29
I really need to clear up a few things about function notation; I can't seem to grasp how to interpret it. As of right now, I know that a function is roughly a mapping between a set $X$ and a set $Y$, where no element of $X$ is paired with more than one element of $Y$. This seems simple enough. I know that this function is commonly denoted by a single letter, such as $f$, $g$, or $h$. I also that when it comes to "rules" for function, $f$ denotes the set of mathematical instructions that tell how to find an output in set $Y$ given an input in set $X$. $x$ is the input, $f$ is the function, and $f(x)$ is the result of applying f to an input $x$, i.e., the output. My main question is, why do many authors say call $f(x)$ the function? This really confuses me, since $f(x)$ is a variable for a real number, and not a mapping between two different sets. Following from this, why do some say that an expression such as $2x + 5$ is a function? As stated before, this seems to just be a variable quantity that varies with $x$, but is not a function itself. Finally, if it's true that $x$ is the input, $f$ is the function, and $f(x)$ is the output, then why do we manipulate functions, like $f$, through the output $f(x)$? For example, we have the image of $x$ under $f$, $f(x) = 2x^2 + 5x$. The only way to find $f'$ (the derivative of $f$) is to manipulate $f(x)$. If we're manipulating functions, then why must we reference an input variable $x$ in the process? Why do we have to have $f(x)$ in order to find the derivative of $f$?
One of the most confusing aspects about function notation is the differentiation operator. $dy/dx$ represents the "infinitesimal" change in $y$ with respect to the "infinitesimal" change in $x$, and since $y = f(x)$, we can write $df(x)/dx$. The confusing aspect of this is, we say "take the derivative of the function $f(x)$"; however, $f(x)$ can't be a function because it is equal to $y$, which is a variable quantity, not a function. To add to the confusion, we say that the differentiation operator $d/dx$ maps a function, $f$, to its derivative, $f'$. However, as with $df(x)/dx$, we need $f(x)$ in order to transform the function $f$ into $f'$. This seems very confusing, because then it seems that the derivative operator, $d/dx$, actually maps $f(x)$ to $f'(x)$, since we need $f(x)$ to calculate the derivative. The differentiation operator is just an example of a more broad frustration with function notation.
To recap, I know that $x$ is the input, $f$ is the function, and $f(x)$ is the image of $x$ under $f$, which can often be given by an algebraic expression. I know that $f$ is a mapping, so $f: x \mapsto f(x)$. This means that $f$ is the function that maps $x$ to an output $f(x)$. I've determined this for myself, but I always stumble when I see authors or other people refer to $f(x) = $ "some expression" as the function. It is clear that $x$ is a variable of a real number, and $f(x)$ is a variable of a real number that is dependent on $x$. Then, $f$ is the function, the mapping that links $x$ to $f(x)$; yet , people insist on saying that something like $2x + 1$ is a function. Additionally, I know that differentiation is an operator $d/dx: f \mapsto f'$. However, in order to calculate derivatives, we are not given a function $f$, we are given the image of $x$ under $f$, $f(x)$. This means that it seems that the differentiation operator should be $d/dx: f(x) \mapsto f'(x)$. However, I do not think this is right, and it is one of the main points of my confusion.
EDIT: Looking at some of the comments, I have one additional question. When we define a function, we usually do so by writing $f: X \rightarrow Y$, such that $f(x) = 5x^2$, for example. My additional question is, why is it necessary to, in order to define the rule for a function, use a variable x as the input in the function? Why don't we define functions like $f(~)$, with no reference to any variables, since we are specifying the action of the function, not the image of $x$ under $f$...
