13
Assume all spaces are Hausdorff.
Definitions:
$X$ is totally disconnected if the only nonempty connected subsets of $X$ are singletons.
$X$ is zero dimensional if it has a base of clopen sets.
Now consider the following:
A) $X$ is zero dimensional,
B) for any $p\neq q\in X$ there exists a clopen set containing $p$ missing $q$ (the quasicomponents of $X$ are singletons),
C) $X$ is totally disconnected (the components of $X$ are singletons)
It is clear to me that $A\Rightarrow B\Rightarrow C$, and I know that $A$ and $C$ are not equivalent.
Question: Is $B$ equivalent to either $A$ or $C$ ? I think that $B\Leftrightarrow C$ if $X$ is compact since in this case quasicomponents are connected, but I'm not sure in general.
Edit: I am really interested in knowing if $B$ is strictly weaker than $A$, even for normal spaces.
  • Property (B) is called totally separated in Steen & Seebach. Note that (A) zero dimensional implies (B) totally separated only for $T_0$ spaces. For example, a space with the indiscrete topology is zero-dimensional, but not totally separated (since not even $T_1$). – PatrickR Sep 06 '21 at 03:32
No two of the three properties are equivalent for Hausdorff spaces in general. In this answer Martin Sleziak gives a proof that the Erdős space $\ell^2\cap\Bbb Q^\omega$, the space of square-summable sequence of rational numbers, has (B) but not (A). The space obtained by removing the dispersion point $p=\left\langle\frac12,\frac12\right\rangle$ from the Knaster-Kuratowski fan has (C) but not (B): its quasicomponents are the segments $L_c\setminus\{p\}$ for $c\in C$, the middle-thirds Cantor set.
Brian M. Scott
  • 616,228
