I think this is correct:
If $\phi:\mathbb Z^{n}\to\mathbb Z^{k}$ is a group homomorphism then $n=\operatorname{rank}\operatorname{im}\phi+\operatorname{rank}\ker\phi$.
Here is my attempt at a proof:
$\phi$ may be naturally and uniquely extended to a linear map between $\mathbb Q$-vector spaces $\widetilde{\phi}:\mathbb Q^{n}\to\mathbb Q^{k}$, where $n=\dim\operatorname{im}\widetilde{\phi}+\dim\ker\widetilde{\phi}$.
My questions:
  1. Is this proof correct? I am concerned with "rank" either not making sense for subgroups or not coinciding with "dimension".
  2. Does this appear in books (maybe with different formulation)? I have not found it in some standard textbooks I've looked in.
No need to refer to $\mathbb Q$: we have the following short exact sequence of free $\mathbb Z$-modules (or abelian groups, if you like it) $$0\to\ker\phi\to\mathbb Z^n\to\operatorname{im}\phi\to0$$ which is split (helpful, but not necessary to conclude).
user26857
  • 52,094
  • Is it correct that this short exact sequence is simply a formulation of the first isomorphism theorem? How does the rank equation follow from this short exact sequence? – Yoni Rozenshein Jan 08 '15 at 20:58
  • Yes. 2. If you know what means "split", then $\mathbb Z^n=\ker\phi\oplus\operatorname{im}\phi$ shows that $\mathbb Z^n$ has a basis resulting from the bases of $\ker\phi$ and $\operatorname{im}\phi$.
  • – user26857 Jan 08 '15 at 21:01
  • I didn't know, but now I read about it. So as I understand: This sequence trivially left-splits; We use the splitting lemma to conclude $\mathbb Z^n = \ker \phi \oplus \operatorname{im} \phi$; and then we trivially get the union of bases as we wanted. So, the heart of the proof is in the proof of the splitting lemma. Right? – Yoni Rozenshein Jan 08 '15 at 21:08
  • @YoniRozenshein Yes. (This is because I don't want to refer to $\mathbb Q$, otherwise we can extend the maps to $\mathbb Q$-vector spaces with or without splitting.) – user26857 Jan 08 '15 at 21:11
