Whenever I try to run my Lua script, right after the first function, be it defining a parameter, mission planner (ground control station of ardupilot), display an error message saying unexpected token.
function pr()
local altitude = vehicle:get_altitude()
  if altitude > 1
  then
    abc:set_value(1)
    gcs:send_text("Above 1m")
  else
    abc:set_value(0)
    gcs:send_text("Below 1m")
  end
return update, 500 end
local abc = param:define_class("abc") abc:set_name("test") abc:set_description("This is a test parameter.") abc:set_value(1)
param:add_parameter(abc) pr()
Here, right after the function, it displays an error message:
("SyntaxError: unexpected token 'abc'")
liggiorgio
  • 4,636
  • 25
  • 37
abc is shown in the pr() function before it is defined. This is likely because you're defining abc as a local variable.
Some suggestions to fix it:
  • make abc a global variable by removing the local part. (I recall pico-8 auto defines variables that way)
  • add the abc as parameter to the pr() function , like pr(abc) at both locations
Steven
  • 891
