15
Usually the problem with earphones is that you don't know which goes to which ear. Of course there are some small markings (such as L or R), but who wants to read those every time when you want to use them (especially in some dark places).
Which method usually do you use to keep the track which one is which?
kenorb
  • 4,462
  • 33
  • 65
    I find, in particular with Apple headphones, the volume control / microphone on the cable do a pretty good job (once you know which side it is on it is not hard to remember) in my case it is the right headphone so I always know to put that in my right ear. – MrPhooky Jan 23 '15 at 13:35
    Sometimes, once you put the wrong earphone in your ear it will feel different. It does for me, it normally wont stay in. Then I just automatically switch ears. – LOSTinNEWYORK Sep 24 '15 at 00:10
7 Answers7
15
In lighted situations: Wrap electrical tape around the base of the earbud and the wire, using a different color for each side. I would suggest red for right just for the mnemonic device. Taping is good practice, anyway, unless your wires are fabric-wrapped.
In dark situations: Put a drop of high-temperature glue - super glue is probably OK - on the outside stem or shell of one of the earbuds and let it dry completely. You'll be able to feel the bump with your fingertip.
Engineer Toast
  • 1,555
A dot of red fingernail polish on the right earbud. Red and Right begin with the same letter.
dwilbank
  • 440
You can make a simple knot on one of the earphone cable, so from know you'll always know which headphone is the left one, even without looking.
How I always know which headphone is the left one, even without looking
Alex
  • 3,979
  • 25
  • 45
kenorb
  • 4,462
  • 33
  • 65
Wrap some tape around one of the cables. Make it thick enough to feel or make a tab.
Adam Zuckerman
  • 4,328
  • 32
Most earphones have a long and short cable. You could remember which way you wear them.
I know that my Sennheiser earphones are short on the left side and long on the right side. I always put them on in the same way, the long wire goes behind my neck towards my right ear, whilst the left side can easily be inserted.
CustomX
  • 293
  • I have been going crazy looking for a set of J cord earbuds! (I listen to music while I work and I like to leave one earbud out sometimes and J cord means it's sits behind my neck instead of hanging in my lap!) Are all Sennheiser earbuds J cord style? Can you recommend a model number? – ErinGoBragh Sep 23 '15 at 14:28
  • Not quite sure if all Senheisers are like that. My earbuds are 8 years old, so wouldn't know what to reccomend :P – CustomX Sep 23 '15 at 14:50
  • Thanks, I had a Sony pair for years and they broke recently and I'm having a heck of a time replacing them. Right now I'm using the Y cord ones that came with my phone but I still have not gotten used to taking them out to talk to someone and having them fall to the floor. I'll check Sennheiser out, good to know they last! – ErinGoBragh Sep 23 '15 at 14:55
Hi I am using Samsung earphones and on the left earphone, there is a dot which can befelt in dark. Also for Left earphone L is not carved in its carved out, which can be felt in dark along with a dot just below that. Guess this solves the purpose.
user24962
My solutions
In light: I took a permanent marker and covered the right earbud with one color (blue) and the left with another (red). If you have earbuds with colors other than white, wrap paper and tape it around each earbud cable and then do the coloring.
In dark: I took some tape and made a little "flag" on the right earbud.
Trooper Z
  • 159