Wesley
  • 1,567
    I would say that, when it is the original definition, $f(x) = ...$ is to be understood as $f = x \mapsto ...$ As for $d/dx$, you can think of it two different ways, depending on what's convenient in context. Either $d/dx = f \mapsto f'$ or $d/dx = (f,x) \mapsto f'(x)$. These are the same, through an isomorphism usually called currying in the computer science literature. – Ian Jan 13 '15 at 04:25
    Also, you can't compute a derivative knowing only the value of a function at one point. At a minimum you need knowledge of the values of the function on some open set containing the point. – Ian Jan 13 '15 at 04:27
    Short answer based on my opinions: (1) people don't learn grammar, (2) notation (e.g. lambda abstraction) for expressing things both precisely and conveniently is unfamiliar, and (3) people don't properly learn about dependent variables, and are instead trained to interpret everything as functions. –  Jan 13 '15 at 04:30
  • And, typically, the value of the derivative at any given point is defined as a limit involving--hold onto your hat--expressions that vary as the input variable varies. Remember $$f'(x)=\lim_{y\to x}\frac{f(y)-f(x)}{y-x}$$ defines the value of the derivative $f'$ at the specific point $x$, and it does so by considering lots of other values of $f$ at points other than $x$. – MPW Jan 13 '15 at 04:33
    Related:http://math.stackexchange.com/questions/6870/in-written-mathematics-is-fxa-function-or-a-number – Jonas Meyer Jan 13 '15 at 04:43
  • 18
    Are you genuinely confused about what is meant when someone writes "the function $3x^2-5x+7$" or are you being excessively pedantic just to see what people say? In my experience, anyone who can articulate the subtlety that you are bringing up in your question knows exactly what is going on. – KCd Jan 13 '15 at 06:18
    @KCd Oh he knows what's going on. I think he is just venting. – Navin Jan 13 '15 at 08:42
    I heard a story once that someone was giving a lecture at Harvard (on some topic in number theory or representation theory) and people from the audience started to get picky about the notation being used by the lecturer. It somehow was not precise enough for them. After some back and forth comments among various people in the audience the speaker finally said "Hold on! Who does not really know what I am trying to say?" There was silence. "Thank you. Now let me proceed..." The OP's claim not to be able to grasp utterly standard function notation reminds me of the audience in that lecture. – KCd Jan 13 '15 at 09:17
  • Regarding your last edit: that's called tacit programming or point-free notation. You define a function as the composition of other functions, without ever referencing which arguments it has. So: yes you definitely can write in that way, and functional programmers are actually using that kind of style quite a lot. However it has its own limitations, and you probably don't want to abuse it. – Bakuriu Jan 13 '15 at 12:39
  • In principle, you are right : the variable $x$ in the expression of a function $f(x)$ is only a "place-holder"; we con dispense with, writing : $f(~)$. The problem is with finctions of two or more variables, like $f(x,y)=ax+by+c$; in this case we have to introduce some way to indicate the difefrent argument-places, like : $f(\square_1, \square_2)=a \square_1 + b \square_2 + c$ (see N.Bourbaki, Elements of Mathematics : Theory of sets (1968), page 15). The traditional notation is well-known and quite useful ... – Mauro ALLEGRANZA Jan 13 '15 at 12:54
    @MauroALLEGRANZA "Consider following function $f$ defined as $f(x)=\dots$" is the proper way (and I've seen it used), it's just that "Consider following function $f(x)=\dots$" is shorter and everyone understands the meaning. – Joker_vD Jan 13 '15 at 16:35
    I don't see why @KCd and others find it so unbelievable that Wesley is actually confused. I'm also sure that Wesley understands what ‘the function $2x+1$’ means in practice, but what does it mean in theory? This is more subtle than many commenters seem to realize (especially if you're going to stick ‘$\mathrm{d}/\mathrm{d}x$’ in there or something like that), and Wesley is quite right to try to get to the bottom of it. – Toby Bartels Sep 23 '18 at 07:28
5 Answers5
18
$f(x)$ means both the map $x \mapsto \textrm{whatever}$ and the image of $x$ under $f$, depending on the context.
Some people would prefer a stricter convention of always writing the function as $f$. In practice I find there is usually little room for confusion, and saying "the function $f(x)$" conveniently reminds the reader what the independent variable of $f$ is (in the case that $f$ contains many constants, etc).
