Let me see if by trying to understand as a web/UI JS dev, I can be of help. Also, don't go too far in language agnosticism. A lot of patterns established in other languages are worth studying but can be applied very differently in JS due to its flexibility or really aren't necessary due to the malleable nature of the language. You could blow some opportunities if you write your code thinking of JS as having the same set of boundaries that a more classical OOP-oriented language does.
First of all, on the "don't use OOP" factor, remember that JavaScript objects are like playdough compared to other languages and you actually have to go out of your way to build a cascading-inheritance scheme nightmare since JS isn't class-based and compositing comes much more naturally to it. If you are implementing some silly class or prototype hand-me-down system in your JS, consider ditching it. In JS we use closures, prototypes, and we pass functions around like candy. It's disgusting and filthy and wrong but also powerful, concise and that's the way we like it.
Inheritance heavy approaches are actually spelled out as an anti-pattern in Design Patterns and for good reason as anyone who has walked down 15+ levels worth of class or class-like structures to try and figure out where the heck the busted version of a method was coming in from can tell you.
I don't know why so many programmers love doing this (especially java guys writing JavaScript for some reason), but it's awful, illegible, and completely unmaintainable when used to excess. Inheritance is okay here and there, but not really necessary in JS. In languages where it's a more enticing shortcut, it should really be reserved for more abstract architecture concerns rather than more literal modeling schemes like frankensteining a zombie implementation through an inheritance chain that included a BunnyRabbit because it happened to work. That's not good code reuse. It's a maintenance nightmare.
As a JS dev Entity/Component/System based engines strike me as a system/pattern for decoupling design concerns and then compositing objects for implementation on a highly granular level. In other words, child's play in a language like JavaScript. But let me see if I'm grokking this correctly first.
Entity - The specific thing you are designing. We're talking more in the direction of proper nouns (but not actually, of course). Not 'Scene', but 'IntroAreaLevelOne'. IntroAreaLevelOne might sit inside a sceneEntity box of some kind but we're focusing on something specific that varies from other related things.
In the code, an entity is really just a name (or ID) tied to a bunch of stuff that it needs to have implemented or established (the components) in order to be useful.
Components - types of things an entity needs. These are general nouns. Like WalkingAnimation. Within WalkingAnimation we can get more specific, like "Shambling" (good choice for zombies and plant monsters), or "ChickenWalker" (great for reverse-joint ed-209ish robot-types). Note: Not sure how that could decouple from the rendering of a 3D model like that - so maybe a crap example but I'm more of a JS pro than an experienced game dev.
In JS I would put the mapping mechanism in the same box with the components. Components in their own right are likely to be light on logic and more of a roadmap telling your systems what to implement if systems are even needed (in my attempt at ECS some components are just collections of property sets). Once a component is established, it's easy enough to tweak one component and assign the altered version to a new name if necessary but having sets of properties that can referred to for branching of behavior established by Systems strikes me as a better way to go.
Systems - The real programmey meat is here. AI systems are built and linked, Rendering is achieved, animations sequences established, etc... I'm copping out and leaving these mostly to the imagination but in the example System.AI takes a bunch of properties in and spits out a function which is used to add event handlers to the object that ultimately gets used in implementation. The key thing about System.AI is that it covers multiple component types. You could sort out all the AI stuff with one component but to do so is to misunderstand the point of making things granular.
Mind the Goals: We want to make it easy to plug in some kind of GUI interface for non-designers to easily tweak different kinds of stuff by maxing and matching components within a paradigm that makes sense to them, and we want to get away from popular arbitrary code schemes that are a lot easier to write than they are to modify or maintain.
So in JS, maybe something like this. Game devs please tell me if I've got it horribly wrong:
//I'm going with simple objects of flags over arrays of component names
//easier to read and can provide an opt-out default
//Assume a genre-bending stealth assassin game
//new (function etc... is a lazy way to define a constructor and auto-instantiate
var npcEntities = new (function NpcEntities(){
//note: {} in JS is an object literal, a simple obj namespace (a dictionary)
//plain ol' internal var in JS is akin to a private member
var default={ //most NPCs are humanoids and critters - why repeat things?
speedAttributes:true,
maneuverAttributes:true,
combatAttributes:true,
walkingAnimation:true,
runningAnimation:true,
combatAnimation:true,
aiOblivious:true,
aiAggro:true,
aiWary:true, //"I heard something!"
aiFearful:true
//this. exposes as public
this.zombie={ //zombies are slow, but keep on coming so don't need these
runningAnimation:false,
aiFearful:false
this.laserTurret={ //most defaults are pointless so ignore 'em
ignoreDefault:true,
maneuverAttrubtes:true, //turning speed only
//also this.nerd, this.lawyer and on and on...
