What HF bands, times of day and/or conditions might be best for attempting to make non-local contacts using QRP transmitter power (around 1 Watt) and a small indoor folded or loop antenna?
hotpaw2
  • 13,316
  • 45
  • 76
  • Could you perhaps elaborate on what you consider to be a "non-local contact"? HF with an indoor antenna sounds like it'll be tricky no matter what you try to do because there will be so much coupling to things like concrete reinforcement, electrical wiring, etc., but the question will likely be much easier to answer constructively if you give us an idea of how far in terms of distance you want to be able to reach. – user Jan 22 '14 at 15:26
  • How small? Could you provide any specific dimensions of your folded loop antenna? Why have you chosen a folded loop over let's say a magnetic loop? – cj5 Jan 22 '14 at 19:32
The lower the frequency, the larger the antenna that is required to be resonant, so if you're aiming for something small then 10m might be best. That band is usually best during the day, and during the summer.
If you want to go with a slightly longer antenna, 15m is also good, either day or night.
As for the antenna being indoors, that could work, but usually (especially with QRP), you'll find that you get the best results with HF with the antenna outside.
user
  • 4,878
  • 60
Brian WB4ES
  • 119
  • If you want to go with a slightly longer antenna, 15m is also good, either day or night. – Brian WB4ES Jan 21 '14 at 22:02
  • Hello Brian, and welcome to Amateur Radio Stack Exchange. This site works a little differently compared to most forums that you may be used to. If you want to expand on your post, add further information, or make any other changes, please use the [edit] link below the post to do so. Comments are intended for asking for more information or requesting clarification, and should be considered ephemeral. – user Jan 22 '14 at 15:23
There is no particular band more suited to QRP operation than another. A weak signal is still weak, whatever the frequency.
It's easier to build efficient antennas on higher frequencies, since the wavelength is smaller, and antenna designs scale with wavelength. While it's always possible to electrically lengthen an antenna with loading coils, capacitive hats, etc, this makes the antenna less efficient, making poorer use of your already limited transmitter power. So, you likely want to stick to frequencies high enough where you have room for the antenna.
Being indoors is never good: it means you can't get the antenna far away from noise sources and you can't get it very high. That's always bad regardless of frequency.
Non-local contacts are possible on any of the HF bands. Which one is best depends on many factors, a large one being luck. HF propagation is significantly affected by solar activity, which follows some pattern regarding an 11 year sunspot cycle, and the obvious day/night changes, but also is highly variable based on just chance. Higher frequency bands like 10m are mostly good during the day. Lower frequency bands like 40m and down are mostly good during the night. The bands between, 30m, 20m, 15m, are somewhere between. Exceptions to these "rules" are common, based on random solar weather. It also depends on where you are trying to communicate: each frequency refracts in the atmosphere at a different angle, so a particular frequency might happen to not work because the signal skips over the intended target. The sun is moving, and so is the ionosphere, so a frequency that's good now might not be good in 5 minutes. That's just luck.
Given all this, it should be pretty clear: we can't predict what the best band will be. You can't get outdoors, you don't have space for a good antenna, and you have limited transmit power. On balance you have a poor station, and there's no way around it. Your size limitations restrict you to the higher frequencies, but on those for which you have enough room, the best band will be determined by luck.
Phil Frost - W8II
  • 51,701
  • 88
  • 212
  • I think it's pretty obvious that more transmitter power and bigger more efficient antennas will improve ones chances of distant contacts. But the question is how best to make do with much less of both. – hotpaw2 Jan 22 '14 at 23:14
  • @hotpaw2 and the answer is you can't make something out of nothing. – Phil Frost - W8II Jan 22 '14 at 23:25
  • Of course. Nothing won't work. But, IIRC, the QRP record is for over 90 dB less than the legal limit. So the amount above nothing doesn't seem to need to be very big if one chooses ones conditions carefully. – hotpaw2 Jan 22 '14 at 23:47
  • @hotpaw2 I think you missed the point: you don't choose conditions, the sun does. – Phil Frost - W8II Jan 23 '14 at 00:29
  • And the Earth rotates (etc.), which changes the suns position in the sky relative to the local ionosphere (etc.), which may affect optimal operating bands and times (etc.), which is the question. – hotpaw2 Jan 23 '14 at 00:34
  • @hotpaw2 you seem to know this topic pretty well. Perhaps you should write an answer. – Phil Frost - W8II Jan 23 '14 at 00:40
