I am looking for an equation for predicting the future position of a moving arcade physics body in Phaser 3. The body has drag applied and isDamping set to true. Phaser applies the drag using the following run on each update (showing x axis only but same applies to y).
//  Damping based deceleration
dragX = Math.pow(dragX, delta);
velocityX *= dragX;
Given the above, how would I write a kinetic equation to predict the future position?
I am currently using the method below, where I am iterating over frames to calculate the position accumulatively. But this is inefficient and inelegant so would prefer a solution which estimates the position without any looping.
public futurePosition(timeInSeconds: number): Phaser.Math.Vector2 {
  const DELTA = 1 / 60; // Assume we are running at 60fps
  const DRAG = 0.3; // Drag value
  const position = this.position.clone(); // Current position of body
  const velocity = this.body.velocity.clone(); // Current velocity
// Inefficiently looping through frames for (let i = 0; i < timeInSeconds / (DELTA * 1000); i++) { velocity.x = Math.pow(DRAG, DELTA); velocity.y = Math.pow(DRAG, DELTA); position.x += velocity.x * DELTA; position.y += velocity.y * DELTA; }
return position; }
Any help appreciated. Thanks.
Calabi
Solved with a geometric progression.
  const fps = 60;
  const drag = Math.pow(0.3, 1 / fps);
  const x = ((this.body.velocity.x / fps) * (1 - Math.pow(drag, timeInSeconds * fps))) / (1 - drag);
  const y = ((this.body.velocity.y / fps) * (1 - Math.pow(drag, timeInSeconds * fps))) / (1 - drag);
return new Phaser.Math.Vector2(this.position.x + x, this.position.y + y); }
Calabi
