-1
I have variable that I need to save and load between 2 scenes.
So this is what I'm trying:
First script:
public class s1sc : MonoBehaviour
public string playername;
public static s1sc Instance;
void Awake ()
    if (Instance == null)
        DontDestroyOnLoad(gameObject);
        Instance = this;
    else if (Instance != this)
        Destroy (gameObject);
Second script:
public class s2sc : MonoBehaviour
    public string pn;
    void Start ()
        pn = s1sc.Instance.playername;
And it doesn't work fine. What is the problem??
Sourav Paul Roman
  • 2,043
mmoj
This is what I do to retain variables between scenes. Create a static class that is not derived by Monobehaviour:
public static class ApplicationData {
    public static string PlayerName;
Then use it in your Monobehaviour scrips like so:
ApplicationData.PlayerName = "Frank";
This PlayerName variable will persist until you close your application. It will be accessible from all MonoBehaviour scripts.
jgallant
  • 8,414
  • 32
  • 46
  • thank's. it work fine when i need to load variable from "ApplicationData" class. but how can i edit "PlayerName" variable from "Monobehaviour" classes ?? – mmoj Aug 14 '16 at 09:33
-1
You can simply use an empty game object with your desired script and this code, at the least:
void Awake()
    Debug.Log("DontDestory Script's Awake");
    DontDestroyOnLoad(this);
The script with variable values will be maintain across different scenes. I just confirmed the below code with Scene1 and Scene2:
using UnityEngine;
using System.Collections;
public class DontDestroy : MonoBehaviour
    public int testingInt = 10;
    void Reset()
        Debug.Log("DontDestroy Script's Reset");
    void Awake()
    void OnGUI()
        if (GUI.Button(new Rect(10,10,100,50),"increment :"+ testingInt))
            testingInt++;
        if (GUI.Button(new Rect(10,60, 100, 50), "Load second "))
            Application.LoadLevel("Scene2");
Gnemlock
  • 5,263
  • 28
  • 58
Muhammad Faizan Khan
  • 2,020
  • 29
  • 66
