15 at 19:15
    What does it mean for a function to be smooth? – Git Gud Jan 14 '15 at 19:18
  • To have continuous derivatives. The derivative of x|x|/2 is |x| which is continuous. So I think it's smooth – user96634 Jan 14 '15 at 19:21
  • To follow-up on Git Gud's comment, there are many different uses of "smooth". For instance, one of the theorems in my Ph.D. thesis involves smooth functions (more precisely, functions that are non-smooth at each point), but I bet the notion is different than what you're asking about. – Dave L. Renfro Jan 14 '15 at 19:21
  • @DaveL.Renfro I didn't know about that, I thought smooth could only mean infinitely differentiable. – Git Gud Jan 14 '15 at 19:25
  • @user96634 In view of Dave's comment above, please add the definition of smooth to the question. – Git Gud Jan 14 '15 at 19:25
  • Also of http://math.stackexchange.com/questions/292275/discontinuous-derivative –  Jan 14 '15 at 19:29
  • @Fundamental Thanks – user96634 Jan 14 '15 at 19:34
  • @Git Gud: Off-hand, I can think of three different notions I've seen "smooth" refer to, and if I were sufficiently inclined to (which I'm not), I suspect I could find one or two more if I dug around for a couple of days. The three notions I can think of are continuously differentiable, infinitely differentiable, and what I call (to avoid ambiguity) "Zygmund smooth", the last of which can be found here among many other places. – Dave L. Renfro Jan 14 '15 at 19:34
One standard example is $f(0) = 0$, $f(x) = x^2*\sin(1/x)$. Then $f'(0) = 0$, but $f'$ is not continuous at $0$.
