Is there any way to get Unity 3D to run on Ubuntu. I am currently running Ubuntu 12.04 64bit edition. I also have Wine installed.
According to Unity's bizarro-world SO the answer is no. The Unity3D authoring program is only available for Windows or Mac OS.
According to WineHQ AppDB Unity3D versions 3.3.0 and prior might work via wine.
Here's a link for 3.3.0: http://download.unity3d.com/download_unity/UnitySetup-3.3.0.exe
- 276
- 1
- 6
It's been years since this question was done, but Unity has started to develop the editor for Linux.
More info on the link http://blogs.unity3d.com/2015/07/01/the-state-of-unity-on-linux/
- 31
- 3
My answer is perhaps.
I tried to run Unity3d 4 with the same configuration. Installs flawlessly, but when you try to run it, it fails at start when trying to checking license for activation.
I wonder if there is some manner to bypass that step. For example, I was able to run the activation part on a Windows XP running within an VirtualBox, so perhaps moving some archive from that VirtualBox install to the wine one may do the trick. Just wonder...
On the other hand it didn't work fine neither on my VirtualBox. Windows are not drawn correctly and crashes after a few seconds.
- 121
- 3
1I finally gave up and reinstalled Windows Vista in my laptop just for running Unity. Sad day... – Fran Marzoa Dec 03 '12 at 16:36
You have to use winetricks to improve several parts of WINE for compatibility sake before it will work. Fonts, DirectX, force Mono, and you have to edit the registry. More details are out there.
- 11
- 1
Unity3D
in google, which gives me good results. – Francisco Presencia Jun 03 '13 at 02:17
