Can't quite finish this proof:
Prove that if $x$ and $y$ are not both $0$ then $ x^2 +xy +y^2> 0$
$ x^2 +xy +y^2 +xy -xy> 0$
$ (x +y)^2 -xy> 0$ Without loss of generality define $x\geq y$
Firstly the case where $y<0$ and $x>0$ is trivial as both $ (x +y)^2$ and $-(xy) >0$.
I want to say by transitivity as each are >0 that there sum must be ${}> 0$ can I do that?
The second trivial case is $y=0$ as we simply have $ x^2 >0 $ where $x>0$.
Lastly we have define $c= x+y$ since both $x$ and $y$ must have the same sign we know $|c|>x$ since $x\geq y$ we know that $ x^2 \geq xy$ finally since $ |c|^2 = c^2$ $ \forall c \in \mathbb{R} $
We have $ c^2 >x^2 \geq xy$ hence $c^2 -xy >0$
I feel like I have all the pieces but it doesn't feel finished how do I fix it?
Edit: I am really glad i asked this question love the variety of different good answers no idea what a discriminant is but im going to go look that up. I wanted to give the accepted answer to Edward as he actually answered my question but Anurag s proof was just so much better then my attempt. ^^
Chris Culter
  • 26,806
Faust
  • 5,669
7 Answers7
19
Consider $T=x^2+xy+y^2$. then $2T=x^2+y^2+(x+y)^2 \geq 0$. The only way $T=0$ is when $x=0,y=0$, but that has already been ruled out by the conditions given.
Anurag A
  • 41,067
Here's another way:
If $x=y$, then obvious. Otherwise: $$x^2+xy+y^2=\frac{x^3-y^3}{x-y}>0$$ as $f(x)=x^3$ is monotonically increasing.
Saibal
  • 1,597
You can simply note that $$ x^2+xy+y^2=(x+y/2)^2+3y^2/4\geq 0. $$ Equality is iff $x=y=0$. So if $x,y$ are not both $0$, then $x^2+xy+y^2>0$.
Kim Jong Un
  • 14,794
  • 24
  • 49
Let $y$ a fixed non zero real. The discriminant of the quadratic expression $x^2+xy+y^2$ is $\Delta=y^2-4y^2=-3y^2< 0$ hence the expression doesn't change the sign and we have $$x^2+xy+y^2>0$$
Your proof is correct. The first two cases are obvious. The third case follows directly from the AM-GM inequality:
$$\frac{x+y}{2}\ge \sqrt{xy}$$ $$\Rightarrow x+y>\sqrt{xy}$$
Edward Jiang
  • 3,670
We only need to consider 2 cases:-
(1) Both x and y are negative
Then, $x^2 + xy + y^2 = (x – y)^2 + 3xy = (+ve) + (+ve) > 0$
(2) Only one is negative
Then, $x^2 + xy + y^2 = (x + y)^2 - xy = (+ve) – (-ve) > 0$
Mick
  • 17,141
Switching to polar coordinates ($x=r\cos \theta,y=r \sin \theta)$, we need to prove $$1+\frac{1}{2} \sin 2 \theta>0, $$ which is obvious.
user1337
  • 24,381
