2 players works fine but I can't debug the minimax algorithm, it just keeps going.. sorry that the code is messy
import random
board in nested list
board = [[' ',' ',' ',' ',' ',' ',' '],[' ',' ',' ',' ',' ',' ',' '],[' ',' ',' ',' ',' ',' ',' '], [' ',' ',' ',' ',' ',' ',' '],[' ',' ',' ',' ',' ',' ',' '],[' ',' ',' ',' ',' ',' ',' ']]
draws the board
def boarddraw(board): print("\t 1 2 3 4 5 6 7") print("\t+---+---+---+---+---+---+---+") print("\t| "+board[0][0]+" | "+board[0][1]+" | "+board[0][2]+" | "+board[0][3]+" | "+board[0][4]+" | "+board[0][5]+" | "+board[0][6]+" |") print("\t+---+---+---+---+---+---+---+") print("\t| "+board[1][0]+" | "+board[1][1]+" | "+board[1][2]+" | "+board[1][3]+" | "+board[1][4]+" | "+board[1][5]+" | "+board[1][6]+" |") print("\t+---+---+---+---+---+---+---+") print("\t| "+board[2][0]+" | "+board[2][1]+" | "+board[2][2]+" | "+board[2][3]+" | "+board[2][4]+" | "+board[2][5]+" | "+board[2][6]+" |") print("\t+---+---+---+---+---+---+---+") print("\t| "+board[3][0]+" | "+board[3][1]+" | "+board[3][2]+" | "+board[3][3]+" | "+board[3][4]+" | "+board[3][5]+" | "+board[3][6]+" |") print("\t+---+---+---+---+---+---+---+") print("\t| "+board[4][0]+" | "+board[4][1]+" | "+board[4][2]+" | "+board[4][3]+" | "+board[4][4]+" | "+board[4][5]+" | "+board[4][6]+" |") print("\t+---+---+---+---+---+---+---+") print("\t| "+board[5][0]+" | "+board[5][1]+" | "+board[5][2]+" | "+board[5][3]+" | "+board[5][4]+" | "+board[5][5]+" | "+board[5][6]+" |") print("\t+---+---+---+---+---+---+---+")
randomizer to determine who starts
def start(starter = ['p1','p2']): starter = random.choice(starter) return starter
player move
def pmove(valid = [1,2,3,4,5,6,7]): pmove = 0 while pmove not in valid: try: pmove = int(input(player+ ", please select which column you want to drop your piece("+piece+"): (1 - 7): ")) except ValueError: continue return pmove
runs several fuctions to check boardstate for wins for player
def checkwin(board): if winhorizontal(board): return True elif winvertical(board): return True elif windiagonala(board): return True elif windiagonalb(board): return True else: return False
runs checkwin functions and displays winner
def winner(): if checkwin(board): boarddraw(board) print("\n"+player+" won!!!") return True else: return False
checks if board is full, if so, the game is a draw
def free(board): if any(' ' in space for space in board): return True else: print("draw") return False
function to check which is the lowest row of the column that is free
def drop(pmove): i = 0 if board[i][pmove-1] != ' ': return False else: while board[i][pmove-1] == ' ': if i == 5: board[i][pmove-1] = piece return True i += 1 board[i-1][pmove-1] = piece return True
Horizontal check
def winhorizontal(board): for column in range(6): for row in range(4):
        if board[column][row] + board[column][row+1] + board[column][row+2] + board[column][row+3] == 4 * piece:
            return True
        else:
            continue
Vertical check
def winvertical(board):
for column in range(3): for row in range(7): if board[column][row] + board[column+1][row] + board[column+2][row] + board[column+3][row] == 4 * piece: return True else: continue
diagonal check a
def windiagonala(board):
for column in range(3): for row in range(4): if board[column][row] + board[column+1][row+1] + board[column+2][row+2] + board[column+3][row+3] == 4 * piece: return True else: continue
diagonal check b
def windiagonalb(board): for column in range(3,6): for row in range(4): if board[column][row] + board[column-1][row+1] + board[column-2][row+2] + board[column-3][row+3] == 4 * piece: return True else: continue
def winner1(): if checkwin1(board): print("won") return True else: return False
