using System.Collections;
using System.Collections.Generic;
using UnityEngine;
public class DetectCollision : MonoBehaviour
    public Transform player;
    public Transform target;
    public bool turnOnOffPlayerAnimator = false;
    float timeElapsed = 0;
    float lerpDuration = 3;
    float startValue = 1;
    float endValue = 0;
    float valueToLerp = 0;
    private Animator playerAnimator;
    private bool entered = false;
    private bool prevFacing = false;
    private Rigidbody rigidbody;
    private bool stopped = false;
    // Start is called before the first frame update
    void Start()
        rigidbody = player.GetComponent<Rigidbody>();
        playerAnimator = player.GetComponent<Animator>();
        if (turnOnOffPlayerAnimator)
            playerAnimator.enabled = false;
    // Update is called once per frame
    void Update()
        var currFacing = IsFacing(target);
        if (currFacing != prevFacing)
            // here you switched from facing to not facing or vise verca.
            timeElapsed = 0;
        prevFacing = currFacing;
        var distance = Vector3.Distance(player.position, target.position);
        if (IsFacing(target))
            if (entered && distance > 30)
                if (timeElapsed < lerpDuration)
                    valueToLerp = Mathf.Lerp(startValue, endValue, timeElapsed / lerpDuration);
                    playerAnimator.SetFloat("Forward", valueToLerp);
                    timeElapsed += Time.deltaTime;
                valueToLerp = 0;
        else
            if (valueToLerp < 0.9f)
                    valueToLerp = Mathf.Lerp(endValue, startValue, timeElapsed / lerpDuration);
            Mathf.Lerp(valueToLerp, 0, Time.deltaTime * 0.0001f);
        if(turnOnOffPlayerAnimator)
        else
            playerAnimator.enabled = true;
    private void OnTriggerEnter(Collider other)
        entered = true;
        Debug.Log("Entered !");
    private void OnTriggerExit(Collider other)
        entered = false;
        Debug.Log("Exited !");
    private bool IsFacing(Transform target)
        Vector3 forward = player.TransformDirection(Vector3.forward);
        Vector3 toTarget = target.position - player.position;
        return Vector3.Dot(forward, toTarget) > 0;
I tried first 0.1f but it didn't change the lerp speed.
I want that if the player is pressing the W key and moving the player forward and then stop pressing the key W it will smooth slow will lerp to 0. and it does but I also wanted to control the lerp speed.
I want that when the player is starting moving backward direction if the player leave the W key the player should stop slowly to 0. This should be the line :
but the Time.deltaTime does not seems to affect the lerp at all. the lerp is working fine I just wanted to control the lerping speed too.
Daniel Lip
  • 1,747
  • 34
  • 75
