I am trying to show the following is a commutative ring with unity, however I am encountering a problem.
First, addition and multiplication are defined as:
$$a \oplus b=a+b-1$$$$a \odot b=ab-(a+b)+2$$
I have shown this "addition" is an abelian group. The identity is $1$ and the negative is $2-a$. Now, I am stuck on distributivity. I found that:
$$a \odot(b \oplus c)$$ $$= a \odot (b+c-1)$$ $$=(a\odot b) + (a \odot c) - (a \odot 1)$$ $$=ab-(a+b)+2+ac-(a+c)+2-(a1-(a+1)+2)$$ $$=ab-a-b+2+ac-a-c+2-a+a+1-2$$ $$=ab+ac-2a-b-c+3$$
Why is this not equal to: $$= a \odot (b+c+(-1))$$ $$=(a\odot b) + (a \odot c) + (a \odot (-1))$$ $$=ab-(a+b)+2+ac-(a+c)+2+a(-1)-(a+(-1))+2)$$ $$=ab-a-b+2+ac-a-c+2-a-a+1+2$$ $$=ab+ac-4a-b-c+7$$
However, the first equation is equal to $$(a \odot b) \oplus (a \odot c)$$ $$=(ab-(a+b)+2) \oplus (ac-(a+c)+2)$$ $$=ab-(a+b)+2+ac-(a+c)+2-1$$ $$=ab-a-b+2+ac-a-c+2-1$$ $$=ab+ac-2a-b-c+3$$
So, why is the first equation not equal to the second, but equal to the third? Which one is correct?
user5826
  • 11,982
Note that $(a+1)\oplus (b+1)=(a+b)+1$: This makes us suspicious and we compute $$\begin{align}(a+1)\odot(b+1)&=(a+1)(b+1)-(a+1)-(b+1)+2\\ &=ab+1.\end{align}$$ We conclude that $x\mapsto x+1$ maps the commutattive ring with unity $(\mathbb Z,+,\cdot)$ to the structure $(\mathbb Z,\oplus,\odot)$, which is therefore also a commutative ring with unity. (And we conclude that $0+1=1$ is its additive neutral and that $1+1=2$ is its unity.
We want to show that $\odot$ distributes over $\oplus$. However, we can NOT assume that $\odot$ distributes over $+$.
For the first part, we have: \begin{align*} a \odot(b \oplus c) &= a \odot (b + c - 1) \\ &= (a)(b + c - 1) - ((a) + (b + c - 1)) + 2 \\ &= (ab + ac - a) - (a + b + c - 1) + 2 \\ &= ab + ac - 2a - b - c + 3 \\ \end{align*} For the last part, we have: \begin{align*} (a \odot b) \oplus (a \odot c) &= (ab - (a + b) + 2) \oplus (ac - (a + c) + 2) \\ &= (ab - (a + b) + 2) + (ac - (a + c) + 2) - 1 \\ &= ab + ac - 2a - b - c + 3 \\ \end{align*} which matches.
Adriano
  • 41,576
I'm assuming the domain is $\mathbb Z$, but the same argument would work for $\mathbb Q$, $\mathbb R$, or really any ring.
In general, if $f:X\to\mathbb Z$ is $1-1$ and onto, we can define operators on $X$:
$$x\oplus y = f^{-1}(f(x)+f(y))$$ $$x\odot y = f^{-1}(f(x)\cdot f(y))$$
In these cases, the additive identity is $f^{-1}(0)$.
In your case above,this $X=\mathbb Z$ and $f(x)=x-1$, $f^{-1}(n)=n+1$.
Now, with these definitions:
$$\begin{align} x\odot(y\oplus z) &= x\odot f^{-1}(f(y)+f(z))\\ &= f^{-1}\left(f(x)\cdot(f(y)+f(z))\right)\\ &= f^{-1}(f(x)f(y)+f(x)f(z))\\ &= f^{-1}(f(x\odot y) + f(x\odot z))\\ &=(x\odot y)+(x\odot z) \end{align}$$
Thomas Andrews
  • 177,126
  • See also the appendix of http://math.stackexchange.com/questions/1001186/which-associative-and-commutative-operations-are-defined-for-any-commutative-rin – Thomas Klimpel Nov 29 '14 at 01:45
  • @Thomas Andrews: Woah. This seemed pretty advanced. Where can I learn more about this method? I am only in a introductory algebraic structures course. – user5826 Nov 29 '14 at 18:49
  • It's probably not worth studying further, as it is essentially "trivial," although filled with a lot of notation. Just keep studying and come back to it later. – Thomas Andrews Nov 30 '14 at 02:47