def winner2(): if checkwin2(board): print("lost") return True else: return False
def checkwin1(board): if winhorizontal1(board): return True elif winvertical1(board): return True elif windiagonala1(board): return True elif windiagonalb1(board): return True else: return False
def checkwin2(board): if winhorizontal2(board): return True elif winvertical2(board): return True elif windiagonala2(board): return True elif windiagonalb2(board): return True else: return False
Horizontal check AI1
def winhorizontal1(board): for column in range(6): for row in range(4):
        if board[column][row] + board[column][row+1] + board[column][row+2] + board[column][row+3] == 4 * dr:
            return True
        else:
            continue
Vertical check AI1
def winvertical1(board):
for column in range(3): for row in range(7): if board[column][row] + board[column+1][row] + board[column+2][row] + board[column+3][row] == 4 * dr: return True else: continue
diagonal check a AI1
def windiagonala1(board):
for column in range(3): for row in range(4): if board[column][row] + board[column+1][row+1] + board[column+2][row+2] + board[column+3][row+3] == 4 * dr: return True else: continue
diagonal check b AI1
def windiagonalb1(board): for column in range(3,6): for row in range(4): if board[column][row] + board[column-1][row+1] + board[column-2][row+2] + board[column-3][row+3] == 4 * dr: return True else: continue
Horizontal check AI2
def winhorizontal2(board): for column in range(6): for row in range(4):
        if board[column][row] + board[column][row+1] + board[column][row+2] + board[column][row+3] == 4 * pl:
            return True
        else:
            continue
Vertical check AI2
def winvertical2(board):
for column in range(3): for row in range(7): if board[column][row] + board[column+1][row] + board[column+2][row] + board[column+3][row] == 4 * pl: return True else: continue
diagonal check a AI2
def windiagonala2(board):
for column in range(3): for row in range(4): if board[column][row] + board[column+1][row+1] + board[column+2][row+2] + board[column+3][row+3] == 4 * pl: return True else: continue
diagonal check b AI2
def windiagonalb2(board): for column in range(3,6): for row in range(4): if board[column][row] + board[column-1][row+1] + board[column-2][row+2] + board[column-3][row+3] == 4 * pl: return True else: continue
def compmove(): bestscore = -10000
bestmove = 0
for move in range(7):
if board[0][move] == ' ':
j = 0 while board[j][move] == ' ': if j == 5: board[j][move] = dr score = deepretard(board, 0, False) board[j][move] = ' '
if score > bestscore:
bestscore = score bestmove = move return bestscore j += 1 board[j-1][move] = dr score = deepretard(board, 0, False) board[j-1][move] = ' ' if score > bestscore:
bestscore = score print(bestscore)
bestmove = move + 1
return bestmove
def deepretard(board, treedepth, max): if winner1():
return 1
elif winner2():
return -1
elif not free(board):
return 0
if max:
bestscore = -10000
i = 0 while board[i][move] == ' ': if i == 5: board[i][move] = dr score = deepretard(board, treedepth + 1, False) board[i][move] = ' '
bestscore = score return bestscore i += 1 board[i-1][move] = dr score = deepretard(board, treedepth + 1, False) board[i-1][move] = ' '
bestscore = score
return bestscore else: bestscore = 10000
i = 0 while board[i][move] == ' ': if i == 5: board[i][move] = pl score = deepretard(board, treedepth + 1, True) board[i][move] = ' '
if score < bestscore:
bestscore = score return bestscore i += 1 board[i-1][move] = pl score = deepretard(board, treedepth + 1, True) board[i-1][move] = ' '
Game start
print(""" _________ __ _____