However, as you point out there are exceptions where confusion does arise, particularly when taking derivatives. For example, is $$\frac{\partial f(x^2)}{\partial x}$$ the derivative of $f$ evaluated at $x^2$? Or the derivative of the composition of $f$ with $x^2$? What about $$\frac{\partial f}{\partial x}(x^2)?$$ Again, one can usually figure out what is meant, but here there is definitely a potential for confusion. With functions of multiple variables it gets even worse; for instance in physics you often define functions $L(x^i, x^{i+1})$ and then need to differentiate $$\frac{\partial}{\partial x^i} \sum_{j=0}^n L(x^{j}, x^{j+1}).$$ It's hard to write down an expression for this derivative that's not a complete abomination. You could go back and rename the independent variables of $L$ using placeholders less likely to lead to confusion, but perhaps better is to switch to notation like $D_1 f$ to denote partial differentiation of $f$ with respect to its first parameter.
user7530
  • 49,280
  • Good examples. We had a similar question on this come up recently http://math.stackexchange.com/questions/1091097/partial-derivative-notation/1091132 – DanielV Jan 13 '15 at 04:51
  • Why is it that people don't use something like $\dfrac{\partial}{\partial x}[f(x, y)]\big|_{x = z}$ to mean the partial derivative with respect to $x$ of $f$ evaluated at $x = z$? – Clarinetist Jan 13 '15 at 18:51
  • @Clarinetist People certainly do; as for why it's not used more often, I would guess the main disadvantage is that it's cumbersome (especially if $z$ is some complicated expression). – user7530 Jan 13 '15 at 18:56
  • In my experience, the notation $f$ is also used for both the function and the image of $x$ under $f$ (where the choice of $x$ is implied, and the implied argument(s) might differ between functions). For example, given $f(x) = x^2 + 3x$, we might be asked for $\frac{df}{dx}$, where the requestor really means $\frac{d(x^2 + 3x)}{dx}$. In order to ascribe meaning to that request, we must remember that $f$'s favorite letter is $x$. – Richard Smith Apr 17 '21 at 01:03
I think the question of notation being abused and ambiguous applies to many more things than functions within mathematics. I could (and I think this has been done before on this very site) make a list of notations (or expressions) whose meaning is dependent on context. In practice, a shorthand, or convenience, notation is usually never a problem.
However, I do think there are times when context is not sufficient. Consider how:
$f^2(x) = f(f(x))$
for most functions, but I have also seen the (very strange to me):
$sin^2(x) = (sin(x))^2$
which puzzled me greatly when I first saw it. But then again, I'm more of a programmer than a mathematician, so I do like it when expressions are non-ambiguous. I one asked a mathematician (back in the 1980s) "How do I know when $f^n(x)$ is iteration and when it is raising the result of application to a power?" and he thought for a few minutes and then said: "I think it is the latter when the function is transcendental." But I am not so sure of that answer: I've seen $\log^2x$ mean both $\log(\log x)$ and $(\log x)^2$ and it drives me crazy! (By the way $\log \log n$ appears often in algorithm analysis.)
I point this out because this is a case where the context is often insufficient to disambiguate the notation. So why did someone use the notation for raising the result to a power to begin with? I believe it was to save time writing parentheses! Yes, they traded convenience for ambiguity! But back when this notation became popular, there were more engineers than there were pure mathematicians and functional programmers concerned with function iteration. :)
EDIT: In the comments below someone said that the notation has a ring theory justification.
Now to return to your question, in the case of $f(x)$ referring to the function versus the result of application, personally, as one who does functional programming, it does make me sad to see "the function $f(x)$" when the codomain of $f$ is the real numbers, because I so badly want the codomain to be functions! Yes, I like higher-order functions, and I almost feel bad for those who.... oh, never mind.
