As per my code:
using System.Collections;
using System.Collections.Generic;
using UnityEngine;
using UnityEngine.UIElements;
using Cursor = UnityEngine.Cursor;
public class FirstPersonController : MonoBehaviour
    public float speed = 5;
    public float jumpPower = 4;
    Rigidbody rb;
    CapsuleCollider col;
    private GameObject player;
    private float minClamp = -45;
    private float maxClamp = 45;
    [HideInInspector]
    public Vector2 rotation;
    private Vector2 currentLookRot;
    private Vector2 rotationV = new Vector2(0,0);
    public float lookSensitivity = 2;
    public float lookSmoothDamp = 0.1f;
    public Camera cam;
    public GameObject crossHair;
    bool isActive;
    // Start is called before the first frame update
    void Start()
        Cursor.visible = false;
        Cursor.lockState = CursorLockMode.Locked;
        rb = GetComponent<Rigidbody>();
        col = GetComponent<CapsuleCollider>();
        player = transform.gameObject;
        crossHair = GameObject.FindWithTag("CrossHair");
    // Update is called once per frame
        void Update()
        float Horizontal = Input.GetAxis("Horizontal") * speed;
        float Vertical = Input.GetAxis("Vertical") * speed;
        Horizontal *= Time.fixedDeltaTime;
        Vertical *= Time.fixedDeltaTime;
        transform.Translate(Horizontal, 0, Vertical);
        if (isGrounded() && Input.GetButtonDown("Jump"))
            rb.AddForce(Vector3.up * jumpPower, ForceMode.Impulse);
        if (Input.GetKeyDown("escape"))
            Cursor.lockState = CursorLockMode.None;
        if (Input.GetButtonDown("Sprint"))
            speed = 15;
            //Debug.Log("Sprint Button Held Down");
        if (Input.GetButtonUp("Sprint"))
            speed = 5;
            //Debug.Log("Sprint Button Let Go");
        if (Input.GetKeyDown(KeyCode.H))
            isActive = !isActive;
        if (isActive)
            crossHair.SetActive(true);
        else
            crossHair.SetActive(false);
        rotation.y += Input.GetAxis("Mouse Y") * lookSensitivity;
        rotation.y = Mathf.Clamp(rotation.y, minClamp, maxClamp);
        player.transform.RotateAround(transform.position, Vector3.up, Input.GetAxis("Mouse X") * lookSensitivity);
        currentLookRot.y = Mathf.SmoothDamp(currentLookRot.y, rotation.y, ref rotationV.y, lookSmoothDamp);
        cam.transform.localEulerAngles = new Vector3(-currentLookRot.y, 0, 0);
    private bool isGrounded()
        return Physics.Raycast(transform.position, Vector3.down, col.bounds.extents.y + 0.1f);
I can't figure out what I am doing wrong in my code, I tried to write a first person controller from scratch.
The full project can be downloaded from: https://github.com/Some-T/FirstPersonController-CSharp
My player goes through any wall or object easily despite it having colliders on the objects and a rigidbody and collider on the player.
I have gone through my code line by line and I cannot work out what is wrong? If someone could please advise me what to change or add to my code to fix this, or / and explain the concept, presumably physics related, as to why this is going wrong please?
SomeT
  • 101
