16
Consider the ring of polynomials $\mathbb{k} [x_1, x_2, \ldots , x_n]$ as a module over the ring of symmetric polynomials $\Lambda_{\mathbb{k}}$. Is $\mathbb{k} [x_1, x_2, \ldots , x_n]$ a free $\Lambda_{\mathbb{k}}$-module? Can you write down "good" generators explicitly? (I think that it has to be something very classical in representation theory).
Comment: My initial question was whether this module flat. But since all flat Noetherian modules over polynomial ring are free (correct me if it is wrong), it is the same question.
There is much more general question, which seems unlikely to have good answer. Let $G$ be a finite group and $V$ finite dimensional representation of G. Consider projection $p: V \rightarrow V/G$. When is $p$ flat?
user26857
  • 52,094
quinque
  • 2,632
Let $s_i= \sum x_1 \ldots x_i$ be the fundamental symmetric polynomials. We have a sequence of free extensions $$k[s_1, \ldots, s_n] \subset k[s_1, \ldots, s_n][x_1]\subset k[s_1, \ldots, s_n][x_1][x_2] \subset \cdots \\ \subset k[s_1,\ldots ,s_n] [x_1] \ldots [x_n] = k[x_1, \ldots ,x_n]$$ of degrees $n$, $n-1$, $\ldots$ ,$1$. At step $i$ the generators are $1, x_i, \ldots, x_i^{n-i}$. Therefore $$k[s_1, \ldots, s_n] \subset k[x_1, \ldots, x_n]$$ is free of degree $n!$ with generators $x_1^{a_1} x_2^{a_2} \cdots x_n^{a_n}$ with $0 \le a_i \le n-i$.
More generally for a finite reflection group of transformations $G$ acting on a vector space $V$ over a field $k$ of characteristic $0$ (to be safe) the algebra of invariants $k[V]^G$ is a polynomial algebra and $k[V]$ is a free $k[V]^G$ module of rank $|G|$ --see the answer of @stephen: .
orangeskid
  • 53,909
    I think some more details are in order: why $1,x_1,\dots,x_1^{n-1}$ is a basis of the first ring extension? – user26857 Nov 03 '14 at 19:41
  • @user26857: $x_1$ satisfies an equation of degree $n$ over $k[s_1, \ldots, s_n]$. It does not satisfy any equation of degree $<n$ over $k(s_1, \ldots, s_n)$ so $1, x_1,\ldots, x_1^{n-1}$ are linearly independent over $k(s_1, \ldots, s_n)$. – orangeskid Nov 03 '14 at 19:48
    And why don't satisfy any equation of degree $<n$? – user26857 Nov 03 '14 at 19:50
    @user26857: Another useful observation using just basic Galois theory is : $k(s_1, \ldots, s_n) \subset k(x_1, \ldots, x_n)$ is Galois with group $S_n$. – orangeskid Nov 03 '14 at 19:57
    Great answer! Just a remark: The basis orangeskid describes is different from the Schubert basis - geometrically, the images of the $x_i$ in the integral cohomology of the flag variety are the Chern classes of the $n$ tautological line bundles (and the iterated computation above has a geometric counteprart, by viewing the flat variety as an iterated projective bundle and using Leray-Hirsch at each step), while as I said above the Schubert polynomials correspond to Bruhat cells. – Hanno Nov 03 '14 at 20:02
  • @26857: Oops, one reason that the "generic polynomial of degree $n$ " $t^n + s_1 t^{n-1} + \ldots s_n$ is irreducible over $k[s_1, \ldots , s_n]$. If it were reducible then it would have a decomposition in $F[s_1, \ldots s_n]$ where $F$ is a finite extension of $\mathbb{Q}$. Now specialize $s_i$ into $F$ to get an irreducible polynomial over $F$ and get a contradiction. – orangeskid Nov 03 '14 at 20:12
    Regarding your last paragraph, it can certainly happen that in characteristic $p$ the ring of invariants is not polynomial even when the group is generated by reflection; on the other hand polynomials invariants is enough to imply that the group is generated by reflections in any characteristic. – Stephen Nov 03 '14 at 20:34
  • @Stephen: Glad you corrected me on that. Perhaps a small characteristic issue? Certainly no problem for $S_n$. Any quick counterexample? – orangeskid Nov 03 '14 at 20:50
  • Sure, see for instance Haruhisa Nakajima's paper here https://projecteuclid.org/download/pdf_1/euclid.pja/1195517251 – Stephen Nov 04 '14 at 12:45
  • @Stephen: Oh, it is $S_n$, with a sub and/or quotient of the standard representation, small char, thx. – orangeskid Nov 04 '14 at 18:04
    @user26857 Set $L := k(s_{1},\dotsc,s_{n})$; suppose there exists $f \in L[T]$ of degree at most $n-1$ having $x_{1}$ as a root; then $x_{2},\dotsc,x_{n}$ are also roots of $f$ (since $0$ is preserved by the $S_{n}$-action on $k(x_{1},\dotsc,x_{n})$), so $f = 0$. – Minseon Shin Mar 14 '16 at 21:57
    This is not a complete answer. The degrees of the free extensions (and their freeness) are far from obvious. – darij grinberg Sep 22 '21 at 19:54
13
Yes, that's indeed a classical result of representation theory: ${\mathbb Z}[x_1,...,x_n]$ is graded free over ${\Lambda}_n$ of rank $n!$ (the graded rank is the quantum factorial $[n]_q!$), and a basis is given by Schubert polynomials defined in terms of divided difference operators.