The probable source of the expression $f(x)$ when someone means to write only $f$ is that the former gives an indication of the arity of the function. That said, it does create an ambiguity, which you must try to figure out, but the surrounding text should make it so you usually can. Human beings are not bound to be all the time unambiguous and super-precise, so we take notational liberties.
Now, obviously a problem can occur if you take this abuse of notation and try to use it in a program. I don't know many programming languages that would tolerate that kind of ambiguity.
As to your other point, yes if someone tried to say that $2x+5$ was a function, they are probably only doing so because they do not want to type, or write $\lambda x. 2x+5$ -- perhaps because they don't like Greek letters (just kidding) or any of the other countless representations for anonymous functions. Again, people are allowed to do this because they are being informal. When writing programs, yes we must say:
  • (x) -> 2*x + 5 // CoffeeScript
  • function(x){return 2*x+5} // JavaScript
  • (LAMBDA (x) (+ (* 2 x) 5)) ; Lisp
  • fn x => 2 * x + 5 (* ML *)
  • #(+ (* 2 %) 5) ; Clojure
and so on.
TL;DR It is allowed because it is informal, and yes you are expected to infer it from context. I've given some thoughts as to why some of the ambiguity might have arisen: the same reasons that people shortcut anything in communication! We can live with this in mathematical communication between people but not for programming.
ANSWER TO YOUR EDIT QUESTION:
You asked why we define functions using variables like $x$ and $y$ instead of defining them without reference to any variables. Now if your question was one of differentiating
$$f =_{def} \lambda x. \lambda y. 2x+y$$
from
$$f(x,y) =_{def} 2x+y$$
then the answer is that the second is probably easier to write. However, we can do something more interesting, as is done in the programming language Clojure: let %1 be the first argument to the function, and %2 be the second argument, and so on, and define the brackets #( and ) to wrap a function expression. Now we can write:
$$f =_{def} \#(2(\%1) +\%2)$$
and in fact we can use anonymous function expressions. That particular notation might be a but ugly, but I would encourage you to try to invent a nice notation, and change the world for the better. If it catches on, that is.
Ray Toal
  • 2,096
  • Mathematicians like greek letters allright... unfortunately, few of them are firm with lambda calculus though, and will likely interpret $\lambda x.\ 2x + 5$ as something like $\lambda \times x \times 2 \times x + 5$ (and say that this is a function of either only $x$, or both $x$ and $\lambda$. Gaaaaah...) — I personally like to use Haskell-style lambdas in mathematical expressions, i.e. $\backslash x \to 2x + 5$. That is quite readable and pretty unambiguous, though probably still few people will understand it right away. – leftaroundabout Jan 13 '15 at 12:08
    @leftaroundabout Most people will understand $x \mapsto 2,x + 5$. – Tavian Barnes Jan 13 '15 at 14:01
  • I know, the remark about not liking Greek letters was tongue-in-cheek and directed to those in the general population that don't really like math. Personally I actually do prefer a stylized arrow. But for whatever reason, they never caught on. Human history (language, society, economics, politics, sciences) is like that. No telling beforehand what communication styles will become prevalent. – Ray Toal Jan 13 '15 at 14:59
    The business about $f^n$ meaning either iterated composition or exponentiation of the function value comes about because there are two different ways to give a function space a multiplicative structure. For a ring $R$, the space $X\to R$ naturally becomes a ring with addition and multiplication defined pointwise, and it would be very inconvenient to deny the usual ring notation for those operations, including $\sin^2$. On the other hand, the functions $X\to X$ form a monoid under composition that is often written multiplicatively. ... – hmakholm left over Monica Jan 13 '15 at 15:58
