Why does not $ \int_{b}^{a} 2\pi \,f(x) \,dx $ yield the correct answer when calculating the surface area of a solid of revolution?
1http://tutorial.math.lamar.edu/Classes/CalcII/SurfaceArea.aspx – Bruno Joyal Dec 19 '14 at 22:07
Somewhat related: http://math.stackexchange.com/questions/12906/is-value-of-pi-4 – Hans Lundmark Dec 19 '14 at 22:30
Because the 'infinitesimal' line element which you are rotating about a circle of circumference $2\pi f(x)$ doesn't have length $dx$; rather the length is $\sqrt{1 + f'(x)^2} \ dx$, which is always longer for any $x$ for which $f'(x) \neq 0$.
For a cylinder where $f(x)$ is a constant, then $f'(x) = 0$ and your proposed expression does work.
- 26,524
Forgive me if this is a silly question, but why can I use dx when calculating the volume of a solid of revolution? Why is it different in this case? – user1904218 Dec 19 '14 at 22:04
Because in the volume calculation you are adding up 'discs' of cross-sectional area $\pi f(x)^2$ and width $dx$. There no sort of adjustment is required. – Simon S Dec 19 '14 at 22:06
1It's worth going back to the Riemann sums in both cases to make sure you understand how the SA and volume integrals are constructed. – Simon S Dec 19 '14 at 22:07
For a thin slice surface area of a cone = $ 2 \pi \,f(x) \,ds $ which you should integrate.
If it is a flat disc of height tending to zero there would be a big error without multiplying by $ \sec \phi $ due to slope.
$ \int_{b}^{a} 2\pi \,f(x) \,dx $ yields correct answer only when calculating the surface area of a cylinder, zero slope, constant radius $ a = f(x) $.
No area is represented by $ \int_{b}^{a} 2\pi \,f(x) \,dx,$ for variable $ f(x). $
- 40,495
