I know I can initialize arrays via code written in C++, etc. to set arrays in a shader. What I want to know is if I can initialize the array in HLSL code instead.
For example:
float3 myArray[64] = InitializeFunction();
Is this possible?
I've tried calling this type of function in my vertex shader to set values on the array, but I get unrolling errors...
Is there a concept of a function that only runs once per frame for a shader?
liggiorgio
  • 4,636
  • 25
  • 37
jjxtra
  • 127
No, there is no such concept. You must use CPU code to initialize your variables.
DMGregory
  • 134,153
  • 22
  • 242
  • 357
  • Shader programming is not my area of expertise, but shouldn't it be possible to first use a compute shader to create that array as a raw buffer and then bind that buffer to the vertex shader? https://stackoverflow.com/questions/19907062/how-can-i-feed-compute-shader-results-into-vertex-shader-w-o-using-a-vertex-buff – Philipp Dec 09 '21 at 12:49
  • @Philipp sure, but you're still invoking the compute shader from the CPU side, rather than having it automatically invoked as a sort of "initial setup step" of the vertex shader, which is what I read the question to be asking. If it's just about doing the computation on the GPU, even if the CPU still has to invoke each step, then I'd say a compute shader for setup is a good solution worth sharing in an answer. – DMGregory Dec 09 '21 at 12:53
  • Thanks that's what I figured. Too bad, I would love to have had some sort of initialize call so that my shader could be distributed without the coupling to CPU side code. Thanks for the answer. – jjxtra Dec 09 '21 at 16:31