//loop runs on instantiation which we're forcing on the spot
//note: it would be silly to repeat this loop in other entity collections
//but I'm spelling it out to keep things straight-forward.
//Probably a good example of a place where one-level inheritance from
//a more general entity class might make sense with hurting the pattern.
//In JS, of course, that would be completely unnecessary. I'd just build a
//constructor factory with a looping function new objects could access via
//closure.
for(var x in npcEntities){
var thisEntity = npcEntities[x];
if(!thisEntity.ignoreDefaults){
thisEntity = someObjectXCopyFunction(defaults,thisEntity);
//copies entity properties over defaults
else {
//remove nonComponent property since we loop again later
delete thisEntity.ignoreDefaults;
})() //end of entity instantiation
var npcComponents = {
//all components should have public entityMap properties
//No systems in use here. Just bundles of related attributes
speedAttributes: new (function SpeedAttributes(){
var shamblingBiped = {
walkingAcceleration:1,
topWalking:3
averageMan = {
walkingAcceleration:3,
runningAcceleration:4,
topWalking: 4,
topRunning: 6
programmer = {
runningAcceleration:100,
topWalking:2
topRunning:2000
}; //end local/private vars
//left is entity names | right is the component subcategory
this.entityMap={
zombie:shamblingBiped,
lawyer:averageMan,
nerd:programmer,
gCostanza:programmer //makes a cameo during the fire-in-nursery stage
})(), //end speedAttributes
//Now an example of an AI component - maps to function used to set eventHandlers
//functions which, because JS is awesome we can pass around like candy
//I'll just use some imaginary systems on this one
aiFearful: new (function AiFearful(){
var averageMan = Systems.AI({ //builds and returns eventSetting function
fearThreshold:70, //%hitpoints remaining
fleeFrom:'lastAttacker',
tactic:'avoidIntercept',
hazardAwareness:'distracted'
programmer = Systems.AI({
fearThreshold:95,
fleeFrom:'anythingMoving',
tactic:'beeline',
hazardAwareness:'pantsCrappingPanic'
});//end local vars/private members
this.entityMap={
lawyer:averageMan,
nerd:averageMan, //nerds can run like programmers but are less cowardly
})(),//and more components...
//Systems.AI is general and would get called for all the AI components.
//It basically spits out functions used to set events on NPC objects that
//determine their behavior. You could do it all in one shot but
//the idea is to keep it granular enough for designers to actually tweak stuff
//easily without tugging on developer pantlegs constantly.
//e.g. SuperZombies, zombies, but slightly tougher, faster, smarter
}//end npcComponents
function createNPCConstructor(npcType){
var components = npcEntities[npcType],
//objConstructor is returned but components is still accessible via closure.
objConstructor = function(){
for(var x in components){
//object iteration <property> in <object>
var thisComponent = components[x];
if(typeof thisComponent === 'function'){
thisComponent.apply(this);
//fires function as if it were a property of instance
//would allow the function to add additional properties and set
//event handlers via the 'this' keyword
else {
objConstructor.prototype[x] = thisComponent;
//public property accessed via reference to constructor prototype
//good for low memory footprint among other things
return objConstructor;
var npcBuilders= {}; //empty object literal
for (var x in npcEntities){
npcConstructors[x] = createNPCConstructor(x);
Now any time you need an NPC, you could build with npcBuilders.<npcName>();
A GUI could plug into the npcEntities and components objects and allow designers to tweak old entities or create new entities by simply mixing and matching components (although there's no mechanism in there for non-default components but special components could be added on the fly in the code as long as there was a defined component for it.
Entity should not be derived from, any differences between entities should be accomplished through components.
Generally you will need an interface for each major system (Rendering, Physics, Networking, Input, Audio, etc...). The way I've setup my renderer is to query the scene for renderable entities, and the scene manager than asks each entity that has a render component on it for its render information.
– Nic Foster Jul 18 '12 at 23:21