    ... and in particular the space of linear maps $V\to V$ for a $K$-vector space $V$ becomes a (non-commutative) $K$-algebra under pointwise addition and composition, and that also has a good claim to the usual ring notation. – hmakholm left over Monica Jan 13 '15 at 16:01
    What Henning said. Also, notation $f^n$ is just a convention (as is using $+$ sign, etc.). If in some particular area one usage is way more common than the other (which is perhaps non-existent), then it makes a lot of sense to use a different convention. For example, depending on the domain $\pi$ could mean some permutation, or a projection, or the prime-counting function or the ratio of circumference to diameter or yet something else. – dtldarek Jan 13 '15 at 17:17
  • Good to know. I had no idea that $f^n(x)$ in place of $(f(x))^n$ had any justification at all! It's not worth fighting because it was an accepted style before people starting programming, where the mindset becomes much less tolerant of ambiguity. However I don't agree that iteration is uncommon: What I love about $f^n(x)$ for iteration is that is makes the inverse notation $f^{-1}(x)$ make perfect sense! (Try it!!) Does anyone ever use that to mean $\frac{1}{f(x)}$? I don't think so! If you like consistency of notation, then the whole exponentiation of result is very discomforting! – Ray Toal Jan 14 '15 at 06:42
  • In Wolfram language you can denote an anonymous function as 2#+5&, where & ends a so called pure function and # is a shorthand for #1 - first argument (you can have #2 etc.). Seems this is what takes the least number of chars to denote an anonymous function, and looks unambiguous compared to $\lambda x.2x+5$. – Ruslan Jan 14 '15 at 10:25
  • That's pretty cute. Circled number characters U+2460 through U+2474 might also serve to keep the expression short, but it's not a general solution because there are only a finite number of them. :) – Ray Toal Jan 14 '15 at 18:31
  • @Ruslan: you call that unambiguous? There are plenty of ways this could be misread, it's certainly not self-explanatory. Perhaps 2#+5& is among the shortest ways of writing $\lambda x.\ 2x+5$. Does that mean it's among the best? I don't think so; there are very good reasons for giving parameters actual names rather than just numbers. And if you don't want to label a parameter, then it's best not to introduce it explicitly at all: point-free style. That function can be written (+5) . (*2) in Haskell, which means $(\lambda y.\ y+5) \circ (\lambda x.\ 2x)$. – leftaroundabout Jan 15 '15 at 18:35
    Both meanings of ‘$f^2$’ have their justifications, but it's mixing them that drives me crazy. If you're going to write ‘$\sin^2x$’ for $(\sin x)^2$, fine, that's very well justified, but then how can you write ‘$\sin^{-1}x$’ for anything other than $(\sin x)^{-1}$ (that is $\csc x$)? You need to use another notation, such as ‘$\operatorname{asin} x$’, for the inverse sine of $x$. (This is aside from the technicality that the sine function is not actually invertible.) – Toby Bartels Sep 23 '18 at 07:22
Most times, functions can be defined by an expression (e.g., $2x+5$), because using the expression we can guess many things about the function (like its domain, and the "rule" for getting an output given an input). The phrasing "$f(x)$" is just a generic expression.
Also, context and notation helps a lot, so if you are reading a book about vector spaces, you know that when the author says
the function $Ax+b$
he really means something like:
the function $f:E\to F,x\mapsto Ax+b$, where $E$ and $F$ are vector spaces, $b\in F$ and $A$ is a matrix.
You might even know that $E=F$, or that $E=\mathbb R^n$, or something like that. Anyway, as you can see, the first is much simpler.
As for the derivatives, you can differentiate an expression. I've never seen a formalization of this, but people do write $$\frac{d}{dx}\left\{2x^2 + 3x + 5\right\}=4x+3$$ without ever mentioning functions. So that $df(x)/dx$ is an expression, and $df/dx$ is a function $df/dx:D\to Y$, where $D$ is the set of points where $f$ is differentiable, and $Y$ is $\mathbb R$, or more generally, a space of linear operators.
