Im not sure if i use the right terms, but im not able to find something to start with.
Im trying to develop a little HTML5 game. I have a ground with a texture and now I want to make a surrounding texture. The texture is an image wich should be bend around the ground.
At the moment im using easelJS for display my images/textures. So im looking for some sort of Tutorial/Script/Advice. Im not even sure if I can bend a image in javascript. So the worst case I can think of is split the image in 100 pieces and then put it back together and rotate each piece.
for example like this:
edge Texture
fehrlich
  • 121
  • Are you asking about how to make a grass layer to follow your ground? Cos it's hard to see the idea on your picture. – Kromster Sep 27 '12 at 18:51
  • yes the question is how i can bend the image to fit the ground – fehrlich Oct 17 '12 at 08:44
    Take a look at this question, it looks similar to yours: http://gamedev.stackexchange.com/questions/15302/how-can-i-get-textures-on-edge-of-walls-like-in-super-metroid-and-aquaria – Kromster Oct 18 '12 at 07:46
    @KromStern I don't think so - that question presumes a tile-based rendering. This question appears to be talking about curving images (i.e. spline based terrain). Perhaps the OP could clarify. I think it's a tricky problem, but pertinent to game-development certainly. – MrCranky Apr 27 '14 at 09:28
  • yes im looking for a way to curve the image on a spline – fehrlich Apr 27 '14 at 12:16
  • The linked duplicate does not appear to presume tile-based at all, nor does the solution. –  Apr 29 '14 at 22:20