_ ___ \ ____ ____ ____ ____ _____/ |_ / | | / \ / / _ \ / \ / _/ __ _/ ___\ \ / | |_ \ _( <_> ) | \ | \ ___/\ ___| | / ^ / ______ /____/|___| /___| /___ >___ >| ____ | / / / / / || \t\t\t\t\t By Jeroen Penders """) print("Welcome to Connect 4 version 1.1\n") print("AI is coming soon, for now this is only a 2 player game, enjoy!\n") print("Enter 1 to play against DeepRetard AI") print("Enter 2 to play a 2 player game") playercount = int(input("Enter 1 or 2: ")) if playercount == 2: name1 = input("Player 1 please enter your name: ") name2 = input("Player 2 please enter your name: ") print("\nHello, "+name1+" and "+name2+"!\n" ) input("Please press enter to see who begins\n") starter = start() if starter == 'p1': player1 = name1 player2 = name2 print(name1+" begins!\n") input("Press enter to begin...") else: player2 = name1 player1 = name2 print(name2+" begins!\n") input("Press enter to begin...") while free(board): player = player1 piece = 'X' boarddraw(board) p1move = pmove() while not drop(p1move): boarddraw(board) print("Column is full...") p1move = pmove() if winner(): exit() player = player2 piece = 'O' boarddraw(board) p2move = pmove() while not drop(p2move): boarddraw(board) print("Column is full...") p2move = pmove() if winner(): exit()
# only displayed if board is full
boarddraw(board)
print(&quot;Board is full, it's a draw...&quot;)
else: name1 = input("Please enter your name: ") name2 = "DeepRetard" print("\nHello, "+name1+"! So you think you can defeat DeepRetard?") input("Press enter to see who begins") starter = start() if starter == 'p1': player1 = name1 player2 = name2 print(name1+" begins!\n") input("Press enter to begin...") piece = 'X' pl = 'X' dr = 'O' player = player1 boarddraw(board) p1move = pmove() while not drop(p1move): boarddraw(board) print("Column is full...") p1move = pmove() if not free(board): print("The game is a draw...") exit() if winner(): exit() player = player2 compm = compmove() p2move = pmove(compm) if winner(): exit()
else:
    player2 = name1
    player1 = name2
    print(name2+&quot; begins!\n&quot;)
    input(&quot;Press enter to begin...&quot;)
    dr = 'X'
    pl = 'O'
    player = player1
    boarddraw(board)
    compm = compmove()
        boarddraw(board)
        print(&quot;Column is full...&quot;)
        p1move = pmove()
    if not free(board):
        print(&quot;The game is a draw...&quot;)
        exit()
    if winner():
        exit()
    player = player2
    boarddraw(board)
    p1move = pmove()
        boarddraw(board)
        p1move = pmove()
    if not free(board):
        exit()
    if winner():
        exit()
</code></pre>
Jerpen80
    It looks to me like your algorithm is set to explore the game tree exhaustively, without ever falling back on a heuristic. So, checking all 7 possible moves, then all 7 possible replies to each of those, then all 7 possible replies to each of those... until there are no more legal moves to check. Since Connect 4 has something like 4.5 trillion game states, and your code has no memoization to avoid re-checking the equivalent states from multiple directions, you might not be in an "infinite" loop, just busy checking more possibilities than can be explored in a reasonable time frame. – DMGregory Jul 24 '21 at 12:07
  • Thank you for your quick reply! I will look into that! I'm just a beginner but making the minimax algorithm more efficient is definitely something I want to expore! – Jerpen80 Jul 24 '21 at 12:15
    Try stopping at a tree depth of 4 or so, and see if that is enough that your algorithm terminates in a reasonable time. If so, then it's probably not an infinite loop, just biting off more computation than you can chew, and you can update your question to ask for help writing a fallback heuristic to handle cases beyond your exploration horizon. – DMGregory Jul 24 '21 at 12:40
