Is there a simple (by simple, I mean a hobby friendly method that trades some accuracy for expense) method of measuring the "actual" output impedance of an active or "hot" RF (HF to VHF) circuit?
As an amateur radio enthusiast, I often find myself in a situation where I'd like to measure the actual output impedance of some amplifier or oscillator (type of amplifier). Right now, I have an oscillator operating in the low VHF region and I'd like to match its output to a mixer that has a well defined input impedance. But that's just one example, I've had plenty others in the past. I can calculate the output impedance theoretically, but it would be nice to confirm the theory with a practical measurement.
I have some hobby or entry grade tools to hand, including an oscilloscope and a NanoVNA. Is there a reasonably accurate measurement method using these tools? One that doesn't damage the measurement device (especially the VNA).
One I read somewhere that made some kind of sense was to match the output with a (passive) device that varied the resistance, inductance and capacitance (a type of complex load). You could use a power meter to find the match point. Then measure the input impedance of the device/load with a VNA and use the conjugate as the output impedance.
Sounds simple enough, but I'm guessing the devil is in the construction of the complex load. What other methods are there?
UPDATE: Since asking this on EE SE, I've solved my immediate problem by using the two measurement technique (wonderfully explained in this video by W2AEW). However, I believe this approach becomes less accurate at RF frequencies and I have a continuing interest in discovering a practical, simple and inexpensive solution - if it exists!?
Buck8pe
  • 989
According to Microwaves101, the "load pull" technique may fulfill your need:
Load pull involves varying the load impedance presented to a device under test and monitoring a single or set of performance parameters. When used in conjunction with a signal source and signal analyzer (spectrum analyzer, power meter, vector receiver…), load pull can be used to measure parameters such as output power, gain, and efficiency as a function of load impedance presented to the DUT.
Relying on the maximum power theorem, the load will see maximum power when it represents a "conjugate match" to the source. Matching the output of your circuit to a known load value using an SWR meter would allow you to "back out" the impedance of the generator. At UHF and above, the lumped matching network you would use at HF and, probably, VHF is replaced by a transmission-line based "microwave impedance tuner."
Brian K1LI
  • 7,838
  • 33
  • That sounds promising. Could you expand a little on "Matching the output of your circuit to a known load value using an SWR meter would allow you to "back out" the impedance of the generator" Thanks! – Buck8pe Jun 20 '20 at 07:23
  • Actually, this is a great answer because those links name a key component that I knew must exist (see my original question), that is the impedance tuner. If you had the tuner you could envisage a cheap(ish) system involving a power meter (https://ham.stackexchange.com/questions/16311/how-to-make-an-rf-probe-for-accurate-power-measurement-at-qrp-power-levels) to find the match point. With sensitive power meters and higher powers you would need to tap a fraction of the DUT output so as not to destroy the meter. Thoughts? – Buck8pe Jun 20 '20 at 08:32
  • At HF and VHF, a simple matching network, like an L-, $\pi$, or T-section might effect the match, as indicated on an SWR meter. Then, using a spreadsheet or Smith chart program (e.g., SimSmith), the impedance looking into the matching network is easily calculated. The source impedance is the complex conjugate of this value; i.e., same (series) resistance and opposite (series) reactance. – Brian K1LI Jun 20 '20 at 08:58
  • Since the power into a resistive load is proportional to the square of the voltage across it, an oscilloscope might be the simplest way to evaluate the match. – Brian K1LI Jun 20 '20 at 09:05
