For longer sentences with more verbs, it is often hard for a learner to figure out when to use the double infinitive sentence structure and when to use the past participle.
For example in the following two sentences:
They will have to pick him up from the train station. =
Sie werden ihn vom Bahnhof abholen müssen.
versus
They would have bought it. =
Sie würden es gekauft haben.
Both these sentences contain three verbs, the first verb in the second position as normal, but then one sentence uses the double infinitive structure, whilst the second has a past participle. How do you know when to use which type of structure?
Apart from knowing that "sie würden es kaufen haben" sounds wrong and strange, I don't know how one would definitively know how to use the ge-verb form.
Em1
  • 38,586
  • 91
  • 208
user5105
  • 4,086
  • 30
  • 48
  • Do you really want the second example to be in a subjunctive mood in German and to use would in English? – Wrzlprmft Jan 13 '14 at 10:37
  • Wouldn't it still be the same construction? Ie for they will have bought it = sie werden es gekauft haben. It doesn't change my question as to when to use the two different types of sentence structures. I'll think of some more examples tomorrow but it's now midnight here ;) – user5105 Jan 13 '14 at 10:57
    even then, the second example is unidiomatic: "Sie hätten es gekauft." Is more german-like and your problem suddenly is a lot smaller. – Vogel612 Jan 13 '14 at 13:22
  • Btw, the nasty case is „Sie haben ihn vom Bahnhof abholen müssen“, which seems to contradict my answer but is treated here. – Carsten S Jan 13 '14 at 13:37
  • @Vogel612: That's correct if you read the English sentence to be in present tense; not if it's future. ("idiomatic" maybe in spoken language, but even then not on its own; you need some pointer to the future.) – Raphael Jun 11 '14 at 05:55
  • It is not clear that the second English sentence even talks about the future; it could as well continue with " if they had (had) the money". – Raphael Jun 11 '14 at 05:57
I think there's a degree of confusion about the 'double infinitive'.
The sentence:
(1) Sie werden ihn vom Bahnhof abholen müssen.
is the future of the sentence
(0) Sie müssen ihm vom Bahnhof abholen.
The future is formed with werden + infinitive. As a result the sentence (1) has nothing special, there is no 'double infinitive rule' involved here. It's just the standard form of the future.
Now if we form the present perfect of (0), what we normally expect is that müssen becomes haben + past participle of müssen (that is, gemusst). However, the actual present perfect of (0) is:
(2) Sie haben ihn vom Bahnhof abholen müssen.
In other words the expected past participle of müssen is replaced by the infinitive müssen, hence an (unexpected) double infinitive (abholen müssen).
And that is the rule of the double infinitive.
Em1
  • 38,586
  • 91
  • 208
french imp
Your first English sentence is "will have to pick". This sentence contains also three verbs.
  • will -> future -> werden
  • have to -> müssen
  • pick -> infinitive -> abholen
So this sentence is translated as "werden ... abholen müssen".
The other sentence is "would have bought". Again three verbs.
  • would -> conditional -> würden
  • have -> auxiliary -> haben
  • bought -> past participle -> gekauft
That sentence is translated as "würden ... gekauft haben".
There's no much different between English and German in respect to verb forms. Fortunately, the future tenses are quite equal in both language. You only need to pay attention on the word order, but it's quite the same in both sentences as you've likely noted.
In case Wrzlprmft is right with his comment and you change would to will, you simply replace würden with werden in the German sentence as well. Note, that still the English sentences are different. It's then just Futur 1 vs Futur 2 (as they're called in German).
Em1
  • 38,586
  • 91
  • 208
My impression is that this a use of "werden" to denote the passive voice and a modal verb "müssen". Together they require the double infinitive, abholen müssen.
Ingmar
  • 19,257
  • 48
  • 82
Vivaxms
