This expression:
inputDirection = orientation.forward * verticalInput + orientation.right * horizontalInput
can only equivalent to this:
inputDirection = new Vector3(horizontalInput, 0.0f, verticalInput)
if orientation.forward
is Vector3(0.0f, 0.0f, 1.0f)
and orientation.right
is Vector3(1.0f, 0.0f, 0.0f)
Which I cannot guarantee to be true. Why? Because orientation
is a variable, and thus it might… well… vary. Using orientation
allows you to have the input be… well… oriented differently. For example, to make it relative to move a character in a direction relative to where the camera is pointing or to move a vehicule according to its current orientation, and so on.
Ok, so you say you want to understand vectors. You need to start with these operations:
- Vector-Scalar product
- Vector addition
So, when you have a Vector-Scalar product such as this:
v * f
Is equivalent to this:
Vector3(v.x * f, v.y * f, v.z * f)
Thus, this:
Vector3(
orientation.forward.x * verticalInput,
orientation.forward.y * verticalInput,
orientation.forward.z * verticalInput
And this:
Vector3(
orientation.right.x * horizontalInput,
orientation.right.y * horizontalInput,
orientation.right.z * horizontalInput
Vector addition
If you add two vectors like this:
a + b
It is equivalent to this:
Vector3(a.x + b.x, a.y + b.y, a.z + b.z)
So when you have this:
Vector3(
) + Vector3(
Vector3(
orientation.forward.x * verticalInput + orientation.right.x * horizontalInput,
orientation.forward.y * verticalInput + orientation.right.y * horizontalInput,
orientation.forward.z * verticalInput + orientation.right.z * horizontalInput
Wrapping up
So how can
Vector3(
Be the same as this:
Well, it implies that:
horizontalInput == orientation.forward.x * verticalInput + orientation.right.x * horizontalInput
0.0f == orientation.forward.y * verticalInput + orientation.right.y * horizontalInput
verticalInput == orientation.forward.z * verticalInput + orientation.right.z * horizontalInput
And thus:
orientation.forward.x == 0.0f
orientation.right.x == 1.0f
orientation.forward.y == 0.0f
orientation.right.y == 0.0f
orientation.forward.z == 1.0f
orientation.right.z == 0.0f
Which is how I get this:
orientation.forward = Vector3(0.0f, 0.0f, 1.0f)
orientation.right = Vector3(1.0f, 0.0f, 0.0f)
Learning material
I'm going to send you to 3Blue1Brown video series on Linear Algebra.
I have written an Introduction to Vector Algebra and How to Work With Arbitrarily Oriented Vectors before, which you go over if you rather my writing.