See for example the original article of Demazure, in particular Theorem 6.2.
Passing to the quotient, one obtains the graded ring ${\mathbb Z}[x_1,...,x_n]/\langle\Lambda_n^+\rangle$ which is isomorphic to the integral cohomology ring of the flag variety of ${\mathbb C}^n$, and the ${\mathbb Z}$-basis of Schubert polynomials coincides with the basis of fundamental classes of Bruhat cells in the flag variety. This is explained in Fulton's book 'Young Tableaux', Section 10.4.
Hanno
  • 19,510
The answer by @orangeskid (+1) is the most classical and direct, and the answer by @Hanno connects your question to Schubert calculus and the geometry of flag varieties (+1). Hoping this isn't too self-promoting, you might also have a look at my paper Jack polynomials and the coinvariant ring of $G(r,p,n)$ (I worked in somewhat more generality)
Stephen Griffeth, Jack polynomials and the coinvariant ring of $G(r,p,n)$
where I showed that certain non-symmetric Jack polynomials give a basis as well (I was working with more general reflection groups and over the complex numbers, but a version should work over any field of characteristic $0$; I have not thought much about this in characteristic $p$). The point of my paper was really to connect the descent bases (yet another basis!) studied much earlier by Adriano Garsia and Dennis Stanton in the paper Group actions of Stanley-Reisner rings and invariants of permutation groups
Garsia, A. M. (1-UCSD); Stanton, D. (1-UCSD), Group actions of Stanley-Reisner rings and invariants of permutation groups (article)
to the representation theoretic structure of the coinvariant algebra as an irreducible module for the rational Cherednik algebra. Of course this structure becomes much more complicated in characteristic smaller than $n$; in particular the coinvariant algebra will in general not be irreducible as a module for the Cherednik algebra.
Towards your second question: by definition $p$ is flat if and only if $k[V]$ is a flat $k[V]^G$-module. This certainly holds if $k[V]$ is free over $k[V]^G$; a sufficient condition for this is given in Bourbaki, Theorem 1 of section 2 of Chapter 5 of Lie Groups and Lie algebras (page 110): in case the characteristic of $k$ does not divide the order of $G$, it suffices that $G$ be generated by reflections. This is false (in general) in characteristic dividing the order of the group. But see the paper Extending the coinvariant theorems of Chevalley, Shephard-Todd, Mitchell, and Springer by Broer, Reiner, Smith, and Webb available for instance on Peter Webb's homepage here
http://www.math.umn.edu/~webb/Publications/
for references and what can be said in this generality (this is an active area of research so you shouldn't expect to find a clean answer to your question).
Conversely, assuming $p$ is flat and examining the proof of the above theorem in Bourbaki, it follows that $k[V]$ is a free $k[V]^G$-module. Now Remark 2 to Theorem 4 (page 120) shows that $G$ is generated by reflections. So to sum up: if $p$ is flat then $G$ is generated by reflections; in characteristic not dividing the order of $G$ the converse holds.
Stephen
  • 14,811
  • MO level, neat. +1! – orangeskid Nov 03 '14 at 20:00
  • I have a problem about your links. Article by Webb and others is just about connected topics. They do not answer my question (or I just do not see it, then please explain). About Bourbaki book I have a deeper trouble. It sounds silly but I even can not find what is called theorem 1 in this section. Could you post here what it is about (proof is not necessary). – quinque Nov 03 '14 at 23:32
  • @user167762, The statement is Theorem 1 on page 110 of my English edition---are you able to locate it now? I referenced the paper of of BRSW not because it answers your question, but because it is the most recent thing I can think of that deals with the subject in detail and I thought the references it contained might prove useful for you or other future readers. I will edit my answer a bit to give an indication of what I believe to be the state of the art. As far as I know, in positive characteristic there is no clean characterization of groups such that the projection is flat. – Stephen Nov 04 '14 at 12:26
Another perspective:
The ring extension $S=k[s_1,\dots,s_n]\subset k[x_1,\dots,x_n]=R$ is finite, and since $R$ is Cohen-Macaulay it is free of rank say $m$. We thus have a Hironaka decomposition $R=\bigoplus_{i=1}^m S\eta_i$ for some homogeneous $\eta_i\in R$. Using this the Hilbert series of $R$ is $$H_R(t)=\sum_{i=1}^mH_S(t)t^{\deg\eta_i}=\sum_{i=1}^mt^{\deg\eta_i}/\prod_{i=1}^n(1-t^i).$$ On the other side, $H_R(t)=1/(1-t)^n$ and therefore $\sum_{i=1}^mt^{\deg\eta_i}=\prod_{i=1}^{n-1}(1+t+\cdots+t^i)$ which for $t=1$ gives $m=n!$.
user26857
  • 52,094
