Is there some simple utility, or published set of charts, or suite of formulae, where one can approach the situation by inputting a space weather summary, (sunspots, various indexes, etc), the receive frequency (band), half power beam width and gain of antenna, and arc distance from max gain main lobe vector to the sun disk (using the az el of the rotators), where the noise floor will rise enough to make signal detection unlikely, everything else being equal? Yes, that might be too broad a brush. Please educate my ignorance.
Stated differently: If I am working a satellite or the ISS digipeater with a two meter beam or helical, and the sun is up, and the satellite (ISS) pass comes close to or even transits the sun disk, then at what arc distance to the sun (center?) will the sun likely cause enough RFI to black out the attempted communication with the satellite (ISS), on two meter, 70 cm, 23 cm bands? I understand it will depend on the main lobe of the antenna, and its half power beam width? Let's use as an example, the average 3 element yagi maximized for gain, such that it gives about a 40 degree half power beam width... if those numbers are unrealistic, still, you get the idea of what I am looking for, yes? I'd like an announced expectation of a sun causes comm black out. It already says 'eye protection' when the antenna is pointed within 45 degrees arc distance of the sun. Why? When portable, or in power conserving situations, the rotator(s) might be strong-arm, aligning with a big plywood compass (az) rose on the ground, and an elevation scale, while looking somewhat along the antenna. With az and el announcements every four seconds, strong-arm alignment should be plenty good enough. People are making contacts with less accuracy than that, roadside, on youtube.
I'm thinking there must be some utilities already out there without my re-inventing the wheel, for the sun related noise floor increases. Hopefully source code available, opensource, so I can write them into my python script(s), honoring any licensing terms and conditions of course.
My Antenna handbook is from 1988, and I figure there is a lot more data and experimentation since then, particularly in this context.
I've got a python program using pyephem, that runs continuous, and gives periodic voice announcements of the status of upcoming passes and 'in progress' passes, grabbing TLE updates each day, internet connection dependent at least once per week. It runs on a raspberry pi or an android device (since pyephem is easily installed on either of them). I would like it to also give a caution regarding possible noise floor related black out(s) when the pass is closely aligned with the sun (risen of course). For that, I need this additional RFI noise floor based on the sun/space-weather information, so it can be appropriately coded.
Maybe the EME folks have already worked something like this out? The geostationary commercial bird operators know when there is a higher probability for a blackout, briefly, twice per year, when the orbital position basically transits the sun for certain geographic regions. I am looking to know if for the HAM sats, this would only happen if there is a literal transit, or if it develops into happening as the main lobe of the receive antenna gets within a certain threshold arc distance of the sun.
Comments please if you need more clarification.
Update 2-23-2020:
I have selected the post from tomnexus as the answer, but I wish to be clear. Phil Frost - W8II 's post was just as valuable as the answer. As is often the case here, there is not always a best answer, but instead, several postings that form the more complete answer for which an OP was hoping. Some of the comments and comment exchanges were also essential toward an answer that would give me what I need to form a project decision. If you can, imagine that both these posts have been selected as the answer. If there are more posts that I miss later on, I trust they will be in some way helpful to someone with a similar question(s). Thank you to all the contributors.
always_learning
  • 247
    Hello, and welcome to ham.stackexchange.com! Thanks for a nice first question, and we look forward to seeing more of you here. :-) Please consider reading the tour and help pages to get the most from this site. – Mike Waters Jan 25 '20 at 19:43
  • It's good to be always learning. We are, too! :-) IMHO, your 2/23 update would be better if you moved it to a comment, as it's not really part of the question. And since comments have a character limit, sometimes it's necessary to use two comments. Commenting guidelines – Mike Waters Feb 23 '20 at 18:56
It depends on the gain of your receive antenna, your system noise temperature, and how much link margin you had in the first place.
The moonbounce (EME) community use Sun Noise as a measure of their system performance, so the sun is certainly detectable by a modest amateur station.
A quick Google search for "sun noise EME 144" yields this interesting result from SM7SJR: 2m noise measurement: 2 x 15 el LFA. Stacked vertically. LNA 0,36dB NF. Aimed at the sun: 5,3dB sun noise.
So with this fairly large station with a very good preamp, the noise floor rises 5 dB when pointed at the sun. Can your link budget afford this much additional noise?
If you have no LNA or say one 5-element yagi (6 dB less gain, 10+ dB more system noise) then the sun will only contribute <<1 dB of noise, not enough to worry about. If you have both a small antenna and no fancy pre-amp then you definitely won't be able to detect sun noise. If you can hear the satellite at night, you'll be able to hear it in the day even as it transits the sun.
For detailed, more general predictions, you can look up measurements of the solar flux at your frequency - it depends on the sunspot number. Then with the rest of the system parameters - gain (pattern), noise temperature - you can predict the rise in noise due to the sun in the beam. The sun raises the system temperature depending simply on the pattern of the receive antenna.