EDIT: as for your added question, you can define a function without mentioning a variable ("Let $f$ be the function that takes a real number and gives the quintuple of its square"), but usually, it's easier to write "Let $f(x)=5x^2$". Also, the expression "$5x^2$" is much more familiar for most readers than writing "the quintuple of the square of a real number".
fonini
  • 2,728
I think the formalism removes ambiguity instead of increasing it as it defines the variables of the function. In essence, the notation differentiates the variables from the "constants" of the function.
More technically, the "constants" should actually be something like "variables, defined/assumed elsewhere, dependent or independent of of the dependent variable(s) of the function defined by the definition given here" while considering that the dependent/independent variables can also be functions, but I digress.
Consider this: $$ f(x) = ax \\ \frac{d}{dx}f(x) = (\frac{d}{dx}a)x + (\frac{d}{dx}x) a = 0 + 1a = a $$, where a is arbitrary constant (or a variable/function independent of x).
However, I do think there are issues with the notation, but it isn't in ambiguity as the result will (should?) remain the same regardless of how we consider the problem, rather it's in "hiding the obfuscation".
Let's consider this: $$ f(x) = ax \\ banana = x \\ \frac{d}{dx}f( banana ) = \ldots = a $$ What happens in ... of the last row?
For example, should constants actually be handled as a special class of independent functions (ie. eg. a = 9 <-> a( ) = 9 or even a( x ) = 9 + 0x) or how the banana should be handled (ie. f( banana ) = x or banana( x ) = x or ...) or...? The issue is that what goes into the ... changes, it is undoubtedly ambiguous, but the result – a – should remain the same.
In essence, there's a lot of short-handing going on in algebra. Therefore, I think the issue simply boils down to what is considered syntactic sugar rather than axiomatic expression.
There are many questions in the final version of this post, and here I'm going to try to answer them all afresh.
  1. Why do many authors call $f(x)$ the function? Why do some say that an expression such as $2x^2 + 5$ is a function?
    I interpret this question as asking how this state of affairs came about. It was not, as many people assume, through carelessness or deliberate abuse of notation/terminology (although perhaps that it how it persists), but because the meaning of the word ‘function’ (‘Funktion’, ‘fonction’, etc) has changed over time. The question at https://hsm.stackexchange.com/questions/6104/who-first-considered-the-f-in-fx-as-an-object-in-itself-and-who-decided-t by @MichaelBächtold (the question, not the answers, although they add some details) explains this history; but briefly, the original meaning of the word ‘function’ was $f(x)$, and this was established for a couple of centuries before anybody seriously considered the nature of $f$ as a thing in itself. (And when they did, they initially came up with different words for it.) This is in contrast to the synonyms ‘map’ and ‘mapping’, which have always meant $f$, and you're less likely to see $f(x)$ called by one of those terms.
    Even when people write things like ‘$f(x)$ is continuous’ or ‘$2x^2 + 5$ is continuous’, this can be made sense of, although now it is true that the terminology is being abused; it should be ‘$f(x)$ is continuous in $x$’ or ‘$f(x)$ is continuous as a function of $x$’. (In practice, this meaning is clear, but ‘$f(x,y)$ is continuous’ and ‘$2x^2 + y$ is continuous’ are genuinely ambiguous.) Similarly, ‘the derivative of $2x^2 + 5$’ is an abbreviation for ‘the derivative of $2x^2 + 5$ with respect to $x$’ (but notice that, while the derivative of $f$ is the mapping $f'$, the derivative of $f(x)$ with respect to $x$ is that mapping's value $f'(x)$).
    This is not to say that nobody who writes like this is confused or careless, only that there is long-standing precedent for this terminology, and that it can be done precisely and carefully. But if you want to use ‘function’ with its modern meaning and you want to write without abuse, then yes, the function is $f$ and not $f(x)$. (Although you can still say that $2x^2 + 5$ is a function of $x$, or that $2x^2 + 5$ is continuous in $x$, as this terminology has no other meaning. And you can also write $x \mapsto 2x^2 + 5$ if you want to discuss the function itself without giving it a name such as $f$.)
