I work for a project in the style of game "Minecraft".
I started using the "Model Instancing" in order to generate a large number of cubes possessing an identical model. So far so good. My problem is that if I increase the size of my matrix to draw from [300-1-300] (90,000 cubic meters) of [500-1-500] (250,000 cubic meters) my program slows down tremendously. It goes from 60fps to 20 ...
I do not really understand why. But I use the technique correctly "Hardware Instancing". I also noticed on forums that this technique allows XNA to draw up to 7 million cubic!! Do you have any idea from where my problem ?
Thanks a lots
Here is my function that draws the model instantiated:
// Draw the 3D map (world) of game
public void drawWorld(GameTime gameTime)
/ * Draw all the structures that make up the world with the instancing system * /
Array.Resize(ref instanceTransforms, smallListInstance.Count);
for (int i = 0; i < ListInstance.Count; i++)
instanceTransforms[i] = ListInstance[i].Transform;
DrawModelHardwareInstancing(myModel, myTexture2D,instancedModelBones,instanceTransforms, arcadia.camera.View, arcadia.camera.Projection);
// ### end function drawWorld
Here is my function [DrawModelHardwareInstancing] which draws models with the method [Hardware Instancing] used in the sample from microsoft.
// Function that will draw all the models instantiated in the list
void DrawModelHardwareInstancing(Model model,Texture2D texture, Matrix[] modelBones,
Matrix[] instances, Matrix view, Matrix projection)
Game.GraphicsDevice.SamplerStates[0] = SamplerState.LinearWrap;
if (instances.Length == 0)
return;
// If we have more instances than room in our vertex buffer, grow it to the neccessary size.
if ((instanceVertexBuffer == null) ||
(instances.Length > instanceVertexBuffer.VertexCount))
if (instanceVertexBuffer != null)
instanceVertexBuffer.Dispose();
instanceVertexBuffer = new DynamicVertexBuffer(Game.GraphicsDevice, instanceVertexDeclaration,
instances.Length, BufferUsage.WriteOnly);
// Transfer the latest instance transform matrices into the instanceVertexBuffer.
instanceVertexBuffer.SetData(instances, 0, instances.Length, SetDataOptions.Discard);
foreach (ModelMesh mesh in model.Meshes)
foreach (ModelMeshPart meshPart in mesh.MeshParts)
// Tell the GPU to read from both the model vertex buffer plus our instanceVertexBuffer.
Game.GraphicsDevice.SetVertexBuffers(
new VertexBufferBinding(meshPart.VertexBuffer, meshPart.VertexOffset, 0),
new VertexBufferBinding(instanceVertexBuffer, 0, 1)
Game.GraphicsDevice.Indices = meshPart.IndexBuffer;
// Set up the instance rendering effect.
Effect effect = meshPart.Effect;
//effect.CurrentTechnique = effect.Techniques["HardwareInstancing"];
effect.Parameters["World"].SetValue(modelBones[mesh.ParentBone.Index]);
effect.Parameters["View"].SetValue(view);
effect.Parameters["Projection"].SetValue(projection);
effect.Parameters["Texture"].SetValue(texture);
// Draw all the instance copies in a single call.
foreach (EffectPass pass in effect.CurrentTechnique.Passes)
pass.Apply();
Game.GraphicsDevice.DrawInstancedPrimitives(PrimitiveType.TriangleList, 0, 0,
meshPart.NumVertices, meshPart.StartIndex,
meshPart.PrimitiveCount, instances.Length);
// ### end function DrawModelHardwareInstancing
