I have operated at several stations - including my own - where a 40m beam is stacked above a tribander. During a rain storm, there is so much QRN on the 40m beam that the band is unusable, but the tribander seems unaffected. Conversely, a nearby tribander without a beam stacked above it is similarly useless due to QRN.
Are precipitation discharges being re-radiated out of phase from the upper antenna in the stack and cancelling the discharges in the lower antenna?
rclocher3
  • 9,192
  • 50
Brian K1LI
  • 7,838
  • 33
Among other things, rain and cloud droplets interacting with each other causes a voltage gradient in the air, similar to the Kelvin water drop experiment explained here and here), with the earth being the lowest potential and increasing with height.
The noise on the highest antenna is because there is a corona (like St. Elmo's fire) emanating from sharp points on that highest antenna -which is at ground potential- to the higher voltage gradient in the air. Therefore, eliminating or covering those sharp points or edges will reduce or eliminate the corona noise. A sharp point could be threads, the ends of metal tubing, or sharp edges. Ideally, the ends of the boom and elements would have metal spheres or insulating caps.
But there's a better way.
As W8JI points out in his page about precipitation static, there should be a sharp, grounded point above the highest antenna, like a lightning rod. Afraid that it will attract lightning? :
My physics teacher taught that if a lightning conductor actually did "conduct" a lightning strike then it would have failed in its job. Its job, he taught, was to prevent a strike from ever occurring by dissipating the charge in the atmosphere above the conductor, thereby causing the lightning to strike elsewhere. ...
It does dissipate the charge from the ground to the atmosphere. This is fact as current can be measured flowing up through the lightning rod to the atmosphere. Any current flow will reduce the potential difference between the ground and charges in the sky thus lessening the probability of a strike. This reduction in potential also will weaken any strike that does occur (not by much but it will weaken it none the less).
TL;DR: Put up a "lightning rod" above your highest antenna to eliminate the noise; that will now become your "highest antenna".
REF: https://physics.stackexchange.com/questions/65825/does-a-lightning-rod-prevent-lightning-strikes
Mike Waters
  • 7,948
  • 18
  • 51
    Are you quoting a wikipedia talk page to support your claim that a lightning rod prevents strikes? – Phil Frost - W8II Aug 21 '19 at 17:50
  • @PhilFrost-W8II Fair enough. Please see the physics.SE reference that I just added. – Mike Waters Aug 29 '19 at 19:36
  • This video offers compelling evidence of the dissipation nature of points. https://youtu.be/2sSqzLPMb4s?t=1046 – JSH Aug 29 '19 at 23:10
    Yeah...I don't think a tiny model of a house is necessarily an accurate model of the real world. – Phil Frost - W8II Aug 30 '19 at 01:59
  • @MikeWaters That physics.se source is quoting another source, which itself doesn't cite sources. Also the highest-voted answer is contrary to the accepted answer. So I don't think this is a very science-based argument... – Phil Frost - W8II Aug 30 '19 at 02:00
  • @PhilFrost There seems to be two answers on the physics.se question and both have net +9 votes. Maybe this changed since your comment? – Matt Aug 31 '19 at 04:29
  • @Matt Seems so, but in any case, "number of votes on stackexchange" is not a scientific way to make a point. – Phil Frost - W8II Aug 31 '19 at 15:11
    Actually reading it more carefully, both answers contradict the dissipation model (proposed here). "Lightning researchers are now generally convinced that the lightning dissipation theory provides an inaccurate model of how lightning rods work." and "only diversion theory seems to offer a viable lightning protection system." – Phil Frost - W8II Aug 31 '19 at 15:14
