The formulas to calculate the intersection between a ray and a capped cone / cone frustum are already widely known (see http://lousodrome.net/blog/light/2017/01/03/intersection-of-a-ray-and-a-cone/ or How do I test for intersection between a ray and a cone?) However, I have to test for the intersection between a ray and part of a capped cone. That means instead of having a surface doing a full revolution, it's just one quarter of it, for example.
The aforementioned formulas can handle a capped cone, but they are not suitable to determine the "revolution intersection angle". What would be the best way to solve this problem?
My idea is to first take the standard formula to intersect with the full cone and then use the parametric representation of the cone (see https://de.wikipedia.org/wiki/Kegel_(Geometrie)#Analytische_Beschreibung parametric representation is only on the German page), solve a linear equation system and then applying the inverse trigonometric functions to get the t parameter... I'm also thinking about some inequality tricks or applying the tangent function, but had no luck so far...