There are several EME system calculator programs which can predict sun noise for a particular system. The first many results for "eme calculator sun noise" look useful.
tomnexus
  • 11,076
    Isn't the antenna's pattern, and especially the characteristics of its main lobe, also important? To my knowledge, there is little noise radiated towards earth from outside of the sun's corona. – Mike Waters Jan 25 '20 at 18:56
    @Mike I think Gain is enough information, until the beamwidth of the antenna becomes similar in size to the sun. This takes a dish 50 wavelengths in diameter. Radio telescopes get this large, and use the moon as a calibration source, and need to compensate for its size in the beam. But for a 2 m ham station the pattern is essentially flat at maximum gain, over the whole sun. Sidelobes are important though, they pick up ground noise. This will be rolled into Tsys. – tomnexus Jan 25 '20 at 19:27
  • Fair enough, gain and beamwidth are related. I suggest that you copy your comment into your nice answer. – Mike Waters Jan 25 '20 at 19:38
    So then, for the videos of those hams working the ISS from a roadside, with a 3, 4, or 5 element relatively short handheld beam, they might have ~1 db of noise from the sun, and because of the wide main lobe of such an antenna, it could be out to 40 or 50 arc degrees from the sun position (ignoring terrestial noise for now). And at 2 meters, IOW, since the antenna is no where near 50 wl across, that ~1 db is not unique to when aimed directly at the sun, but is as broad an arc distance out from the sun position as is the HPBW of the antenna, ~1db of noise. Have I got that about right? – always_learning Jan 27 '20 at 13:23
  • On an SDR spectral display, therefore, one would be very hard pressed to even discern that noise, visually, when the main lobe is optimized directly at the sun disk, and far less so to be able to visually discern the change in the noise floor at the HPBW arc distance out? For my sofware then, I would need to input more about the system performance in order to properly map the solar noise max potential into the arc distance out from the sun disk, and that is beyond the concerns of the present project, but very helpful to understand for a portable antenna/radio system for 23 cm and above. Yes? – always_learning Jan 27 '20 at 13:40
  • @tomnexus, Would you perhaps edit your answer to add links to one or two of the EME resource pages? And confirm that my understanding in my previous comments does summarize the practical side for a small handheld beam at 2 meters, not just flat across the sundisk, but also out an arc distance of half of the HPBW? These comments are not always permanent, and I think it would be beneficial to your answer (more permanent on the site). It is very close to the answer as is, but I'll wait another week or two before marking it as the answer. ty, and ty also Mike Waters. – always_learning Jan 27 '20 at 13:54
    @always_learning yes the sun would affect the whole beam. But the 1 dB estimate is generous. If SM7SJR sees 5 dB with that preamp, that means the sun is 4x as loud as the system temperature. With a barefoot rig, the noise floor will be many times higher. Then you only have 3 or 4 elements, instead of 2 x 15 ele, so you're another 6 dB down. I guess the sun will be well under 1 dB, so you'd need to spend some effort to even detect it. Re the EME calculators - they're all this DOS software you download, not online calculators, so I didn't actually try them out. – tomnexus Jan 27 '20 at 18:29
  • @tomnexus -- I'll be looking at some of them this week, once I have a DOS emulator working on the raspberry pi. Ty for the link to the search results. – always_learning Jan 27 '20 at 19:24
The answer will depend on many factors. You've not given sufficient information to yield an answer, but the following concepts should help you arrive at your own answer.
Firstly you must start with a link budget. The link budget determines how much power from the transmitter will arrive at the receiver. See What is a link budget, and how do I make one?
Ultimately it's not the power received that determines whether a signal is decodable or not, but rather the signal to noise ratio. So you will want to evaluate the noise performance of your receiver(s), see How can I calculate the effects of an LNA, antenna gain, etc. on noise performance? Linked in that answer is ITU-R P.372-13 which will give you some estimation of the noise temperature of the sun, sky, and terrestrial noise in various conditions and frequencies.
You'll have to combine all these noise sources, weighted by the sensitivity of the antenna in every direction. That is, an extremely directional antenna will have a noise temperature nearly identical to just the thing it's pointed at, whereas a weakly directional antenna (like a 2 element Yagi) will pick up more noise from the sides, back, and other directions.
Finally compare the estimated signal to noise ratio with the sensitivity of the mode you'll be using, and you should have some estimation of whether communication will work or won't.
Phil Frost - W8II
  • 51,701
  • 88
  • 212
  • Some details were buried in my OP, such as the reference to those making contact on the roadside with handheld antenna. Those videos often show a simple handheld, no external LNA as far as I can see. But your points and links certainly contribute toward the most total and knowledgeable answer, making it a more difficult task for me to select which post is 'the answer'. I'm gratefully taking it all in, trusting it will help others as well. 'The answer' is shaping into, HT with short handheld yagi, it won't really matter, but.. there are details to consider beyond that roadside example.' – always_learning Jan 28 '20 at 01:41
  • @ Phil Frost - W8II - My raspberry pi project has voice announcements during a pass, for manually aiming an antenna, handheld or on a tripod. The goal of the announcements is to be practically useful, and also partly instructive for others, by the announcements it makes. The answers here are helping me conclude to have it, along with az alt, simply report the angular distance from satellite to the sun when it is less than half the HPBW. I can then further explain when and why that is useful, to interested onlookers. You answer is very helpful in forming that direction for the project. ty – always_learning Jan 28 '20 at 01:55