  2. If we're manipulating functions, then why must we reference an input variable $x$ in the process?
    You don't have to do this, but it's often convenient and always relevant. This is because a function (in the modern sense, that is a mapping) is determined by how it relates its inputs to its outputs. Some of the other answers have shown how you can refer to $x \mapsto 2x^2 + 5$ by high-level notation such as $2\operatorname{id}_{\mathbb{R}}^{\,2} + \operatorname{const}_5$ (although nobody else seems to have suggested quite this way of putting it), but at some point you have to define what identity functions and constant functions are and explain what it means to add and multiply functions, and at the most basic level, this is done with reference to input and output values.
    So if I want to differentiate $x \mapsto 2x^2 + 5$, then maybe I directly compute $$\Bigl(x \mapsto \lim\nolimits_0 \bigl(h \mapsto \bigl((\xi \mapsto 2\xi^2 + 5)(x + h) - (\xi \mapsto 2\xi^2 + 5)(x)\bigr)/h\bigr)\Bigr) = \Bigl(x \mapsto \lim\nolimits_0 \bigl(h \mapsto \bigl((2(x + h)^2 + 5) - (2x^2 + 5)\bigr)/h\bigr)\Bigr) = \bigl(x \mapsto \lim\nolimits_0 (h \mapsto (4hx + 2h^2)/h)\bigr) = \bigl(x \mapsto \lim\nolimits_0 (h \mapsto 4x + 2h)\bigr) = (x \mapsto 4x)$$ (notice the change of dummy variable in the first step to avoid reusing a variable name), or maybe I do a more high-level calculation $$(2\operatorname{id}_{\mathbb{R}}^{\,2} + \operatorname{const}_5)' = 2(2\operatorname{id}_{\mathbb{R}}^{\,2-1}\operatorname{const}_1) + \operatorname{const}_0 = 4\operatorname{id}_{\mathbb{R}}$$ that relies on known rules of differentiation. (Of course, the more basic calculation also relies on some rules of limits.) But when I prove these rules of differentiation, then I still need to go back to input and output values.
  3. To add to the confusion, we say that the differentiation operator $d/dx$ maps a function, $f$, to its derivative, $f′$.
    I'd say that the differentiation operator $D$ (or $'$ written postfix) maps a function $f$ to its derivative $Df$ (or $f'$). In contrast, $d/dx$ maps the quantity $f(x)$ to the quantity $f'(x)$; in particular, it maps the quantity $2x^2 + 5$ to the quantity $4x$. If you want to formalize what these ‘quantities’ are, then see the question https://mathoverflow.net/questions/307947/formalizations-of-the-idea-that-something-is-a-function-of-something-else by Michael Bächtold (and the answers by Terry Tao and Mike Shulman, especially the first two paragraphs of Mike's answer); but if you don't want to go down that route, then you can interpret $(d/dx)(2x^2 + 5)$ or $d(2x^2+5)/dx$ as notation for $(\xi \mapsto 2\xi^2 + 5)'(x)$ (which again has a change of dummy variable to avoid a clash). Note that in this case, $(d/dx)\bigl(f(x)\bigr) = \bigl(\xi \mapsto f(\xi)\bigr)'(x) = f'(x)$ as expected. In any case, to avoid ambiguity, you can't apply $'$ to $2x^2 + 5$ (although you can apply it to $x \mapsto 2x^2 + 5$) or apply $d/dx$ to $f$ (although you can apply it to $f(x)$). People who write ‘$(2x^2 + 5)' = 4x$’ or ‘$df/dx = f'(x)$’ are being sloppy, although they can get away with it under certain default assumptions (such as that $x$ is the default variable). This is essentially the same issue as saying ‘$2x^2 + 5$ is continuous’ instead of ‘$2x^2 + 5$ is continuous in $x$’ or ‘$x \mapsto 2x^2 + 5$ is continuous’; in particular, it gets more ambiguous when you have more variables.
Toby Bartels
  • 4,679
